AO, doesn't switching the gpu accelerator option kinda point to that it could be a card issue? maybe try another card.
H2o, not sure what OS ur running, but I went to Nvidas site and for windows 7 there's a 10/4/11 release date driver.
Not saying it will fix it, but everyone, make sure you have the most updated driver.
This has been one of the more difficult issues for us to reproduce in Adobe. I know you have been able to reproduce it on regular basis, but that wasn't the case for us. With help of some of the folks on this thread who sent us their project, were were finally able to reproduce this issue on one of the machines we have in our Lab. Now that we are finally able to reproduce this problem we have written a bug on it and submitted it to our development team and set this as high priority. I know a few different developers have been working on this trying to find the root of the problem. Once we have a fix, we'll test it internally and then if it looks like it's fixed for us, we'll invite some of you to our pre-release (beta) program to check it out as well. If you would like to help test this fixed once it goes on our pre-release program, please send me a private message (using this forum's message sending program).
Richard, if you're use to mac then you'll probably like a mac pro, especially if a couple grand difference in price vs the learning curve of selecting the parts and knowledge to build the same equipt pc. With mine I used the gigabit UD5 board, but thats like thier first gen board for the i7. If anything go to TomsHardware.com to look up system build specs and weigh ur options.
Hi, is there any update on this issue? i currently have 2 neer identical machines one has this problem and the other does not the only difference in the 2 is one has 24gb of ram and the other has 48gb other than that there both dual quads with quadro 4000 graphics cards they both had no problem on cs5 but as soon as they were both upgraded to 5.5 the machine with 24gb of ram started to have the issue. im willing to do various tests to get this problem fixed as im the I.T technician in an animation company and this problem is proving pretty hard to tackle but the worse part is its putting are editor behind because he can't leave a cue of things to render as he can almost guarantee that at least one will drop off I've just disabled his hardware acceleration and ill report back later with my findings. any help would be greatly appreciated!!
Cheers Jason.
Here is the latest from Adobe and my response:
Hi Doug,
I'm writing to let you know that we're closing Case 182349424. The specific behavior that you've reported has been logged as a bug. There is a workaround, which is to disable GPU hardware acceleration in Premiere before rendering. We are investigating the root cause of this issue, but we do not provide specific notification when/if updates may become available to address the issue.
The members of the engineering team responsible for investigating this issue have been in contact via the forum (http://forums.adobe.com/thread/856263?tstart=0) and are providing additional information when available. There is nothing further that we can do from the tech support side, so as a matter of procedure we're closing the case. If I receive any new specific information on this issue, I'll send along an update.
Best regards,
Chad Baker
Tier 3 Technical Support, Adobe Pro Video
Chad,
Your solution is not a very good one. It is like being a runner on a track team and you have a broken leg. Rendering the amount of projects I render with the MPE disabled is too time consuming and as a business owner, cuts into all the other tasks I have to manage. If you look at the forum, I’m the one who started it back on May 24th, 2011 and I am not the only one having these issues. How long is this going to take? I will give you every file I have to help resolve this issue.
My confidence is very low with Adobe. Maybe I should switch to Final Cut Pro.
Very frustrated customer,
Doug Ferguson
Neverends Productions
I don't have any information on when this issue might be resolved, nor could I comment publicly about future releases if I did have that information. The best information that I have is included in Nariman's post above (http://forums.adobe.com/message/3991802#3991802).
Please see Nariman's response above if you would be interested in helping us investigate a fix.
I understand your objection to the workaround provided, and would gladly provide a better solution if one were available, but that's the extent of what we can do on the Support side at present.
This is still assigned to our development to fix and has a very high priority assigned to it. If you are interested in testing this before this gets released to public, you can join AME pre-release program. Send me a private message via forum and provide your name, email and phone. I'll send you an invitation to join the pre-release program and you can then test it once we have a fix available.
I am having this exact same issue with CS4. I have an Intel I7, 24GB of Ram, GeForce 9800 GT. I cannot Encode with AME nor Encore. The encode just freezes., not always at the same spot, NO error messages. I have litterally been trying to solve this for weeks. From the looks of this post there is not much hope.
I am tring to encode 720p 59.94fps. I have read other posts about this problem showing up in CS5.5 but I am here to tell you I am experienceing the exact same symptoms in CS4.2.1
PLEASE if ther is any solution send me the info.
I was under the impression that Encore uses AME to do the encoding. I am trying to go from HD 720p to a standard definition DVD. Jeff Bellune had a tutorial involving a two step encoding to get the best results. I have done other projects quite successfully with his method and the suddenly, in the middle of a wedding project that I am doing, this failure to encode popped up and it has been a nightmare ever since. I do not know what if anything changed on my system.
How do you encode from PPro without using AME?
To encode straight out of PP just click "export" rather than "queue" in the Export Settings Window bottom right.
I stress to every body to make sure and go to your cards manufacturer site and ensure you have the latest driver, that means if you installed it a week ago, there still might be an updated driver. This is very important if you're using Nvidia GTX cards in my own personal experience.
and to the guy encoding for 20 hours, I'd not even bother using ame for that anyway, ame really only helps if you're queuing up lots of clips over night or something.
I have the same problem here guys on 2 machines built to exact adobe specs with the GTX 5800 cards. encoder just freezes randomly for no apparent reason.
My workaround for months, has been to shut down premiere and all the background processes via task manager, then open the old AME version 5 and load the sequences directly on it.
It takes forever to load a sequence that way, but at least it works without switching the MPE off.
Hi I have had the same problem I found I got rid of it by changing the graphics card and loading the latest drivers. I think its a grahics memory issue. My propblems started when I did a load of updates and even after rolling everything back it still did not go away. I know some find not queueuing the render gets them through with out it stopping.
Mike it was the same for me, I bought a new GTX 570 from the manufacturer, loaded the drivers off the disk, and had this problem happening consistantly over and over again with sequences from 7 mins and up. I'd thought I had the latest drivers because it was a new card. I went to the manufacturer's site and saw there was a driver that was released like in the last month. After I installed the "actual latest drivers", I never had the problem again.
GTX 580 current drivers - constant failures still - I think I have a
sign-up for pre-release software kicking around here - I mean to try 'their
new fix'
AME's 'queue' database is a super weak (is it text file???) and when you
kill AME it loses control of what's been done and what's not - on reboot
the queue will often reflect things to do that it has already done - if you
add this problem to that problem running with the preference "output:
increment output file name if file with same name exists you get like 2^32
copies of the same file. And unfortunately the AME presets do not allow
you to influence the left side of the output file name. Basically you have
to use something else (Post-It notes perhaps) to control your Adobe
Creative Suite workflow - cause it's broken right here in AME kids.
BTW Great sheep sound when you turn off the "increment output file name"
Maybe it's worth mentioning my GTX 570 video card brand EVGA. I think in this thread we've established that it's a card or cuda issue, we've also established for a lot of people it's a VGA driver issue. For people wanting to reload their whole system, or dealing with rendering on a regular basis, I think the next step could be purchasing another Cuda card.
Maybe Miketrobo, you list your exact brand of card too.
GTX 580 by Gigabyte, with the latest drivers, still freezes AME. This does not happen with the old version 5 AME.
I have Premiere pro version 5 as well loaded in the PC which comes with AME version 5 , when I'm ready to render, I close Premiere 5.5, load the AME 5 manually and import the timelines from Premiere 5.5 to render, at list this way I can use the MPE and render quick. The downside to this is that it takes a long time to import the timelines from Premiere 5, once that's done, it works fast.
Any news about it, epecially from those who joined the pre-release team?
Just yesterday I had to encode my current project, took 7 hours. But then, 7 hours is definately a night render job, so at least I am in no hurry...
____________
OK, just tried something else - I removed my Blackmagic HD card since I had a gut feeling that it hangs somewhere there. Upon the first try with 6 Videos it worked well. Becoming euphoric, I tried it a second time and it failed at a somewhat significant position: right where the clip ends and the closing animation starts. Most of the footage for the video came from a P2-Card (DVCPROHD), while the closing animation is either a Quicktime using the Animation Codec or an uncompressed AVI. For a change, I even got an error Message:
Message was edited by: zikade
_______________________
3rd try:
I have arrived at a complete new level of puzzlement. A sequence which AME did render well on Windows get some interesting effects on my Mac like this:
This part should look a bit different, trust me on that. The source is an ProRes422 movie, for some reason it's 960x720 with aspect ration of 1,333. So I created a new sequence having just this part in it, chose ProRes 422, 1280x720 square, replaced it in the sequence and it rendered just fine. Which is kind of odd, since the sequence has the settings 960x720 aspect ratio 1,333. Whats even funnier, on Windows I do not have that problem. There it gets interpreted correctly. All of that, and Playback in PPro is just fine, regardless of the OS or the spatial resolution of just that clip. Somebody can enlighten me why that is happening? I do guess that AME does have some problems with different Codecs and/or resolutions in a sequence - even more if both is different - which it shouldn't..
I am considering upgrading from CS5 Web to CS5.5 Web since there is a 30% discount until the end of the month. Would this problem many of you are having be a reason to avoid this upgrade, in your opinion? Or is this just a small bump in the whole package? I don't own Premiere Pro so I can't use the work around some of you are using.
I use it only occasionally, to add small flash videos to my client's website. I had a disaster in May trying to encode a one hour flash movie for the website (it truncated at 30 min) and I don't want to have a repeat of this for the next shareholder meeting video. I have been following this thread with interest but since I only use AME occasionally I don't know how to handle any future problems. My husband is an IT admin and sets up my workstation. He has assured me everything is up-to-date.
