Strobe Not Working In Firefox
Nov 17, 2011 3:15 PM
Hi All
Working on developing a site using Strobe to play videos.
It works fine in new versions of Safari, Chrome, and even IE8+.
For some reason it throws "--org.strobemediaplayback.triggerHandler" as a popup error and then "We are unable to connect to the content you've requested..." inside the player itself.\
This is in Firefox 7.
Any thoughs on why this might be?
Matthew
    Nov 18, 2011 1:40 AM   in reply to matthewspencer1
    Hi Matthew,
    please raise a bug at https://bugs.adobe.com/jira/browse/FM and provide the stream example, the code you're using to load the player that you are using  (if it's not standard) and some other details that could help me replicate your case.
    S.
    Nov 18, 2011 8:43 AM   in reply to matthewspencer1
    Hi Matthew,
    I replicated your problem using the data from the bug report.
    On Firefox I get an answer from the server that's 9.7 kB long instead of 3.3MB.
    I suspect either an asset problem or a strange behavior form Flash Player.
    Before I forward the bug to the Flash Player team, can you verify that the issue appears with another asset on the same server? Maybe you could change the encoding parameters?
    S.
    Nov 21, 2011 1:04 AM   in reply to matthewspencer1
    Hi Matthew,
    I mean the encoding of the video file (ex: h264 with default parameters in ffmpeg).
    Did you configure the web server is a special way? Like chunked response, etc?
    S.
