Bit of a newbie to CS5, having a slight problem: How do you rotate a video in the source monitor window? I've tried a number of different methods to no avail..
Cheers.
The way Pr is set up is that you see your unaltered video in the Source Monitor. Any editing, including transforms and effects, is done in the timeline and the result appears in the Program Monitor.
Pr is a non-destructive editor; your source files are never altered in any way. The only way to make your edits in Pr permanent is to export the timeline to a new file.
That said, if you would like the Source Monitor to have more functionality, then please file a request here:
Adobe - Feature Request/Bug Report Form
-Jeff
NB: Personal and antagonistic comments have been removed from this thread.
Since you're new to Premiere Pro, you'd likely benefit from working your way through the basic learning materials. There are suggestions for resources for learning Premiere Pro here.
Thanks for all the reply's, I've rotated the video's as advised.
I'm just curious as to why there isn't an option to rotate in the source window. I've rotated three video's today & it's taken around two and a half hours to export them, the funtionailty is obviously there to rotate so why not give the option? Given the popularity of camera phone films I'd imagine that this is a fairly common occurence, this just seems to be a painfully slow way of rectifiying it. I come from an audio background, this is my first year using video editing software, I suppose I'm just used to being able to manipulate anything.
I'm learning CS5 at Uni, but anymore info is much appreciated. I'll look through the learning resources.
Thanks again.
Because NLEs just aren't designed that way.
You can work around this by adding the original clip to a sequence, flipping it, then loading that sequence into the Source Monitor. Add the parts you want to a new sequence.
That explains why there's a bit of confusion. Most audio editors immediately affect the original file.
Pr and most other video editing programs store editing operations and commands in the project file, and apply those operations only when you *export*. So when you save the file in a DAW, you actually overwrite the original audio file. When you save your Pr project, you're only saving the list of commands. You have to *export* to get a file on your hard drive that contains the processed video. It is a separate file from the original video file, and that original file remains unchanged.
If it helps, think of the Source Monitor as a video player, much like Windows Media Player. In general, you don't edit or alter the video that you're watching in WMP. Ditto for the video in the Source Monitor.
-Jeff
