Hi all,
Something weird happened in Illy CS5 for me. I can no longer stroke lines [or shapes] using the "Basic" brush [the default stroke in Illy] with a stroke of less than 1pt [or its equivalent (like .376 mm for example)] if a line is either horizontal or vertical or if a shape has either a horizontal or vertical line in it. If I take a line that is diagonal and is stroked with a .25 pt stroke and I align it vertically, then the line stroke pops to 1pt. If I take that line and make it diagonal again, then I can change the stroke so that it is less than 1pt again.
Wha?
I have:
1. reset all my preferences [plist as well as CS5 prefs in folder]
2. restarted Illustrator [multiple times]
3. restarted my machine
With no luck. I still have the problem.
A bit before I noticed the problem, I changed a bunch of my unit preferences to millimeters as well as the units for the document and then changed them back to points. I would think that this might have something to do with the problem, but my husband went and did the same thing and didn't manage to incur the same problem.
Help!
You are using a 'Web' or 'Flash Catalyst' Document profile, which has a property called 'Align New Objects to Pixel Grid' turned ON by default. This property can be found in the New Document dialog (under Advanced) or in the Transform panel flyout menu. This property helps in creating clean, sharp graphics for the Web & this is a new feature in Illustrator CS5.
You can turn this OFF to create strokes (horizontal/vertical) with less than 1pt weight.
Thanks so much!
I often assume that I've done some obscure thing that has spawned a weird bug or something. But after resetting my preferences and restarting, it was hard to pretend that it was anything apart from some obvious and logical thing.
And sure enough...
Thanks a lot for the responses. It makes complete sense! Duh...
Thanks, this solved my problem as well!
The strange thing is that in the same document, while some line weights are restrained by 1pt, some objects with "align to pixel" ticked can still go under 1pt lineweight. The 1pt restrainer only happened randomly on certain new shape I created.
Does anyone know a logical explanation?
I have this problem with CS5. But I have nailed down reproduction of this behaviour.
With stroke width set to points in prefs. to start with you can get lower than 1pt text in the line width setttings. So far so good.
Then I selected the Pen. Set the line width to 0.25 and started to draw an arrow. It all worked until I drew the first acute angle in the arrow shape. And then Illustrator reset the width to 1pt.
My solution was terrible. After 30 mins of frustration I just opened up Illustrator CS4. It worked.
