2011 Calendar Template for Indesign (CS compatible)
Jan 20, 2010 7:51 AM
  Latest reply: Eugene Tyson, Aug 28, 2013 9:28 AM
Replies 1 2 Previous Next
    Nov 10, 2011 4:16 AM   in reply to amiexx
    In my own search for such information I received the following email.
    Hope this helps. For now I myself am looking for a pocket calendar
    template. If you come across one please post/send the link/info. Thanks.
    Re: 2011 Calendar Template for Indesign (CS compatible)
    created by rob Cubbon in InDesign - View the full discussion
    Here's some more I did for 2012. Templates available in InDesign CS5,
    CS4, and .INX, therefore CS3. Also Illustrator (down to version 9) as
    well as PDFs available:
    http://robcubbon.com/free-2012-calendars-download-pdf-illustrator-inde
    sign-files/
    Jean
    Nov 10, 2011 5:43 AM   in reply to Peter Spier
    Hi, I tried the links, but none is working for the 2012. BTW I am using Photoshop CS3, is it compatible with Photoshop Indesign? What is the difference between them?
    Nov 10, 2011 5:47 AM   in reply to SmallPondPhotos
    Thanks for the link, but it is not what I am looking for. I want to add photos and then print. Something like this. http://regex.info/blog/photo-tech/calendar
    Nov 10, 2011 5:52 AM   in reply to amiexx
    There is no application called Photoshop Indesign. Adobe makes a Photo editor called Photoshop, and a page layout application called InDesign. Files editied in any version of Photoshop can be used in layouts created with any version of InDesign, but the two have nothing really in common other than a similar look to the interface and the ability to save files in some formats common to both (Like PDF) and are used for totally different tasks.
    Nov 10, 2011 5:53 AM   in reply to amiexx
    I just downloaded and opened the InDesign zip file. There is a very
    workable format for InDesign. I have used Photoshop with InDesign
    calendars to create a photo calendar for Therapeutic Riding. The zip
    file will provide good working material to create what you want.
    http://robcubbon.com/free-2012-calendars-download-pdf-illustrator-inde sign-files/
    Jean
    Nov 10, 2011 5:59 AM   in reply to Peter Spier
    I am aware of that and use images from Photoshop in my InDesign
    calendar template since I want a photo calendar. Sorry if it seemed as
    though I were making it appear as though it was ONE program.
    Jean
    Nov 10, 2011 6:10 AM   in reply to SmallPondPhotos
    Jean, thank you. I tried and it works. Sorry but I am just learning and know so little about PS. Thanx
    Nov 22, 2011 1:13 PM   in reply to Lisa Wandrei
    If anyone is still listening to this post and wants a 2012 template there are some in this blog here.
    Dec 19, 2011 6:27 AM   in reply to Lisa Wandrei
    Hi Lisa,
    Download free 2012 calender templates as PDF, Illustrator and InDesign files here. More over you can use these calendars in 2013, 2014, 2015,
    and every year to come by just shunting the numbers on in the boxes (refer video tut).
    Also find a calender a wizard here
    Hope these help.
    Dec 19, 2011 8:50 AM   in reply to Reji Samuel
    Reji,
    Nice of you to link to Rob Cubbon's templates again (he did it himself in post 32 back on Nov. 26), but they won't help anyone looking to work in anything earlier than CS3 unless they already have CS3 and every version in between to the one they want.
    Dec 19, 2011 9:09 AM   in reply to Peter Spier
    Not in InDesign; but he does supply eps, illustrator and pdf files as well...
    Dec 19, 2011 9:11 AM   in reply to Peter Spier
    Peter,
    That is true...hope Lisa might have upgraded to CS3 by this time
    Thanks.
    Jan 3, 2012 3:08 PM   in reply to Lisa Wandrei
    I'm coming in a little late to this...but I'm wondering if anyone can point me to an InDesign template compatible with CS5.5? Specifically I am looking for the Franklin Covey type planner, in the "Classic" size 5.5" x 8.5" (half page). I would like a 2012 calendar that prints each month on two pages, as well as either a day-on-two-pages spread, or a week-on-two-pages spread.
    Can anyone point me toward such an animal?
    Thank you!
    Jan 25, 2012 5:27 PM   in reply to ladyinblack1964
    Day planner template or script to do the job.
    Looking for the same animal. Found some related tips on creating it with code, but seems to be beyond me.
    Still looking
    Oct 27, 2012 2:11 AM   in reply to HBAquaman
    Hope someone can help me out. I have taken a 2012 calendar from a designer (very experienced in InDesign) and am needing to do the donkey work to set it up for next year... well, I am running really late with this because I can't figure out how the calendar is set up. I can change the date of the first of the month and everything follows, except that here seems to be extra tabs in there.
    Would someone be willing to look at one month for me, and see if they can see something I'm missing? I have left the template (one page of it) in my Dropbox folder (public) and hope someone can advise me...
    https://www.dropbox.com/sh/zaf3easvo3e5wtz/6595l_g3Cu
    Oct 27, 2012 5:16 AM   in reply to BraeNZ
    At the end of each week there are two tabs, not one. The second tab is to make the line wrap to the next week.
    If you delete a day from the first week, delete its tab as well. At that point the two-tab "end" of that week will have moved to the left. Delete one, so the day numbers after that are in their correct position again, and add a single tab at the end of that line so the next one aligns correctly. Do this for every line.
    Oct 27, 2012 5:23 AM   in reply to Peter Spier
    I've done calendars for 2013 in InDesign and Illustrator – in InDesign the date are now in the middle of the boxes rather than on the sides as in previous years. They are saved as INDD CS5 as well as IDML. The Illustrator ones are in AI and EPS and a legacy Illustrator 8. The text boxes are linked so you can convert them to subsequent years. Hope they help someone.
    http://robcubbon.com/free-2013-calendars-pdf-illustrator-indesign-phot oshop-files-download/
    Oct 27, 2012 11:01 AM   in reply to [Jongware]
    Thanks so much - that's exactly what happens but I thought it was something I was doing wrong! Much appreciated.
    Dec 11, 2012 7:25 AM   in reply to rob Cubbon
    Is there anyone with CS4. If so, can you produce an INX of the IMDL calendar here http://robcubbon.com/free-downloads/2013-Calendar-12-pages.idml
    Lots of people are asking me for this calendar compatible with CS3 and I want to link to it here:
    Dec 11, 2012 7:29 AM   in reply to rob Cubbon
    I'll take care of it...
    Dec 12, 2012 6:51 AM   in reply to Peter Spier
    Thank Peter, the INX is downloadable on that article now so I have 2013 calendars for people with InDesign CS6, 5.5, 5, 4 and 3!
    Aug 28, 2013 8:25 AM   in reply to rob Cubbon
    Aug 28, 2013 8:32 AM   in reply to rob Cubbon
    Typo on your site - should say "IDML" not "INDL"
    Aug 28, 2013 8:44 AM   in reply to rob Cubbon
    Interestingly the 2014 Calendar is repeated every +11 and +6 years
    So go ahead and change the year to
    2014+11 = 2025
    2025+ 6 = 2031
    2031+11 = 2042
    and so on
    Same with 2013 and 2011 calendars
    2012 calendars are repeated every 28 years!
    So if you have calendars already made for those years - you can reuse them in about 11 years time
    Aug 28, 2013 9:19 AM   in reply to Eugene Tyson
    Thank you. Corrected now.
    Aug 28, 2013 9:23 AM   in reply to Eugene Tyson
    Interesting. I didn't know about those strange number of years between repeated years.
    Actually, you can use my calendars for every year as the dates are in linked text frames and you just have to shunt them all along by typing in new ones or deleting them. You do have to go round and do a bit of cleaning up on the grayed out dates but they are quite recyclable!
    Aug 28, 2013 9:28 AM   in reply to rob Cubbon
    Indeed - I haven't downloaded your calendars.
    I quite like making my own with my own style etc. - it's a good learning curve I think.
    I always recommend people make their own - but whatever floats peoples boats.
1 2 Previous Next
Actions
