I'm cutting a feature film using Premiere Pro cs5... I've finished cutting the first 10 minutes of the film and want to export an OMF or AAF to the sound guy so he can import it into Logic Pro, to test out the workflow... now there is nothing fancy going on with my sequence... 9 audio tracks, just dialog and a music track.... no fx, no audio transitions and the video is straight cuts with a few cross dissolves... I've tried exporting to OMF about 6 different times with this sequence ticking/unticking the options but it never completes the export....just stops %75 through and I have cancel it.... AAF export finishes but lists several errors and less than half of the audio is included... so neither option seems to work correctly...
I read several older posts here about the inability and inconsistency to export OMF/AAF out of Premiere Pro Cs4/Cs5... with the workaround being to manually export each audio track... is that the current state of affairs? Has anyone isolated the factors that cause PPro to stall when trying to generate an OMF?
How are people taking their temp mixes from their PPro cuts and getting them into Pro Tools, Nuendo, Logic etc?
I've also tried exporting OMF's from a few of my other sequences but it never works.... any tips? Or do I just need to manually export each audio track seperately and file a bug report? Thanks!
using PPro Cs5 5.0.3 on Win7 64... i7 920 16gb ram
After doing some more research I found this which has some things to try to get OMF's out of PPro Cs5... I tried all the tricks but none of them worked... Premiere Pro works flawlessly in every other respect...its just too bad this required professional functionality is screwed up... Is the recommended workflow to do final audio mixes inside of Premiere? ![]()
Or lets say you wanted to stay all Adobe ... without OMF/AAF working properly how would you get your multitracks into Adobe Audition? I mean you could always solo your audio tracks and export them one by one... is that the only reliable solution?
Thanks for the reply... After doing more testing I'm able to export an OMF from a simple sequence with 2 audio tracks... but my actual working sequences with 9 audio tracks with lots of dialogue pieces never finish... it seems as with the AAF errors that there are some unsupported features or elements that are causing the problems... I've read about nesting and time remapping causing problems but I'm not using either...
I also had issues with AAF/OMF export of a project I had with three video tracks and 12 audio tracks. I needed to get an edit to a guy and ended up just sending him my project file with the media and he pieced it together that way...
I'm not sure on this, but I think I remember reading something about Premiere struggling with OMF where you had more than 2 or 3 tracks of audio running at once...
Yeh it does seem to choke when trying to export an OMF from these sequences that have 4+ audio tracks going at once... I guess we're supposed to make silent films ![]()
Thanks for the replies! I exported a Final Cut XMLfrom PPro and sent that and the audio source files to a friend running Final Cut Pro and he was able to export an OMF for me...so I guess I'm going to do that as my workaround.
I've just tried to export OMF from CS 5.02 with 13 tracks of audio.. it worked fine, and the sound guy did open it on PT 7.4 ..
I had only one issue, it was stereo tracks that was residing in the timeline as separate mono tracks.. I just made render and replace for these special files and everything went smooth,,
I had different file types on the timeline from DVDs and other MPEG layer 2 audio, audio from canon DSLR files and wave files that were recorded on edirol.. I think there were also other mp3s and wave from different sources.. the sequence was full of audio effects, transitions and volume envelopes.. the timeline count was around 52 minutes.. it works excellent and exports fast..
Actually, it's a completely ineffective method. This is a user-to-user forum with only ocassional Adobe interaction. The proper avenue is here: Adobe Feature Request/Bug Report Form
Hey evryone,
I had a similar experience with PREMIERE 5.5 , spent 5 hours scratching my head, wondering why certain files export no problem and certain make it crash.
After careful combing and process of elimination of audio files I found out that certain encodings of even most common AIF, or MP3's files, trip the system. (for me it was a 2 second AIF snippet of a rock crumbling sound effect huddled together amongst 435 files
FUN!)
So you have to start eliminating channels and keep exporting piecemeal, until you find the faulty encoding. Remove it, and Voila!
From then on everything works FAST & SMOOTH.
Love PREMIERE, but little bugs like that drive you NUTS!
I hope this helps
