ID CS4 - PDF library failed to initialize
Nov 21, 2011 12:29 PM
Out of the blue I am no longer able to open any InDesign files.  When I try to open a file, I get the following error: "PDF library failed to initialize."  After which the app freezes.
I trashed the preferences (InDesign Defaults & SavedData) as recommended by a previous forum answer.
Restared the computer 3 times and also shut it down and turned it back on.
Any suggestions?
    Nov 21, 2011 12:34 PM   in reply to Detweiler Design
    Sadly, it sounds like it's time to think about reinstalling, or if you have one, restoring from a backup. If on Windows, though, I'd try a System Restore first.
    Nov 21, 2011 12:50 PM   in reply to Detweiler Design
    If you don't delete the folders by erasing the  prefs during an uninstall operation, they should survive, but it's a good idea to back them up anyway. They're all in one or the other of the folders you looked in to find the two files you already replaced in your profile/library.
    Nov 21, 2011 1:07 PM   in reply to Detweiler Design
    I'm a Windows uyser, so know nothing about MacKeeper, but I'm always suspicioous of newly installed software when things suddenly change for the worse. Did ID work at all after installing it?
    Nov 21, 2011 1:28 PM   in reply to Detweiler Design
    Doesn't sound like a MacKeeper issue.
    Nov 21, 2011 1:41 PM   in reply to Detweiler Design
    Replace with what? If you have a backup copy, absolutely. You can also try doing a "repair" install over the existing installation using the Installer without uninstalling first.
    Nov 21, 2011 2:03 PM   in reply to Detweiler Design
    Perfect.
    Nov 27, 2011 6:20 PM   in reply to Detweiler Design
    I had the same problem after I installed MacKeeper! Restore from Time Machine worked for me too, thank you!
    Dec 5, 2011 4:57 AM   in reply to Elise__A
    Thanks for this thread.
    I have just intalled Makkeeper, and have exactly the same problem.  Iwill resore from TimeMachine, and let you know if there is still a problem.
    Dec 10, 2011 11:27 AM   in reply to Detweiler Design
    I'm having the exact same issue with InDesign. I get the "PDF Library fails to initialize" error message, which renders ID completely inoperable. I, too, installed and ran MacKeeper just days ago. I think it might be the Duplicate File remover in MacKeeper that's running afoul.
    Eager to try restoring ID from my TimeMachine back up. By the way, MacKeeper says they no nothing about this problem.
    Dec 10, 2011 12:03 PM   in reply to GfxGeek
    I don't think it is the duplicate File Remover, because I did not run that system.
    Dec 10, 2011 2:52 PM   in reply to ralfellis
    Thanks for the update, ralfellis. Any thoughts on what MacKeeper tool might be the culprit?
    Dec 10, 2011 2:54 PM   in reply to GfxGeek
    Successfully restored my entire InDesign folder from my TimeMachine backup. InDesign is working normal again! Thanks for everyone's help.
    Dec 10, 2011 3:02 PM   in reply to Peter Spier
    IMHO, MacKeeper seems to be the one commonality among everyone here. Fortunately, if you can restore from back up using TimeMachine (Mac users), the problem appears to be recoverable.
    Dec 11, 2011 1:41 AM   in reply to GfxGeek
    I only ran the first three sections  -  the disk management tools, and the anti-virus tool (but that only found two things which did not sound important).
    Undoubtedly this is a Makeeper problem.  I have run ID for years and years, and the day after I run Makeeper it fails.  Its a Makeeper problem.
    Dec 16, 2011 10:56 AM   in reply to Detweiler Design
    I have MacKeeper also and have experienced the same error: "PDF library failed to initialze" I uninstalled/reinstalled ID and the problem went away. I chatted with MacKeeper online and directed them to this thread and they said they were not aware of an issue, but to me, at least for now MacKeeper seems to be the culprit.
    They suggested to omit ADOBE files from the Duplicates Finder feature.
    Jan 7, 2012 1:50 AM   in reply to Detweiler Design
    This is an old thread, but fyi, I'm using CS3 - used MacKeeper and now have problems. MacKeeper helped with my overall crashing problems, but I've had problems with various programs since then such as Indesign, and my printer driver for my Epson 3880 stopped working. I'll re-install InDesign and hope that works. (Haven't upgraded the CS suite as I mainly use Photoshop these days.)
    Jan 16, 2012 4:56 PM   in reply to Detweiler Design
    I'm also having the same issue after running MacKeeper… I've tried trashing the preferences but to no avail. Anybody have any suggestions? Just like above, mine is right out of the blue as well.
  • John Hawkinson
    Jun 25, 2009
    Jan 16, 2012 11:58 PM   in reply to jsdslomo
    Get rid of MacKeeper and reinstall InDesign.
    Jan 17, 2012 8:36 AM   in reply to John Hawkinson
    thanks John, I will give it a shot…
    Feb 22, 2012 2:02 PM   in reply to Detweiler Design
    I, too, am having the same problem!! I'm very glad I found this thread but super irritated with the MacKeeper people. I /think/ the only thing I did was use Duplicate Finder, but whatever, InDesign and Photoshop are messed.
    Trying the Time Machine route now, fingers crossed. After that, am contacting MacKeeper - maybe one day they'll pay attention to this.
    ***UPDATE: Thank you, Time Machine!!!! You've saved my arse once again. Not the best solution, but it's a solution - now I have my ID back again!
    Message was edited by: wendyhig
  • John Hawkinson
    Jun 25, 2009
    Feb 22, 2012 2:41 PM   in reply to wendyhig
    Wendy: I'm sorry to say this, but I think, essentially, MacKeeper is a scam. Not an illicit one, but not a credible product.
    Feb 22, 2012 2:52 PM   in reply to John Hawkinson
    I'm wondering.... I did google it and found decent reviews, nearly everywhere. Their chat/customer service is really pretty good. But I can't have my software (with which I make my meager living) corrupted, so....
    Apr 4, 2012 2:31 PM   in reply to Detweiler Design
    Yes, I agree, MacKeeper is the culprit, though I couldn't say which part of it is evil.
    I installed it yesterday and have had no end of trouble now. I uninstalled it, wrote to MacKeeper, and am reinstalling InDesign CS4. It's a shame, because as others here have mentioned, it gets great reviews online. Maybe those who have not yet experienced problems are those who only use their Macs as glorified entertainment systems and not for their livelihoods.
    Apr 5, 2012 6:45 AM   in reply to fontmaven
    The "livelihood" part is the worst one... I am still plagued by inability to name layers and various other "small" problems that Time Machine has /not/ been able to fix - really don't want to reinstall, but probably the most sensible route to recovery.
    If anyone has discovered what, exactly, it is that MacKeeper messes up (which files/prefs/plists, etc), I would be very interested in knowing!
    Apr 5, 2012 6:55 AM   in reply to Wendy H
    Hi, Wendy,
    I was told by the third support guy I spoke with that they don't recommend using TimeMachine to restore Adobe products. So there you go.
    The reinstall was the way I went, because TimeMachine left out libraries and other things needed to get InDesign back to where I had it. I lost one and a half work days because of MacKeeper, and when I wrote to complain after uninstalling it, they refunded my payment quickly and cheerfully. But I got up at 5am this morning so I could get this straightened out with Adobe.
    Apr 5, 2012 6:57 AM   in reply to fontmaven
    Hi Becky,
    Same with me - I requested a refund, it was made within 5 minutes, quite happily. Maybe their lawyer suggested that route?
    It's hard to find a window during projects for the reinstall, I find - but of course it's the only way to guarantee all is well again. If only, if only....
    Good luck!
    Wendy
    Apr 7, 2012 9:13 AM   in reply to Detweiler Design
    YES! Same problem - installed MacKeeper and now can't run out files on pdf because of this initialize message - help!
    Apr 7, 2012 10:01 AM   in reply to fontmaven
    FYI... This from MacKeeper chat: Shari, as far as I can see - last version of Indesign is added to blacklist, so CS 5, and CS5.5 is safe. About 4 version, I can not tell for sure. In our case I recommend you not to use fast cleanup, because needed caches and languages packs removed, and indesigned stops working. All other tools of mackeeper will work fine, and won`t interfere.
    Apr 7, 2012 11:37 AM   in reply to Shari Stauch
    Well, for me, this was not only ID CS4 that was affected, but also PS CS4, both of them. Now having problems with psds somehow being saved as flat files, not useful at all.
    It would be super nice if MacKeeper posted this clearly somewhere, rather than having all of us victims contact them after the fact, since full resolution of any of these problems has not been consistent.
  • John Hawkinson
    Jun 25, 2009
    Apr 7, 2012 1:51 PM   in reply to Shari Stauch
    I hope this is not too repitious, but:
    MacKeeper is not a good product.
    You should not use it.
    MacKeeper conveys no material benefit to you. It doesn't make your system run better, or keep your system running smoothly. It causes serious problems for many pieces of software and for many people. You are not getting anything for your money other than aggravation.
    Please don't use MacKeeper, and please don't promote it to others.
    If there's something in particular you think you need from MacKeeper, I'm sure we could suggest other ways to get what you're looking for. If it is a warm fuzzy feeling, MacKeeper is certainly not that. (You might think it is, but you would be wrong.) The whole category of "optimization tools" is essentially security theatre; there is no ongoing maintenance required to "keep your system clean" or "keep your system running smoothly." There are a few reputable tools out there that can fix occasional corruption problems, but they are rarely necessary and the best ones are not commercial software. (E.g., Onyx is one such program; you definitely don't need it, but it can sometimes help with very strange problems.)
    (Of course, it would be better to ask on a Mac software forum, rather than here, but I'm sure we can help you out.)
    Apr 19, 2012 12:26 PM   in reply to John Hawkinson
    I have MacKeeper on two Macs, one running 10.6.8 and CS5. No problems whatsoever.
    I have a laptop on 10.7, MacKeeper and CS4. Problem, which is why I'm here.
    There may be a problem caused by MacKeeper and I broadly agree with John Hawkinson that other programmes do much of what MacKeeper does, etc, etc. but I think the problem must surely lie with the CS4 / MacKeeper interaction.
    Back in the day I used AppleJack, but now find myself using both OnyX and MacKeeper. As John suggests, there are other ways to get to the same place as these two programmes, but their point seems to be that they each of them are one-stop scripts that do a range of things, an automator of sorts. Many users simply never repair permissions, or need to. But others need do need to, for all sorts of reason. I'd suggest that each of the aforementioned do their thing their way and so are useful to many users who are perhaps less computer-wise as John evidently is. Many leave their machines on 24/7 and don't need to concern themselves with maintenance scripts. Some don't. And on and on.
    His point that one or both programmes conveys no material benefit is correct, but only in so far as you can accomplsh many of the operations they do by simply using the built in Disk Utility in your Mac. Or re-index Spotlight manually. You get the idea. They offer convenience, and the various claims the software makes is the usual marketing that companies do and which you ought to regard as such. And MacKeeper does have virus scanning now, and their version of Find My Mac, so some might find these aspects useful. I'd respectfully suggest that John's comments are useful, but unproven, and so perhaps ought to be read as one reads MacKeeper's claims - with both eyes open.
    And anyway, there's a separate thread on this same subject which appears to have nothing whatsoever to do with MacKeeper: http://forums.adobe.com/thread/615271 so the root seems more complex than the suggestion here.
    And no, I don't work for MacKeeper, or have any links to them at all.
