Troubleshooting 101: Replace, or "trash" your InDesign preferences
Feb 24, 2014 3:17 PM
  Latest reply: Peter Spier, Feb 24, 2014 3:32 PM
Branched to a new discussion.
Replies 1 2 3 4 5 Previous Next
    Sep 1, 2011 11:25 AM   in reply to Peter Spier
    You rock! That was the issue...it works now. I will keep the preferences in mind when other odd little issues come up! It seemed like (and is) such and easy thing to do, but I was befuddled. Thanks much.
    Sep 14, 2011 3:57 PM   in reply to Peter Spier
    I was hoping you could help me. I am in InDesign CS3 5.0.4 system OSX 10.4.11 and lately when I print to my Canon MP250 my color is not 100%. It seems as though it's 50% of color. All colors are correct just faded. I spoke to Canon and they told me since emails and other pdfs sent to me by friends print fine that it is something to do with Indesign. Photoshop prints fine too. This just started happening and it's driving me crazy. I called Adobe and they told me that there is no longer phone tech support for CS3. Is there any way you can figure this out? I think I looked at about everything there is to look at.
    Sincerely appreciative,
    Cre8tive428
  • John Hawkinson
    Jun 25, 2009
    Sep 14, 2011 4:03 PM   in reply to Cre8tive428
    Cre8tive428: please start a new thread.
    Sep 29, 2011 2:21 PM   in reply to Peter Spier
    Thanks for taking time to help. Much appreciated, Rick
    Nov 9, 2011 12:58 PM   in reply to Peter Spier
    Hi Peter,
    I did both methods. In the manual prefs replacement, however, in my Win7, I did not see the "InDesign SavedData" file. But I did re-name the InDesign Defaults file, both under the Administrator as user, and "users" as user. I renamed both in the same way - adding an extra underscore. It did not fix the problem. Any further suggestions?
  • John Hawkinson
    Jun 25, 2009
    Nov 9, 2011 1:12 PM   in reply to MystiMac
    MysticMac: Not to be tongue-in-cheek, but if the manual method is not
    working for you, use the automatic Vulcan-nerve-pinch method -- hold
    down control-alt-shift while starting InDesign.
    Nov 9, 2011 1:14 PM   in reply to John Hawkinson
    I wasn't clear in my previous reply -- when I said "both methods" I meant I had done the hurry-up-and-control-alt-click as Indd is opening, and it did indeed ask me if I wanted to trash my preferences. I answered yes. Problem not fixed. Next I did the manual method, renaming the files. Alas, no fix yet.
    Mar 14, 2012 3:55 AM   in reply to Peter Spier
    I have recently upgraded to CS5.5 on my work PC running Windows XP Professional.
    I have opened both a new Indesign Document and an existing Indesign file and in both cases I have absolutely no keyboard shortcuts not even the backspace button that will delete an object that I have put on the page.
    I have tried, several times, both re-naming the InDesign Defaults and InDesign SavedData as well as deleting the defaults by holding ctrl + Alt + shift when launching Indesign. Neither of these options have worked.
    I have also accessed the keyboard shortcuts preferences from the edit menu and tried to create a new set. The new set button is active but when I click, it does nothing.  I have also tried going through the default shortcuts and setting them and although it looks like it has registered my command in the 'New shortcut:' box in the bottom left, when I click ok and try to use this command in my document still there is nothing working.
    Please can you help?
    Apr 24, 2012 4:19 PM   in reply to Peter Spier
    You suggested: Macintosh: Hard Drive/Users/Library/Caches/Adobe InDesign/<Version #>/<Language>/ (Note: Prior to version 6 [CS4] the language folder is not used).
    I have done this with no success.
    Apr 24, 2012 4:54 PM   in reply to llamahandler
    Peter forgot the /<username>/ in his description of the path
    Also if you are doing this in 10.7.x you may have to enable hidden files.
    Apr 25, 2012 8:15 AM   in reply to Peter Spier
    I did go to the user library to eliminate the cache.
    I did us the startup combination (a couple of times) to replace preferences, re-installed the program (what a hassle). Still missing something. I appreciate all the possible leads.
  • John Hawkinson
    Jun 25, 2009
    Apr 25, 2012 11:58 PM   in reply to llamahandler
    Try removing the following:
    ~/Library/Application Support/Adobe/Adobe InDesign CS5.5
    ~/Library/Caches/Adobe InDesign
    ~/Library/Caches/com.adobe.InDesign
    ~/Library/Preferences/Adobe InDesign
    ~/Library/Preferences/com.adobe.InDesign.plist
    ~/Library/Preferences/com.adobe.InDesign.plist.lockfile
    ~/Library/Saved Application State/com.adobe.InDesign.savedState
    May 31, 2012 9:27 AM   in reply to monosierra
    I'm having the same issue. Indesign has been working fine until this morning, when I tried opening it and nothing happens. I get the hourglass for two seconds and then it returns to an arrow, no error messages. In task manager it does not show up by applications, but it does show indesign is running by processes. I uninstalled and reinstalled indesign, I spoke to adobe and we removed the preference folders, nothing seems to help. I was able to open indesign in my hidden administrator account, but I can't open it in my regular account. Adobe says its a permissions problem - I need to speak to Microsoft - but how do I get throught to them? How do I change the permissions? Also, it worked fine till now in my regular user account, what happened now??
    May 31, 2012 10:09 AM   in reply to Peter Spier
    Thanks for replying, in the meantime I ran all the updates from the administrator account, rebooted my computer, and now lo and behold it does open in my regular user account! But there seems to be another issue, and that is, I can't open any documents from their folder, I need to go through indesign to open them...
    May 31, 2012 10:19 AM   in reply to Peter Spier
    Yes, they do show the correct icon in the folder, and they open fine when I go through indesign, they just won't open when I double click on the file that I want in my documents.
    May 31, 2012 10:25 AM   in reply to Peter Spier
    windows 7
    May 31, 2012 10:43 AM   in reply to Peter Spier
    It says adobe indesign cs5
    May 31, 2012 11:13 AM   in reply to Peter Spier
    OK will try that tonight when I'm finished with my computer, thanks.
    Jul 16, 2012 7:20 AM   in reply to Peter Spier
    read first post but don't get it. I found the places and files (InDesign Defaults and InDesign SavedData)
    you say
    BOTH of these files should be replaced at the same time.
    1: replaced ... by what ? you say renaming but which renaming ? anything ?
    2: how can you replace two files at the same time ?
    PS: the CRTL+ALT+SHIFT never worked
    Jul 16, 2012 7:51 AM   in reply to Peter Spier
    cool.
    i can export again, thanx !
    the ionly weird thing is that now my swf (like in http://tv.adobe.com/watch/csinsider-design/indesign-creating-interacti ve-pdfs-with-page-turn-and-flash-animations/) are just .. swf icons .... but this may be for another thread ;-)
    Jul 16, 2012 8:01 AM   in reply to Seb Adore
    believe it or not, ont the next document, the issue came back again !
    Jul 17, 2012 3:01 AM   in reply to Peter Spier
    >>> the issue is:
         when i try to export my files in interractive pdfs it does not work anymore, it says (translated from french) "impossible to visualize because Acrobat can't be found. Verify your Acrobat installation".
    >>> Actually ACrobat IS installed (I even completeley resintalled it yesterday to be sure)
    >>> I'm on CS5.5
    >>> Dunno what "patch level of ID" is (?)
    >>> I'm on WIndows 7
    >>> AFter having done an iPad app (folios with indd/DPS) I want to make a "rich pdf version" of my folio
    >>> I already done some before and never had this issue
    thanx
    Aug 3, 2012 3:58 AM   in reply to Peter Spier
    In Windows Vista/7/8 you can use one of the built in environment variables to speed yourself along finding your preferences files (works best when creating docs for multiple users!):
    %USERPROFILE%\AppData\Roaming\Adobe\InDesign\<Version #>\<Language>\
    Aug 27, 2012 3:14 AM   in reply to Peter Spier
    I've tried all of the above solutions and none of them make the slightest bit of difference.  Not ony can I not open any other inDesign document I can't even open the flipping application. Serious error messages sut it down automatically, and by deleting every preference I get as far as the welcome screen before beach-balling. CS6, Mac 10.8. It worked last week. No so anymore. Frustrating and for something that cost so much money it's very poor show. I've spent the better part of 2 hours trying to finish an annual report and can't even opened the damn thing.
    Aug 27, 2012 3:29 AM   in reply to Smoothfluid
    Is the file crashing or the application? You say you're trying to update an annual report. If you go to the folder where that file and show hidden files (http://www.mactricksandtips.com/2008/04/show-hidden-files.html) is there a file in the folder with the extension "IDLK".
    If there is copy this file to a different location (don't delete it).
    Try restarting InDesign.
    If that's not the solution - I highly recommend creating a new User Login on the Mac and try running the application from there.
    Aug 27, 2012 3:41 AM   in reply to Eugene Tyson
    There is no file to crash the application. There are no temporary files. I can't open the annual report to know if it is crashing the app. I can't open the application at all. I can't open a the app, let alone a previously created file. I've deleted every preference there is using all of the sugested methods. I've just reinstalled the damn thing and still it is crashes. A brand new install of inDesign from the original paid-for-with-hard-earned-money installer and still I can't get the app to open. it just bounces into Apple crash report into Adobe crash report.
    Aug 27, 2012 4:06 AM   in reply to Smoothfluid
    Update: 3 hrs later. Deleted preferences 5+ times incucing with the hidden files. Not that there were any other files hidden that were in any offending preference folders. Restarted as guest user. Lauched inDesign. Quit inDesign. Logged in as me. Deleted all preferences again for the hell of it. Restarted. And now I am 'in'. it's after 11pm. And there was no logic to the procedure. Frustrated doesn't even start describing it. Does Adobe look at the crash logs I kept sending? Does it make their product any more stable? Why today? Was it the preference deleting x 20 that fixed it? Probably not in my opinion. So what the heck is going on. Thanks Eugine for offering your advice anyway. Nice to know I wasn't shouting into the wilderness. Sorry for being a grumpy bugger
Actions
Bookmarked By (10)
