Can't delete a page - Error - "Incorrect structure in pdf"
Feb 11, 2011 11:45 AM
I am unable to delete a page in my pdf (form). I get an error that says - "Incorrect structure in pdf found"....that's it. Can anyone give any insight into this and how I can fix it? I have to delete this page.
Thanks a lot.
    Feb 12, 2011 9:36 AM   in reply to ozworldz
    Sounds like you created the form in Designer and are trying to delete pages in Acrobat. Can't be done. Once you go to Designer, you can no longer do such actions in Acrobat -- The Designer form is an XML form and not a classic PDF.
    Nov 7, 2011 3:24 AM   in reply to ozworldz
    I had the same problem and managed to find a workaround.  Select Document -  Extract pages - and select the pages you want to keep and extract pages as seperate files.  Hope it works for you!
    Jan 5, 2012 9:22 AM   in reply to ozworldz
    Just had the same problem. I think the PDF may have been generated as a "tagged PDF". In my case, I'd generated the PDF from an XHTML document and the tagged option generated a file with a similar structure to the XHTML source.
    When I removed this option I could extract and delete pages.
    I hope this helps.
    Suze
    Jan 9, 2012 9:05 PM   in reply to ozworldz
    I too can't Extract due to- "Incorrect structure in pdf"
    Why can't Adobe figure this out then add a button or run command to fix this. I have a 53 page file with fields (and quite a number of fields). I cannot find where the problem is. All of these posts and message never get answered in a straight forward manner. I shouldn't have to go through countless of web pages of possible solutions to include Adobe's forum...... STILL NO ANSWER.
    I had to go to an older saved file and redo all the changes. C'mon, if the program tells me that there is an "Incorrect Structure" it should be able to tell me where!!!
    I am, as are countless of others, waiting on the solution!
    CS 5 will be my last upgrade if Adobe is unresponsive to it's faithful users!
