I am working on a standalone video presentation, will play directely from PC. So no worries about streaming or file size.
Right now i am using WMV9 with unconstrained bitrate, decoder on auto, avg bitrate maxed out at 10,000
I am still getting some compression artifacts on playback, even when using clean hi res tif files (no jpgs)
Any tips on getting the best quality from PP5.5 ?
thanks,
dr
Is this going to be on one computer, or will it be sent out to others?
The only limitation with Lagarith, or UT, will be that the CODEC's will need to be installed on each computer, but they ARE free. With one computer, it's not an issue, as the installer to Encode, will also include the Decode too.
Good luck,
Hunt
Great, as that certainly makes the delivery much, much easier. Thanks for that clarification.
With that scheme, you can use the best "lossless" CODEC, and only need to have it on that one, dedicated machine.
Both Lagarith and UT get high marks. Some users like one vs the other, and that is probably based on the exact Source Footage, they are working with. As both are free, do not hesitate to try each with your Footage, and pick the one that you like best.
Good luck,
Hunt
