I am considering getting the Sony HDR-CX700V camcorder and was wondering if elements can import the 1010/60p files? Anyone know?
Premiere Elements should interface beautifully with this camcorder -- if you shoot in FX or FH mode 1920x1080 60i.
Premiere Elements can not edit 1920x1080 in 60p or 24p.
AVCHD can also demand a pretty heavy duty computer. We usually recommend a quad core or i7 processsor for best performance.
Steve, couldn't you use the 1280x720, 60p AVCHD preset to edit 1920x1080 60p if you don't mind scaling down. Your 1920x1080 will be scaled to the 1280x720 frame size. I know it can be done with PAL 1080/50p.
One thing I noticed about transitions. If you are in a 60p project, the default transition length of 30 frames is only one-half second. So if you want 1 second transitions by default, you should change transition length in preferences to 60 frames.
VDOSurfer, no, I don't think it's a bug. Adobe has loosened the requirements for what has to have a red line over it. If frame rate were different or the pixel aspect ratio were different, or the codec were different, then you would have a red line for sure.
I can't test the smoothness because my computer is slow to begin with. I can't play back anything smoothly in Premiere Elements that's 1920x1080, even if it's rendered.
Elements has been able to import 1080p60 H264 video as far back as Premiere Elements 7.
Although an editing-preset explicitly for 1080p50/60 video would be the optimal solution, you can get by with using the "DSLR 1080p25/30 (1920x1080p 25fps or 30fps)" preset.
The native-resolution won't be disturbed. And contrary to the selected framerate, all frames of the video are preserved on output. (At least, this was true for Premiere Elements 7/8/9 ... I haven't tested this yet in Version 10.)
The tricky part is sharing/exporting the video @ 1080p50/60. Since Elements doesn't officially support AVCHD 2.0, you can't select 1080p60 from any built-in sharing preset. The only options are to create your own presets from the (2) codecs that support 1080p60 export within Elements:
(1) Share -> Computer -> Windows Media Video
(This will create a Windows Media Video file...fine if you just want to watch on your PC.)
(Since there's no builtin preset for 1080p60, you need to go to 'advanced options' and edit the fields yourself.)
(2) Share -> "Mobile Phones and Players" -> "iPod and iPhone"
(This will create an MPEG-4 file with H264-video and AAC-audio, should be compatible with multiple-platforms and media set-top boxes.)
Then click on "Advanced Properties", and manually change these settings:
Level: 4.2
Profile: High
Frame Rate [fps] = 59.94 (yes, that's the correct rate for NTSC)
Frame Width 1920
Frame Height 1080
TV Standard NTSC
Bitrate settings
Bitrate Encoding: CBR (VBR has never worked correctly for me)
Bitrate [Mbps] : 28Mbps (lower number takes up less space, higher number has better quality)
Select Key Frame Distance
Key frame Distance: 30 frames (higher number takes up less space, lower number has better random access)
1080p24 is available. To export, I think you can also use Share -> Computer -> MPEG and choose one of the HDTV presets; and modify it. Change the "Level" field to High (not High 1440) and see that 60 fps is shown in the dropdown. Change the resolution to 1920x1080, and the dropdown resets to 30 max. But 720p @ 60 should be close to what you want.
As others have already stated, 1080p60 video is not officially supported by Premiere Elements 10 (PRE10.)
You can still import the 1080p60 files and do your editing just fine. But there's no way to export the finished product in the same AVCHD2 format (1080p60), i.e. you can't get them back onto the camcorder. (If you're just editing and sharing on a PC, then perhaps this isn't important to you.)
Anyway, I created a user-patch that adds a 1920x1080p60 editing-mode. Of course, since PRE10 wasn't designed/tested for 1080p60 video, there is no guarantee of reliability/usability. The hack doesn't add AVCHD2 export -- but you can save your projects as an MPEG-4 1080p60 file. (A sufficiently fast PC will read it fine, but few camcorders recognize MP4 files.)
If you're interested in trying the user-patch for 1080p60 editing, you can download the PRE10 trial-edition for free, then install the patch and see if it works for you. Link to the tips-thread is here: http://forums.adobe.com/message/4021810#
More discussion in http://forums.adobe.com/thread/1033992
