Unable to Remove plug-in using Extension Manager
Jun 17, 2011 5:06 AM
I have installed my plug-ins into InDesign CS5 using the Extension Manager CS5, the installation is successful. When I select my plug-in entry in the list of installed plug-ins and then click on the Remove button, the Extension Manager displays a progress bar and the line disappears from the list but the plug-in sits there in the Plug-Ins folder untouched!
What's going on? How do I make sure that the plug-in is removed/uninstalled? Is there a log file for errors from the Extension Manager?
Thanks a lot.
    Aug 2, 2011 12:14 AM   in reply to lfdiaz
    Which extension are you removing? Extension Manager doesn't really remove some extensions (plug-ins) if special attribute is specified in extension. This feature is used to support multi-user environment.
    Nov 21, 2011 4:51 PM   in reply to Carl Sun
    How does one remove an extension for any and all users on a system?
    Nov 21, 2011 5:09 PM   in reply to XRX_ID_user
    If you remove an ordinary extension from Extension Manager, it will be removed for all users on a system. But for InDesign extension, if plugin-manager-type="all-users" or plugin-manager-type="current-user" is specified in its mxi file, Extension Manager will not really remove it from system, instead Extension Manager adds an entry to PlugInConfig.txt of InDesign so that InDesign will not load this extension at runtime.
    Nov 29, 2011 4:35 PM   in reply to Carl Sun
    Is there a way to really remove the plugin and associated resource files, such that neither InDesign or the Extension Manager have any memory of them?  Is there a reason InDesign extensions are not 'ordinary' and don't get removed for all users?
    Nov 29, 2011 4:44 PM   in reply to XRX_ID_user
    Is your extension a mxp file or zxp file? Does it contain plugin-manager-type attribute? If No, could you please provide this extension so that I can check it?
    Nov 29, 2011 5:01 PM   in reply to Carl Sun
    It is a zxp file, and it does contain a plugin-manager-type attribute.
    Nov 29, 2011 5:05 PM   in reply to lfdiaz
    You can simply remove plugin-manager-type="all-users" and enabled-for-enabled-all="true" from the mxi file then re-create this extension.
    Nov 29, 2011 5:16 PM   in reply to XRX_ID_user
    If you are the developer of this extension, you can remove plugin-manager-type attribute, then it will be an ordinary extension and can be really removed from machine. If you cannot modify this extension, Extension Manager doesn't provide a way to really remove it, this behavior is as per requirement of InDesign team.
    Nov 30, 2011 2:31 PM   in reply to Carl Sun
    It works for me, too!
    I would ask that someone update the documentation to help future users.
    Thanks for the quick answers.
Bookmarked By (1)
