Sequence from Premiere Pro has no Sound in After Effects
Nov 8, 2011 5:53 PM
Tags: #after_effects #audio #import
I created a video Premiere CS5.5 and would now like to take the final cut into After Effects CS5.5. I exported the file as an AVI
(NTSC DV, uncompressed audio) and it plays well in every player I've tried it in. However, now that I'd like to just drop the file into AE the
audio will not play. There is a waveform being displayed for the layer but the audio mixer display doesn't even react when I play it in AE.
Any thoughts?
    Nov 8, 2011 7:16 PM   in reply to DJasonSmith
    Audio enabled in Preview Panel?
    Does audio play when you press the . on the numeric keypad or pick Composition>Preview>Audio?
    Are you using the 0 key on the numeric keypad or the Preview button on the Preview Panel to generate a ram preview?
    Will a standard wav file play?
    Are you an AE Newbie?
    Did you read this FAQ on audio playback?
    Did you read the AE Help file on Audio Preview and Playback?
