I'm trying to invoke a web service using 'Invoke Web Service' Operation. Its works for 8 out of 10 times. Sometime it stalled with "Conneciton Reset' error.
When retry this stalled action from AdminUI, its works fine.
Can someone advise on this issue?
I have attached the error log for reference.
Nith
Total Likes
Hi Nith,
I'm currently struggling with the same problem, did you manage to solve it?
Romain.
Total Likes
If you attempt to retry the stalled component through adminui, it will work. Am i correct?
If so, you can test the following approach.
1. drag a blank component (e.g a decision point)
2. connect a line between the exception of the Web Service Invoke operation to the decision point.
3. Choose java.io.IOException from the eeception drop down.
4. again connect the decision point back to the web service invoke component. (i mean a looping)
This approach was working fine with me.
Please see the attached image shows my routing.
PS: After a couple of days, I tested without looping and it seems to be working. So I removed the loop now.
Nith
Total Likes
and the workflow is attached here..
Nith
Total Likes
Thanks for the answer Nith!
Regrettably, are not it a possible solution for my problem, because there is no error catched by Livecycle. Sniffing TCP packets shows the connection reset, but there is no crash in Livecycle.
I keep on digging.
Total Likes
Try trapping the java.net.SocketTimeoutException off of the Invoke Web Service operation.
You may also want to trap java.lang.Exception.
I have had success intercepting these errors, incrementing an error loop counter and returning to the Invoke Web Service operation.
I don't encounter the errors often, but usually the first attempt resets the connection, and the second try works.
Good Luck.
Mark
Hi Mark,
I'll be grateful if you can show me how did to solve this problem.
Coz i have a lot of process who are stuck on calling web service
Kind regards
Naoufal
Total Likes
