Solve IT
Saving the fillable pdf
Nov 4, 2011 3:37 AM
Hi this is balaji from solve it corp.I already gone through one post and saw the Lock field and saving it as a new pdfhttps://acrobat.com/app.html#d=*jSHIzy-zFVL-QNo6KCQ1Q.But I am unable to view the scripts.By the way I am using "adobe acrobat pro", there I have only java scripts and Im using the trial version.Can anyone help me to get the scripts for locking the controls and saving the pdf in the "adobe acobat pro".Or is it difficult in using the trial version
    Nov 4, 2011 6:51 AM   in reply to Solve IT
    You woudl have to open the file in LiveCycle Designer to be able to get to the scripts.
    Paul
    Nov 6, 2011 3:48 PM   in reply to Solve IT
    Hi Bala ji,
    Have you got your form done or still looking for help? Paul said right you need to Adobe LiveCycle Designer to integrate your JavaScript within the Interactive PDF form.
    Nov 7, 2011 11:45 PM   in reply to Solve IT
    You can set up the workspace in LC Designer to suit how you will work on your forms.
    Here are some pointers (in particular note 5):
    1. The Hierarchy view is fairly important, as you can select objects on the form and perform actions. For example you can wrap selected objects in a subform or click and drag objects.
    2. The Objects Library is obvious.
    3. The page layout, where you will work on positioning objects. You can also view the Master Page, the XML Source (you rarely need to go in there) and the Preview.
    4. You can select objects on the page (or in the Hierarchy) and then complete tasks. For example add script into the object's events.
    5. The Script Editor is very important when you want to start adding interactivity. If the editor is only one line high, then I would drag the bottom edge down, so that you can see a few lines at a time. This is where you will select the event that you want to script against (Show dropdown), set the scripting language and where the script will run (client mainly or server). You add script to an object using the Script Editor.
    6. It is worthwhile setting up other palettes, so that they are close to hand. For example, the Object, Layout, Border and Accessibility palettes and the Font and Paragraph palettes.
    Hope that helps,
    Niall
    Nov 8, 2011 1:27 AM   in reply to Solve IT
    "Events with script" will show all of the events in an object that have script. If an object does not have script then this will show a blank editor. To start adding script you would select the event that you want the script to fire.
    For example, if you select a Button on your form, you may want to type in script into it's click event. Just select the click event from the Show dropdown:
    You can look at script in any of the events by selecting from the "Show" dropdown.
    Please note that all of these screenshots are of a form opened in LiveCycle Designer.
    Niall
    Nov 8, 2011 2:16 AM   in reply to Solve IT
    If you have a look at this post and a number beneath it, you will see how Paul calls a function from the button.
    http://forums.adobe.com/message/3172744#3172744
    The main script is in the function.
    Niall
    Nov 8, 2011 4:29 AM   in reply to Solve IT
    When you complete your work in LiveCycle Designer and save it now open it in
    - Adobe Acrobat (not in Reader)
    - Go to "File" menu
    - Click on "Save As"
    - Now select 4th option "Reader Extended PDF"
    - And now select last option "Enable Additional Features"
    still need help feel free to post your questions here...
    Nov 8, 2011 4:51 AM   in reply to Solve IT
    Have you read my above points and implemented?
    Nov 8, 2011 4:58 AM   in reply to Solve IT
    First of all you need make your Interactive PDF reader extened to save and work in Adobe Reader. You're not getting my point so first of all implement my above said points and then you can save your PDF in Adobe Reader.
    Nov 8, 2011 5:00 AM   in reply to Solve IT
    That is correct, the ability to Reader enabled a form is not in Reader. It is only available in Acrobat or LiveCycle Resder Extensions ES2.5. See here for further info: http://assure.ly/etkFNU.
    Hope that helps,
    Niall
    Nov 8, 2011 5:53 AM   in reply to Solve IT
    You have opened the form in Adobe Reader. You cannot Reader Enable the form using Reader.
    If you have an earlier version of Acrobat (eg version 7, 8 or 9), then the PDF here includes screenshots of how to Reader Enable the form in Acrobat: http://assure.ly/etkFNU.
    If you have Acrobat X (eg version 10), then this is the option to Reader Enable the form:
    Niall
    Nov 8, 2011 9:09 AM   in reply to Solve IT
    Correct.  Reader-extending a PDF is a capability only in full Acrobat that then enables features in Reader.
