Hi, I'm dealing with two ANE, one for and one for AdMob and one for Vibration (the example of Adobe) if I enable both, one of them stops working (Vibration) if tested separately functioning properly. According to the debugger does not find correspondence in native code. I tried to add the SWC in several ways: (Librery, Included External library and library) but I can not make applications run more than one ANE ... What I can do?
Hi:
Which is the platform you are targetting?
the name of Initializer and Finalizer methods(Mentioned in extension.xml) of ANE has to be different for all the native extensions that an application uses.
You can verify the values by extracting extension.xml from .ANE (You can rename it to .zip and extract it)
Library has to be external always(Mention the swc as external library)
Hi:
mmmm, the Initializer and Finalizer methods are not different... give me five minute to test.
I'm working on windows, but ANE it's for iOS
yeah!! it's RUN!!!!
thank you!
I had this same problem
In my extension native library written in xcode, I had the following functions:
void ContextInitializer(...)
void ContextFinalizer(...)
void ExtInitalizer(...)
void ExtFinalizer(...)
I had to rename all 4 of these functions to something unique because just changing the last 2 only gave me a "ld: duplicate symbol _ContextFinalizer" compiler error in ADT. However, once I renamed all 4, updated my extensions.xml to point to the new names, compiled it, both extensions came to life without any problems.
http://lilili87222.github.com/admob-for-flash/
user can show all type of banner ad and full screen(interstitial advertising) ad of admob
user can show landscope and portrait advertising in actionscript 3 mobile application
user can set postion of ad
easy to use
