Rename files using Contribute
Sep 15, 2006 8:45 AM
I had a user today publish a new file named "indexi.asp" He intended to
name it "index.asp" but did not realize his mistake until too late.
So we now have a file called indexi.asp on the server. Is there any way
to rename it using Contribute?
The file uses repeating regions, so we can not merely copy the content
and paste it into a new file of the same template.
I can perform the rename in the back end, and they can via a direct
(network share) connection to the folder, but I'd rather encourage them
to do everything from Contribute if possible.
Thanks.
-Ben
    Sep 15, 2006 9:50 AM   in reply to Newsgroup_User
    I don't think Contribute can do a rename. You could start an edit on the mis-named page in Contribute and therefore get it to download a copy of the page to the local working directory, Save for later and exit. Then copy the page on the local drive, renaming it index(New).asp, go back into Contribute, publish the new page and cancel the draft of the mis-named one. Not complex, but hardly simple either.
    Jan 31, 2008 1:53 PM   in reply to Newsgroup_User
    Hey Arun,
    Is the contribute CS3 has rename option?
    Kim
