dishman99
No sign of Flash Player after install
Oct 4, 2011 9:42 PM
#with #not #black #flash #browser #windows #screen #7 #system #player #does #64bit #work #any #operating
I have tried to uninstall Flash Player (using the Adobe uninstall program, deleting Flash directories and rebooting) and install it again and when I use any webpage with flash I do not see the flash player. Flash does not work with any browser. Youtube does not work, in Firefox I get a black screen. If I do the https:// with Youtube it does work. When I go to the http://www.adobe.com/software/flash/about/ page, I see nothing. When I check the add-on managers I see the plugin in Firefox and extension in IE. My understanding is that Flash is built in to Chrome, so I do not understand how it could not work. I don't see Gloval settings panels at macromedia.
Operating System: WIndows 7 64bit
Browsers: IE 9.0 not 64 bit, Firefox 6.02, Google Chrome
Flash Player: Shockwave Flash 11.0.1.152 (flashplayer_11_ax_debug_32bit.exe)
Virus Protection: CA Security Center 7.0.0.279
I have tried some of the troubleshooting including going into the settings in IE checking for Active X Filtering, checking the flash settings in control panel, turned off my virus protection and firewall etc.
    Oct 5, 2011 9:46 PM
    I was having the same problem using Internet Explorer—try the same with Firefox if you can and this is how I solved it. This worked for me—it may not work for you.
    First go to http://get.adobe.com/flashplayer/ and install Adobe Flash Player for your computer.
    Click to open Internet Explorer.
    1. Click the Tools button , and then click Manage add-ons.
    2. Under Add-on Types, click Toolbars and Extensions.
    3. Under Show,
      • To display a complete list of the add-ons on your computer, click “All add-ons” on the left bottom under “Show”.
        Under “Name” go to “Adobe Systems Incorporation” select “Shockwave Flash Object” right click on “Disabled” and click on “Enabled”
        Also make sure “Shockwave ActiveX” is also “Enabled:
    4. When you're finished, click Close.
    marv70
    Community Member
    Oct 5, 2011 10:22 PM
    What files do you have in folder C:\Windows\syswow64\Macromed\Flash?
    Can you list the contents of file FlashInstall.log in that folder?
    Is there any reason why you use the debug version of Flash Player?  If you do not debug Flash content, you better download the standard version from http://forums.adobe.com/thread/909550
    Community Member
    Oct 12, 2011 9:56 AM
    This worked for me—I hope it will work for you, but there is no guarantees that it will work for you. I am old and almost blind and know very little about this stuff, but this worked for me.
    I have 32bit computer and you have a 64bit—maybe that is why it does not work with your computer??? I hope an Adobe support will help you soon.
    There seems to be a bug in the installing of the new Adobe Flash Player 11 that leaves this add on (
    “Shockwave Flash Object”) disabled. The result is that when you need it for video content—you get the message to install Adobe Flash Player again, even if you know that you just installed it and it said successfully. After I enabled (“Shockwave Flash Object”) - Flash player works fine.
    This what I did to enable (
    “Shockwave Flash Object”)First go to http://get.adobe.com/flashplayer/ and install Adobe Flash Player for your computer.Click to open Internet Explorer.
    3. Under Show,
        Also make sure “Shockwave ActiveX” is also “Enabled":
    Community Member
    Oct 12, 2011 10:17 PM
    Go to http://forums.adobe.com/thread/909550 and download
    • the 64-bit uninstaller
    • both 64-bit installers
    then close all browser windows and run the downloaded uninstaller, followed by the installers.
    Does it work now?  If not, please list again all files you have in the install folder, and the contents of FlashInstall.log
    Community Member
    Oct 22, 2011 8:21 AM
    I have the same problem.
    Configuration:
    Browsers: Firefox 3.6.23
    Flash Player: Shockwave Flash 11.0.1.152 debugger
    I need debugger for development, using Flash Builder 4.5.
    What I did:
    Uninstalled then installed  FP 11.0.1.152 debugger.
    Browsers won't show any flash content.
    When I right click onthe flahs area I see its usign FP 11.0.1.152.
    C:\Windows\SysWOW64\Macromed\Flash\
    =O====== M/11.0.1.152 2011-10-22+14-04-25.558 ========
    0000 [I] 00000010 "C:\Users\tqj764\Install\Flash Player 11\flashplayer_11_ax_debug_32bit.exe"
    0001 [W] 00001036 Software\Macromedia\FlashPlayer\SafeVersions/11.0 2
    0002 [W] 00001036 Software\Macromedia\FlashPlayerActiveX/PlayerPath 2
    0003 [W] 00001036 Software\Macromedia\FlashPlayer\SafeVersions/11.0 2
    0004 [W] 00001036 Software\Macromedia\FlashPlayerActiveX/PlayerPath 2
    0005 [I] 00000020 C:\Windows\SysWOW64\FlashPlayerCPLApp.cpl
    0006 [W] 00001037 SOFTWARE\Microsoft\Windows\CurrentVersion\Uninstall\Adobe Flash Player ActiveX/ 2
    0007 [I] 00000013 C:\Windows\SysWOW64\Macromed\Flash\Flash11c.ocx
    0008 [I] 00000015 C:\Windows\SysWOW64\Macromed\Flash\FlashUtil11c_ActiveX.exe
    0009 [I] 00000016 C:\Windows\SysWOW64\Macromed\Flash\FlashUtil11c_ActiveX.dll
    0010 [I] 00000019 C:\Windows\SysWOW64\FlashPlayerCPLApp.cpl
    =X====== M/11.0.1.152 2011-10-22+14-04-30.124 ========
    =O====== M/11.0.1.152 2011-10-22+14-04-32.974 ========
    0000 [I] 00000010 "C:\Users\tqj764\Install\Flash Player 11\flashplayer_11_plugin_debug_32bit.exe"
    0001 [W] 00001036 Software\Macromedia\FlashPlayerPlugin/Version 2
    0002 [W] 00001036 Software\Macromedia\FlashPlayerPlugin/PlayerPath 2
    0003 [W] 00001036 Software\Macromedia\FlashPlayerPlugin/Version 2
    0004 [W] 00001036 Software\Macromedia\FlashPlayerPlugin/PlayerPath 2
    0006 [W] 00001037 SOFTWARE\MozillaPlugins\@adobe.com/FlashPlayer/ 2
    0007 [W] 00001037 SOFTWARE\Microsoft\Windows\CurrentVersion\Uninstall\Adobe Flash Player Plugin/ 2
    0008 [W] 00001036 Software\Mozilla\Mozilla Firefox\extensions/Plugins 2
    0009 [W] 00001036 Software\Opera Software/Last CommandLine 2
    0010 [W] 00001036 Software\Opera Software/Last CommandLine 2
    0011 [W] 00001036 Software\Opera Software/Plugin Path 2
    0012 [W] 00001036 Software\Opera Software/Plugin Path 2
    0013 [I] 00000014 C:\Windows\SysWOW64\Macromed\Flash\NPSWF32.dll
    0014 [I] 00000015 C:\Windows\SysWOW64\Macromed\Flash\FlashUtil11c_Plugin.exe
    0015 [I] 00000017 C:\Windows\SysWOW64\Macromed\Flash
    0016 [I] 00000019 C:\Windows\SysWOW64\FlashPlayerCPLApp.cpl
    0017 [W] 00001024 C:\Windows\SysWOW64\FlashPlayerCPLApp.cpl 183
    =X====== M/11.0.1.152 2011-10-22+14-04-36.964 ========
    Nov 16, 2011 3:30 PM
    From what I've noticed, the uninstaller tool (11.0r1 in my case) doesn't seem to do a good job at removing Flash Player (11.1.102.55 in my case).
    I tried many alterations and it seems only to happen when removing the product via Adobe's tool. I didn't get this problem using Add & Remove Programs...
    All I had to do is run the installer (install_flash_player_11_active_x_32bit.msi in my case) and you'll have the option to repair or remove.. choose remove.
Legend
  • Correct Answers - 10 points
  • Helpful Answers - 5 points
