Introducing: Insert Page Numbers
Nov 14, 2011 1:17 AM
Tags: #javascript #artboards #ui #insert_page_numbers
Hi all, about three weeks ago a user asked about something like this, I thought it was a good idea to have it scripted.
Have a use for it? Let me know if there are questions, bugs...
#target illustrator
// script.name = UI_insertPageNumbers.jsx; // works with CS4 & CS5
// script description = Inserts page numbers (or any other text) to all artboards in the active document;
// script.required = at least one open document
// script.parent = CarlosCanto // 11/14/11;
// script.elegant = false;
// Notes: The script creates a new layer (Page Numbers) then adds a text frame per Artboard that act as footer or header text.
//                     Its primary function is to insert Page Numbers, but it could be used to insert any other kind of information.
if (app.documents.length > 0) // continue if there's at leat one document open
                    // start building User Interface
                    var win = new Window("dialog","MTools - Insert Page Numbers");
                    var panelMargins = win.add("panel", undefined, "Margins");
                    var lblMargins = panelMargins.add("statictext",undefined,"How far from the edge:");
                    var txtMargins = panelMargins.add("edittext",undefined, 0.25);
                    var lblUnits = panelMargins.add("statictext",undefined,"inches");
                    var panelLocation = win.add("panel", undefined, "Location");
                    var radTop = panelLocation.add("radiobutton",undefined,"Top");
                    var radBottom = panelLocation.add("radiobutton",undefined, "Bottom");
                    var panelAlignment = win.add("panel", undefined, "Alignment");
                    var radLeft = panelAlignment.add("radiobutton",undefined,"Left");
                    var radCenter = panelAlignment.add("radiobutton",undefined, "Center");
                    var radRight = panelAlignment.add("radiobutton",undefined, "Right");
                    var panelFooter = win.add("panel", undefined, "Text to insert");
                    var grpPages = panelFooter.add("group");
                    var btnPage = grpPages.add("button",undefined,"Insert Page");
                    var btnPages = grpPages.add("button",undefined,"Insert Pages");
                    var txtFooter = panelFooter.add("edittext",undefined, "[Type text to insert here]");
                    var btnOk = win.add("button", undefined, "Ok");
                    radRight.value = radBottom.value = true;
                    win.alignChildren = panelFooter.alignChildren = "fill";
                    panelMargins.spacing = 3;
                    panelMargins.orientation = panelLocation.orientation = panelAlignment.orientation = "row";
                    win.helpTip = "Coded by CarlosCanto";
                    btnPage.helpTip = "Adds *page* keyword, it represents a single page";
                    btnPages.helpTip = "Adds *pages* keyword, it represents total number of pages";
                    txtFooter.helpTip = "Type \r\t'Page *page* of *pages*' \rto get \r\t'Page 1 of 3' \rfor example";
                                                            btnOk.onClick = function(){
        doSomething(); // call main function
        win.close(); // close when done
                                                            btnPage.onClick = function(){
        footer("*page*");
                                                            btnPages.onClick = function(){
        footer("*pages*");
                                                            win.center();
                                                            win.show();
                    function footer (page) //
                                        txtFooter.text = txtFooter.text + page;
                    function doSomething()
                                        //alert("I'm doing something");
                                        var idoc = app.activeDocument;
                                        var ilayer = idoc.layers.add();
                                        ilayer.name = "Page Numbers";
                                        var pages = idoc.artboards.length; // number of artboards
                                        var footerPages = (txtFooter.text).replace("*pages*",pages); // replace the "*pages*" keyword with the actual number fo pages (artboards)
                                        var margins = Number(txtMargins.text)*72; // get margins in points
                                        //$.writeln(margins);
                                        for (i = 0; i<idoc.artboards.length; i++) // loop thru all artboards, and add input text from UI
                                                            footerPage = footerPages.replace("*page*",i+1); // replace "*page*" keyword with the actual page Number
                                                            var itext = ilayer.textFrames.add();
                                                            itext.contents = footerPage; //"page 1 of 1";
                                                            var fontSize = itext.textRange.characterAttributes.size;
                                                            var activeAB = idoc.artboards[i];
                                                            var iartBounds = activeAB.artboardRect;
                                                            var ableft = iartBounds[0]+margins;
                                                            var abtop = iartBounds[1]-margins;
                                                            var abright = iartBounds[2]-margins;
                                                            var abbottom = iartBounds[3]+margins+fontSize;
                                                            var abcenter = ableft+(abright-ableft)/2;
                                                            if (radRight.value == true)
        //var msg = "right";
        itext.left = abright;
        itext.textRange.paragraphAttributes.justification = Justification.RIGHT;
                                                            else if (radCenter.value == true)
        //var msg = "center";
        itext.left = abcenter;
        itext.textRange.paragraphAttributes.justification = Justification.CENTER;
                                                            else
        //var msg = "Left";
        itext.left = ableft;
        itext.textRange.paragraphAttributes.justification = Justification.LEFT;
                                                            if (radTop.value == true)
        var msg = "top";
        itext.top = abtop;
                                                            else
        var msg = "bottom";
        itext.top = abbottom;
                                                  } // end for loop thru all artboards
                              } // end function doSomething();
 else
        alert ("there's no open documents");
    Nov 14, 2011 2:39 AM   in reply to CarlosCanto
    I can't believe it. Works just great.
    I don't susally do page layouts in Illustrator, but to number a set of logo proposals to send to the client this will come handy as well. Thanks so much.
    Nov 14, 2011 11:23 AM   in reply to CarlosCanto
    Do you mind if I send the link for this thread to someone at Adobe?
    Nov 14, 2011 12:24 PM   in reply to CarlosCanto
    Hey Carlos
    How do I use the script?
    I did not notice a download link to where the script is located.
    Paal Joachim
    Nov 14, 2011 12:52 PM   in reply to Paal Joachim
    Paal,
    All you do is open Applescript or Javascript, copy Carlos' text and paste it into your new script file. Save that in CS5's Scripts folder or wherever you want. When using the script you go to the file menu - Scripts - Other Scripts and navigate to your new script and viola!
    Hope this helps
    Jeff
    Nov 14, 2011 1:02 PM   in reply to Jeff Dafoe
    Thanks Jeff!
    I also received a reply from Carlos:
    "Hi Paal, the script is the text in colors below the image, copy starting from "#target illustrator" all the way down to the last closing bracket "}", then open the ESTK or any text editor, paste it there and save it with a sugested name "UI_insertPageNumbers.jsx" or any other name. Make sure you save it with a "JSX" extension. Save it in you default "scripts" folder and it will show in the Illustrator "File->Scripts" menu, next time you restart illustrator."
    I tested this out and here are some of my findings:
    I pasted the code into the default TextEdit mac text editor. Format -> Make Plain Text. Saved it as a .jsx file.
    Placed the file into Adobe Illustrator CS5 -> Scripting.
    Reopened Illustrator. Opened a file (you need to open a file first). Looked in the File -> Scripts (it was not visible) -> Other Scripts and found the file.
    A dialog box opens and you can test out how it works.
    To get page numbers remove the text in the box and click Insert Page.
    A follow up to this wonderful script.
    What about changing the font and size of the page numbers?
    Thank you for the script Carlos! Hopefully Adobe can purchase it from you and add to to the next version.
    Nov 14, 2011 1:06 PM   in reply to Paal Joachim
    Copy the above text. Open a text editor which can save a plain text file (or the Adobe ESTK [ExtendScript ToolKit]) and paste the text. Save it as a plain text file with a .jsx file extension. Move the file to Applications/Adobe Illustrator CS4 or CS5/Presets/en_US/Scripts and restart your AI app. This is an ExtendScript file and will not work in the AppleScript editor.
    Nov 14, 2011 1:38 PM   in reply to Paal Joachim
    Perhaps Carlos can create a default paragraph style -- or lets the user select an existing one -- and apply that?
    (Gosh Illy's Paragraph Style dialog is clunky. What's with that, they *still* Do Not Talk to InDesign's developers?)
    Nov 14, 2011 2:31 PM   in reply to Paal Joachim
    You cn also go the the Utilities Folder in the Application Folder and use the Adobe Utilties>Extended Script Tool to complie the script by pasting ther as well and do a save as the .jsx is the dfault so not much thinking is required.
    On the PC I am not sure where the Adobe Utilities Folder is located.
    Here is a screenshot of the script utilitis UI
    Nov 14, 2011 3:23 PM   in reply to CarlosCanto
    It actually uses the default character style (at least in my test).
    Nov 15, 2011 4:30 AM   in reply to CarlosCanto
    Paragraph always takes precedence in AI. (Which is backwards compared to Indesign).
    Honestly, due to limitations of both Character and Paragraph styles in Illustrator I'd strongly reccommend not including them. Once a style in Illustrator is set, there's absolutely no way to break the link to the style. Better to not have a style than a style you can't strip from the text in my opinion.
    Nov 16, 2011 2:59 PM   in reply to CarlosCanto
    Well it's certainly about time the programmer teams stop fighting and get their heads together to produce a coherent "suite" then!
    Feb 24, 2014 9:47 PM   in reply to CarlosCanto
    Thank you so much, saved me lots of time!
Bookmarked By (1)
