Exit Code: 6 - I can' install Indesign and get the following error mssages.
Nov 13, 2011 11:15 PM
Tags: #indesign #code #6 #exit
It is part of Creative Suite 5.5 Premium
I have uninstalled many times and re-installed - to no evail.
Could I have a hardware problem? Any help wold be apreciated
-------------------------------------- Summary --------------------------------------
- 0 fatal error(s), 2 error(s), 13 warning(s)
WARNING: DW065: Display requirements not met for {60E59A6C-7399-495A-B85C-C829F4E59602}
WARNING: DW065: Display requirements not met for {857CC5F0-040E-1016-A173-D55ADD80C260}
WARNING: DW065: Display requirements not met for {50509A36-0291-1016-9CCF-FC05E9E55550}
WARNING: DW065: Display requirements not met for {92D5E8D4-01C8-1016-BBA8-F308D6BFCAC5}
WARNING: DW065: Display requirements not met for {C041EC47-0253-1016-891E-E5DE4AB922FC}
WARNING: DW031: Payload:{2EBE92C3-F9D8-48B5-A32B-04FA5D1709FA} Adobe XMP Panels CS5 3.0.0.0 has been updated and has been selected for repair. The patch {42774483-D33C-46F7-8B20-FD0B1A3DAC25} Adobe XMP Panels CS5_3.1_AdobeXMPPanelsAll 3.1.0.0 will be uninstalled now.
WARNING: DW031: Payload:{3F023875-4A52-4605-9DB6-A88D4A813E8D} Camera Profiles Installer 6.0.0.0 has been updated and has been selected for repair. The patch {A189C479-C7CD-4E08-8CCF-D999B68C0C71} Camera Profiles Installer_6.3_AdobeCameraRawProfile6.0All 6.3.0.0 will be uninstalled now.
WARNING: DW031: Payload:{37AB3C65-E02C-4DCF-B0E0-4C2E253D8FA3} Photoshop Camera Raw 6.0.0.0 has been updated and has been selected for repair. The patch {FD58D99B-9927-4226-8E00-959A4F76BD89} Photoshop Camera Raw_6.3_AdobeCameraRaw6.0All 6.3.0.0 will be uninstalled now.
----------- Payload: {75506BF3-0597-1016-8D09-EFDCD9BFC7FB} Adobe InDesign CS5.5 Common Base Files 7.5.0.0 -----------
WARNING: Failed to update the csu inventory for {75506BF3-0597-1016-8D09-EFDCD9BFC7FB} Adobe InDesign CS5.5 Common Base Files 7.5.0.0 return values 12:114
----------- Payload: {CBBBB5DB-8EF3-40D7-A9FE-5A69100C1EED} Adobe ReviewPanel CS5.5 3.0.0.0 -----------
WARNING: Failed to update the csu inventory for {CBBBB5DB-8EF3-40D7-A9FE-5A69100C1EED} Adobe ReviewPanel CS5.5 3.0.0.0 return values 12:114
ERROR: DW050: The following payload errors were found during install:
ERROR: DW050:  - AdobeHelp: Install failed
    Nov 14, 2011 12:03 AM   in reply to bundybear64
    What more needs saying? Your screen resolution is too small.
    Mylenium
    Nov 14, 2011 6:46 AM   in reply to bundybear64
    Hook up an external monitor.
    Bob
  • Sharad Saxena
    Apr 30, 2010
    Nov 16, 2011 4:20 AM   in reply to bundybear64
    Try uninstalling 'Adobe Community Help' explicitly using Control Panel and then run the installer again.
    See if it allows you to run the installer successfully.
  • Sharad Saxena
    Apr 30, 2010
    Nov 16, 2011 10:13 PM   in reply to bundybear64
    Fine. Thanks for the update.
