jcfrei
textSnapshot highlighting disappears
Nov 14, 2011 5:05 AM
Tags: #as3 #actionscript3 #highlight #textsnapshot #greensock #loadermax
hi guys,
been trying to solve this problem all over the internet and am now turning to you:
the problem is that the setselected only works for a fraction of a second (if at all) and then the highlighting of the text disappears.
I don't know if this might have to do with loadermax deleting its content prematurely, but I've set autoDispose = false
any help is appreciated
thanks in advance
CODE:
package {
          import flash.display.MovieClip;
          import flash.display.Stage;
          //import fl.controls.Button;
          import flash.display.SimpleButton;
          // javascript call
          import flash.external.ExternalInterface;
          import flash.text.TextField;
          import fl.motion.MotionEvent;
          import flash.display.DisplayObject;
          import flash.events.MouseEvent;
          import fl.containers.ScrollPane;
          import fl.events.ScrollEvent;
          //important for scrollpane events
          import flash.events.Event;
          import flash.text.TextSnapshot;
          import flash.display.Loader;
          import flash.net.URLRequest;
          import flash.display.Sprite;
          //cursors n' ****
          import flash.ui.Mouse;
          //debugging
          import flash.utils.describeType;
          import flash.system.LoaderContext;
          import flash.system.ApplicationDomain;
          import flash.errors.IOError;
          import flash.events.IOErrorEvent;
          import flash.display.LoaderInfo;
          //timer
          import flash.events.TimerEvent;
          import flash.utils.Timer;
          import flash.utils.*;
          importing libraries:
          Edit > Preferences > ActionScript > ActionScript 3.0 Settings > Source path
          make sure to set path to parent of com folder or whatever
          import com.greensock.*;
          import com.greensock.loading.*;
          import com.greensock.events.LoaderEvent;
          import com.greensock.loading.display.*;
          import flash.geom.Rectangle;
          import flash.display.IBitmapDrawable;
          In order to use the line this.addChild(border) your class has to be a display container. movieclip and sprite are the most common to use.
          dont forget renaming the class here!
          public class expViewer10 extends MovieClip {
                     var mc2:MovieClip;
                     var nextPageButton:SimpleButton;
                     var prevPageButton:SimpleButton;
                     var jsButton:SimpleButton
                     var searchButton:SimpleButton;
                    var firstX:int = 0;
                    var firstY:int = 0;
                    var touchDown:Boolean = false;
                    var startPos:int = 0;
                    var textPos:int = 0; // aka endPos
                    var oldStartPos:int = 0;
                    var oldTextPos:int = 0; // aka endPos
                    var currentlySelecting:Boolean = false;
                    var currentText:String = "";
                    var newSelection:Boolean = false;
                    var snapshotTrigger:Boolean = false;
                    // colors
                    var preSelectionColor:Number = 0xDDAB00;
                    var selectionColor:Number = 0xFFEF00;
                     // array of arrays with [0] one selection
                    //                              [0][0] id [0][1] startPos ...[2] endPos [3] text
                    var selectionsArray:Array = new Array();
                    var theRectangle:DisplayObject;
                    var markCounter:TextField;
                    //mcScrollBar.setScrollProperties(1, 1, 4 );
                    // need to be outside of function
                    // initialize on enterframe
                    //var snapTextArray:Array = new Array();
                    var allSWFLoaded:Boolean = false;
                    var avoidJumpingMarker:int = 0;
                    var mc:MovieClip  = new MovieClip();;
                              //addChild(mc);
                              //addChild(container); // just gotta add containes to stage?
                    var myLoader:Loader = new Loader();                     // create a new instance of the Loader class
                    var url:URLRequest = new URLRequest("tmp1.swf"); // in this case both SWFs are in the same folder
                    var bob:Boolean = false;
                    var captureButton:SimpleButton;
                    var markUpButton:SimpleButton;
                     // hack, just initialize once
                    var dummySprite:Sprite  = new Sprite();
                               //var scrollPane:ScrollPane = scrollPaneOnStage;
                    var scrollPane:ScrollPane;
                    var libMC:MovieClip;
                    var loader:Loader;
                    var fLoader:forcibleLoader;
                    var queue:LoaderMax;
                    var markUpQueue:LoaderMax;
                    var loaderArray:Array;
                    var mcArray:Array;
                    var mcArrayTest:Array = new Array();
                    var offSetArray:Array;
                    var currentClip:int;
                    var snapText:TextSnapshot;
                    var snapTextArrayOffset:Array = new Array();
                    var inter:int = 0;
                    var noPages:int = 0;
                    var pagesLoaded = 0;
                    var justAMovieClip:MovieClip;
                    // renanme this as well!
                    public function expViewer10() {
                              // wait till this class has been added to the stage!
                              this.addEventListener(Event.ADDED_TO_STAGE, attachButtonsNStuff);
                              // dont use this, button should be there already
                              //addChild(nextPageButton);
                              //attachButtonsNStuff();
                    private function attachButtonsNStuff(evt:Event):void {
                              //scrollPane = new ScrollPane();
                              //addChild(scrollPane);
                              // constructor code
                              queue = new LoaderMax({name:"mainQueue", onProgress:progressHandler, onComplete:checkHandler, onError:onError});
                              //this.addEventListener(Event.ENTER_FRAME, onEnterFrame);
                              //MovieClip(root).gotoAndStop(1);
                              mc.gotoAndStop(1);
                              loadPages();
                    private function progressHandler(event:LoaderEvent):void {
                              //trace("progress: " + event.target.progress);
                    private function onError(event:LoaderEvent) {
                              // trace("error occured with " + event.target + ": " + event.text);
                    private function checkHandler(event:LoaderEvent):void {
                                        displayPages();
                                        MovieClip(root).addChild(mc);
                                        //mcArray[0].textSnapshot.setSelected( 4, 300, true );
                                        //queue.getContent( ("tmp1") ).rawContent.textSnapshot.setSelected( 4, 300, true );
                              setTimeout ( function ( libMC:MovieClip ) : void {
                                                            try {
                         libMC.textSnapshot.setSelectColor( 0xFF0000 );
                         libMC.textSnapshot.setSelected( 100, 200, true );
                                                            } catch (error:Error) {
        trace(error.message);
                                                            } finally {
        trace("tada");
                     5000,
                     mcArray[0]
                    private function loadPages():void {
                              try{
                                        noPages = 12;
                                        for (var i:int = 0 ; i < noPages ; i++){
                                                  queue.append( new SWFLoader("tmp"+(i+1)+".swf", {name:"tmp"+(i+1), container:mc, estimatedBytes:70000, autoPlay:false, autoDispose:false}) );
                                        queue.load();
                                         // statements
                                         //ExternalInterface.call("window.alert(\"load err: "+error.message+"\")");
                              } finally {
                                         // statements
                    private function displayPages():void {
                                        //trace('1');
                                        mcArray = new Array();
                                        offSetArray = new Array();
                                        var fromTop:Number = 0;
                                        var totalChars:int = 0;
                                        //ExternalInterface.call("window.alert(\"length err: "+loaderArray.length.toString()+"\")");
                                        for (var i:int=0 ; i < 12 ; i++) {
                                                  //var tempmc:MovieClip =
                                                  //justAMovieClip  = MovieClip(queue.getContent( ("tmp"+(i+1)) ).rawContent);
                                                  mcArray[i] = queue.getContent( ("tmp"+(i+1)) ).rawContent;
                                                  var rect:Rectangle = mcArray[i].getRect(this);
                                                  //trace(inter++);
                                                  //mc.addChild(mcArray[i]);
                                                  mcArray[i].gotoAndStop(1);
                                                  mc.getChildAt(i).y = fromTop;
                                                  offSetArray.push(fromTop);
                                                  fromTop += rect.height + 10; // margin - put on top
                                                  totalChars += mcArray[i].textSnapshot.charCount;
                                                  //ExternalInterface.call("window.alert(\"tot chars: "+totalChars+"\")");
                                                  snapTextArrayOffset.push(totalChars);
    Nov 14, 2011 7:51 AM   in reply to jcfrei
    Never use anonymous functions - they are evil. Fix that and see if it remedies the issue.
