Using the AIR 3.0 overlay and exporting to iOS from CS5.5. All is well (super cool actually) however the drop shadow filter is failing to work. Is fine if I publish as swf or projector.
Any tips?
Thnaks,
Dave
CODE
__________
import flash.net.SharedObject;
import flash.filters.DropShadowFilter;
var path = MovieClip(this.root).main;
var gap:Number = 20;
var hostName:String = "theHost";
var username:String;
var fadeBackAmount:Number = .4;
var myFont = new ExpoDFont();
var myFormat:TextFormat = new TextFormat();
myFormat.size = 15;
myFormat.align = TextFormatAlign.CENTER;
myFormat.bold = true;
myFormat.font = myFont.fontName;
doneBut.addEventListener(MouseEvent.CLICK, finishedEditing);
/*saveBut.addEventListener(MouseEvent.CLICK, saveIt);
clearBut.addEventListener(MouseEvent.CLICK, clearIt);
loadBut.addEventListener(MouseEvent.CLICK, loadIt);
saveBut.buttonMode = true;
clearBut.buttonMode = true;
loadBut.buttonMode = true;*/
var dropShadow:DropShadowFilter = new DropShadowFilter();
dropShadow.distance = 0;
dropShadow.angle = 45;
dropShadow.color = 0x333333;
dropShadow.alpha = 1;
dropShadow.blurX = 10;
dropShadow.blurY = 10;
dropShadow.strength = 2;
dropShadow.quality = 15;
dropShadow.inner = false;
dropShadow.knockout = false;
dropShadow.hideObject = false;
makeThumbs();
function makeThumbs() {
for (var i:uint=0; i<path.pagesFlow1.length; i++) {
var th = new MovieClip();
var bitmap:Bitmap = new Bitmap();
var mc = new(path.pagesFlow1[i]);
var bData:BitmapData = new BitmapData(1024,768);
th.tBmap = bitmap;
bData.draw( mc );
bitmap.bitmapData = bData;
bitmap.filters = new Array(dropShadow);
th.addChild(bitmap);
th.scaleX = .1;
th.scaleY = th.scaleX;
th.x = th.width * i + gap * i;
th.buttonMode = true;
th.name = getQualifiedClassName((path.pagesFlow1[i]));
var myText:TextField = new TextField();
myText.defaultTextFormat = myFormat;
myText.text = th.name;
myText.selectable = false;
myText.mouseEnabled = false;
myText.wordWrap = true;
myText.textColor = 0xCCCCCC;
//myText.scaleX = 1;
//myText.scaleY = myText.scaleX;
myText.width = th.width;
myText.height = 40;
myText.x = th.width * i + gap * i;
myText.y = th.y + th.height / 4;
addChild(th);
addChild(myText);
th.addEventListener(MouseEvent.CLICK,doThumbClick);
if (isThumbExcluded(th)) {
bitmap.alpha = fadeBackAmount;
path.excludePages.push(th.name);
} else {
bitmap.alpha = 1;
//test to see if thumb is already excluded
function isThumbExcluded(t) {
var mySo:SharedObject = SharedObject.getLocal(hostName);
for (var prop in mySo.data.soExcludedArray) {
if (mySo.data.soExcludedArray[prop] == t.name) {
//trace(" mySo.data.soExcludedArray[prop] "+mySo.data.soExcludedArray[prop]);
return true;
function doThumbClick(e:MouseEvent) {
//trace(e.currentTarget.name);
//if already excluded, let it back in else exclude it
if (isThumbExcluded(e.currentTarget)) {
//trace("e.currentTarget "+e.currentTarget.name);
e.currentTarget.tBmap.alpha = 1;
//e.currentTarget.isExcluded = false;
spliceExcluded(e.currentTarget);
} else {
e.currentTarget.tBmap.alpha = fadeBackAmount;
//e.currentTarget.isExcluded = true;
path.excludePages.push(e.currentTarget.name);
saveIt();
function spliceExcluded(t) {
if (path.excludePages[i] == t.name) {
//trace("zapped "+path.excludePages[i]);
path.excludePages.splice(i,1);
function finishedEditing(e:Event):void {
hideMenu();
MovieClip(this.parent).menu_mc.visible = false;
function hideMenu() {
this.visible = false;
path.menu.visible = false;
///////SharedOpject Helpers
function saveIt() {
var theExcluded:Array = path.excludePages;
//trace("theExcluded "+theExcluded);
mySo.data.soExcludedArray = theExcluded;
trace("set: " + mySo.data.soExcludedArray);// theExcluded
//readout.appendText("set: " + mySo.data.soExcludedArray +"\n");
function clearIt(e:MouseEvent) {
mySo.clear();
function loadIt(e:MouseEvent) {
//trace(mySo.data.soExcludedArray);// yourUsername
trace(prop+": "+mySo.data.soExcludedArray[prop]);
trace("path.excludePages[prop] "+path.excludePages[prop]);
//readout.appendText(mySo.data.soExcludedArray[prop] +"\n");
function SharedObject_clear() {
mySo.clear();
}//trace("cleared: " + mySo.data.soExcludedArray);// undefined
