I have a problem that the Flash player runs only in Software mode in all browsers.
I have the following notebook: Dell Vostro 3350 with dual graphics (Intel HD Graphics integrated and AMD Radeon HD 6490M dedicated), the OS is Windows 7 64-bit.
The driver version that is in the device manager is the following: 8.840.7.3000 (I've made sure to have installed the latest driver from Dell)
The hardware acceleration radio button in the Flash settings is on, of course.
The funny thing is that in the Flash 11 Incubator program DirectX rendering was working properly, the problems have started since the RC version of Flash 11.
Can you help me somehow?
Many thanks,
CapKosmaty
Ok, gentlemen, problem solved; I just switched the switchable graphics method to manual and selected the radeon, and now it plays in DirectX9 mode; that's enough for me, but you might look into it though, if that's something you have influence on.
cheers!
Thanks for the heads up. I'm forwarding this along to the team responsible for 3d. What kind of content are you trying to view? Do you have any sample URL's you can give us?
Chris
I've tried different sources like Max Racer and Zombie Tycoon, but mainly I'm testing on Delta Strike: http://apps.facebook.com/playdeltastrike (the Away3D stats screen even shows in the label that it is in Software mode, so it's no subjective impression, for sure).
Thanks for the help!
CapKosmaty
Hi CapKosmaty,
Most likely your graphics driver is getting blacklisted. Any driver dated before 1/1/2009 is automatically blacklisted. If possible you can upgrade to the latest official drivers from AMD, that may fix to fallback to software. Also can you provide you dxdiag info from your machine?
Hey guys, I'm unburying this thread; I've waited a bit, hoping that an update would put my model from the blacklist, but there's no change;
Here's my dxdiag log: (could it be that Flash has problems with switchable graphics? I run different retail games, like Star Wars: The Old Republic recently, and they run perfectly on the Radeon HD 6490M)
again, I'm grateful for help!
System Information
Time of this report: 2/18/2012, 18:24:43
Machine name: CAPKOSMATY-PC
Operating System: Windows 7 Professional 64-bit (6.1, Build 7601) Service Pack 1 (7601.win7sp1_gdr.110622-1506)
Language: German (Regional Setting: German)
System Manufacturer: Dell Inc.
System Model: Vostro 3350
BIOS: BIOS Date: 09/30/11 14:00:46 Ver: 04.06.04
Processor: Intel(R) Core(TM) i7-2620M CPU @ 2.70GHz (4 CPUs), ~2.7GHz
Memory: 6144MB RAM
Available OS Memory: 6052MB RAM
Page File: 3810MB used, 8290MB available
Windows Dir: C:\windows
DirectX Version: DirectX 11
DX Setup Parameters: Not found
User DPI Setting: Using System DPI
System DPI Setting: 96 DPI (100 percent)
DWM DPI Scaling: Disabled
DxDiag Version: 6.01.7601.17514 64bit Unicode
DxDiag Notes
Display Tab 1: No problems found.
Sound Tab 1: No problems found.
Input Tab: No problems found.
DirectX Debug Levels
Direct3D: 0/4 (retail)
DirectDraw: 0/4 (retail)
DirectInput: 0/5 (retail)
DirectMusic: 0/5 (retail)
DirectPlay: 0/9 (retail)
DirectSound: 0/5 (retail)
DirectShow: 0/6 (retail)
Display Devices
Card name: Intel(R) HD Graphics Family
Manufacturer: ATI Technologies Inc.
Chip type: Intel(R) HD Graphics Family
DAC type: Internal
Device Key: Enum\PCI\VEN_8086&DEV_0126&SUBSYS_04CC1028&REV_09
Display Memory: 3329 MB
Dedicated Memory: 559 MB
Shared Memory: 2769 MB
Current Mode: 1366 x 768 (32 bit) (60Hz)
Monitor Name: PnP-Monitor (Standard)
Monitor Model: unknown
Monitor Id: AUO312C
Native Mode: 1366 x 768(p) (60.003Hz)
Output Type: Internal
Driver Name: igdumd64.dll,igd10umd64.dll,igd10umd64.dll,igdumdx32,igd10umd32,igd10umd32
Driver File Version: 8.15.0010.2361 (English)
Driver Version: 8.840.7.3000
DDI Version: 11
Driver Model: WDDM 1.1
Driver Attributes: Final Retail
Driver Date/Size: 4/10/2011 20:51:02, 8238592 bytes
WHQL Logo'd: Yes
WHQL Date Stamp:
Device Identifier: {D7B78E66-4266-11CF-A877-C624B7C2C535}
Vendor ID: 0x8086
Device ID: 0x0126
SubSys ID: 0x04CC1028
Revision ID: 0x0009
Driver Strong Name: oem21.inf:ATI.Mfg.NTamd64.6.1:iSNBM1ML_PROXY:8.840.7.3000:pci\ven_8086&dev_0126&subsys_04cc1028
Rank Of Driver: 00E60001
Video Accel: ModeMPEG2_A ModeMPEG2_C ModeWMV9_C ModeVC1_C
Deinterlace Caps: {BF752EF6-8CC4-457A-BE1B-08BD1CAEEE9F}: Format(In/Out)=(YUY2,YUY2) Frames(Prev/Fwd/Back)=(0,0,1) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY VideoProcess_AlphaBlend DeinterlaceTech_EdgeFiltering
{335AA36E-7884-43A4-9C91-7F87FAF3E37E}: Format(In/Out)=(YUY2,YUY2) Frames(Prev/Fwd/Back)=(0,0,0) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY VideoProcess_AlphaBlend DeinterlaceTech_BOBVerticalStretch
{5A54A0C9-C7EC-4BD9-8EDE-F3C75DC4393B}: Format(In/Out)=(YUY2,YUY2) Frames(Prev/Fwd/Back)=(0,0,0) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY VideoProcess_AlphaBlend
{BF752EF6-8CC4-457A-BE1B-08BD1CAEEE9F}: Format(In/Out)=(UYVY,YUY2) Frames(Prev/Fwd/Back)=(0,0,1) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY VideoProcess_AlphaBlend DeinterlaceTech_EdgeFiltering
{335AA36E-7884-43A4-9C91-7F87FAF3E37E}: Format(In/Out)=(UYVY,YUY2) Frames(Prev/Fwd/Back)=(0,0,0) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY VideoProcess_AlphaBlend DeinterlaceTech_BOBVerticalStretch
{5A54A0C9-C7EC-4BD9-8EDE-F3C75DC4393B}: Format(In/Out)=(UYVY,YUY2) Frames(Prev/Fwd/Back)=(0,0,0) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY VideoProcess_AlphaBlend
{BF752EF6-8CC4-457A-BE1B-08BD1CAEEE9F}: Format(In/Out)=(YV12,YUY2) Frames(Prev/Fwd/Back)=(0,0,1) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY VideoProcess_AlphaBlend DeinterlaceTech_EdgeFiltering
{335AA36E-7884-43A4-9C91-7F87FAF3E37E}: Format(In/Out)=(YV12,YUY2) Frames(Prev/Fwd/Back)=(0,0,0) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY VideoProcess_AlphaBlend DeinterlaceTech_BOBVerticalStretch
{5A54A0C9-C7EC-4BD9-8EDE-F3C75DC4393B}: Format(In/Out)=(YV12,YUY2) Frames(Prev/Fwd/Back)=(0,0,0) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY VideoProcess_AlphaBlend
{BF752EF6-8CC4-457A-BE1B-08BD1CAEEE9F}: Format(In/Out)=(NV12,YUY2) Frames(Prev/Fwd/Back)=(0,0,1) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY VideoProcess_AlphaBlend DeinterlaceTech_EdgeFiltering
{335AA36E-7884-43A4-9C91-7F87FAF3E37E}: Format(In/Out)=(NV12,YUY2) Frames(Prev/Fwd/Back)=(0,0,0) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY VideoProcess_AlphaBlend DeinterlaceTech_BOBVerticalStretch
{5A54A0C9-C7EC-4BD9-8EDE-F3C75DC4393B}: Format(In/Out)=(NV12,YUY2) Frames(Prev/Fwd/Back)=(0,0,0) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY VideoProcess_AlphaBlend
{BF752EF6-8CC4-457A-BE1B-08BD1CAEEE9F}: Format(In/Out)=(IMC1,YUY2) Frames(Prev/Fwd/Back)=(0,0,1) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY VideoProcess_AlphaBlend DeinterlaceTech_EdgeFiltering
{335AA36E-7884-43A4-9C91-7F87FAF3E37E}: Format(In/Out)=(IMC1,YUY2) Frames(Prev/Fwd/Back)=(0,0,0) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY VideoProcess_AlphaBlend DeinterlaceTech_BOBVerticalStretch
{5A54A0C9-C7EC-4BD9-8EDE-F3C75DC4393B}: Format(In/Out)=(IMC1,YUY2) Frames(Prev/Fwd/Back)=(0,0,0) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY VideoProcess_AlphaBlend
{BF752EF6-8CC4-457A-BE1B-08BD1CAEEE9F}: Format(In/Out)=(IMC2,YUY2) Frames(Prev/Fwd/Back)=(0,0,1) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY VideoProcess_AlphaBlend DeinterlaceTech_EdgeFiltering
{335AA36E-7884-43A4-9C91-7F87FAF3E37E}: Format(In/Out)=(IMC2,YUY2) Frames(Prev/Fwd/Back)=(0,0,0) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY VideoProcess_AlphaBlend DeinterlaceTech_BOBVerticalStretch
{5A54A0C9-C7EC-4BD9-8EDE-F3C75DC4393B}: Format(In/Out)=(IMC2,YUY2) Frames(Prev/Fwd/Back)=(0,0,0) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY VideoProcess_AlphaBlend
{BF752EF6-8CC4-457A-BE1B-08BD1CAEEE9F}: Format(In/Out)=(IMC3,YUY2) Frames(Prev/Fwd/Back)=(0,0,1) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY VideoProcess_AlphaBlend DeinterlaceTech_EdgeFiltering
{335AA36E-7884-43A4-9C91-7F87FAF3E37E}: Format(In/Out)=(IMC3,YUY2) Frames(Prev/Fwd/Back)=(0,0,0) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY VideoProcess_AlphaBlend DeinterlaceTech_BOBVerticalStretch
{5A54A0C9-C7EC-4BD9-8EDE-F3C75DC4393B}: Format(In/Out)=(IMC3,YUY2) Frames(Prev/Fwd/Back)=(0,0,0) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY VideoProcess_AlphaBlend
{BF752EF6-8CC4-457A-BE1B-08BD1CAEEE9F}: Format(In/Out)=(IMC4,YUY2) Frames(Prev/Fwd/Back)=(0,0,1) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY VideoProcess_AlphaBlend DeinterlaceTech_EdgeFiltering
{335AA36E-7884-43A4-9C91-7F87FAF3E37E}: Format(In/Out)=(IMC4,YUY2) Frames(Prev/Fwd/Back)=(0,0,0) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY VideoProcess_AlphaBlend DeinterlaceTech_BOBVerticalStretch
{5A54A0C9-C7EC-4BD9-8EDE-F3C75DC4393B}: Format(In/Out)=(IMC4,YUY2) Frames(Prev/Fwd/Back)=(0,0,0) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY VideoProcess_AlphaBlend
D3D9 Overlay: Not Supported
DXVA-HD: Not Supported
DDraw Status: Enabled
D3D Status: Enabled
AGP Status: Enabled
Sound Devices
Description: Lautsprecher (High Definition Audio-Gerät)
Default Sound Playback: Yes
Default Voice Playback: Yes
Hardware ID: HDAUDIO\FUNC_01&VEN_111D&DEV_76D1&SUBSYS_102804B2&REV_1002
Manufacturer ID: 1
Product ID: 65535
Type: WDM
Driver Name: HdAudio.sys
Driver Version: 6.01.7601.17514 (German)
WHQL Logo'd: Yes
Date and Size: 11/21/2010 04:23:47, 350208 bytes
Other Files:
Driver Provider: Microsoft
HW Accel Level: Basic
Cap Flags: 0xF1F
Min/Max Sample Rate: 100, 200000
Static/Strm HW Mix Bufs: 1, 0
Static/Strm HW 3D Bufs: 0, 0
HW Memory: 0
Voice Management: No
EAX(tm) 2.0 Listen/Src: No, No
I3DL2(tm) Listen/Src: No, No
Sensaura(tm) ZoomFX(tm): No
Sound Capture Devices
Description: Mikrofon (High Definition Audio-Gerät)
Default Sound Capture: Yes
Default Voice Capture: Yes
Cap Flags: 0x1
Format Flags: 0xFFFFF
DirectInput Devices
Device Name: Maus
Attached: 1
Controller ID: n/a
Vendor/Product ID: n/a
FF Driver: n/a
Device Name: Tastatur
Attached: 1
Controller ID: n/a
FF Driver: n/a
Device Name: Wacom Virtual Hid Driver
Attached: 1
Controller ID: 0x0
Vendor/Product ID: 0x056A, 0x1001
FF Driver: n/a
Attached: 1
Controller ID: 0x0
FF Driver: n/a
Attached: 1
Controller ID: 0x0
FF Driver: n/a
Poll w/ Interrupt: No
USB Devices
+ USB-Root-Hub
| Vendor/Product ID: 0x8086, 0x1C26
| Matching Device ID: usb\root_hub20
| Service: usbhub
| Driver: usbhub.sys, 3/25/2011 04:24:56, 343040 bytes
| Driver: usbd.sys, 3/25/2011 04:28:59, 7936 bytes
+-+ Generic USB Hub
| | Vendor/Product ID: 0x8087, 0x0024
| | Matching Device ID: usb\class_09
| | Service: usbhub
Gameport Devices
PS/2 Devices
+ Standardtastatur (PS/2)
| Matching Device ID: *pnp0303
| Service: i8042prt
| Driver: i8042prt.sys, 7/14/2009 00:19:57, 105472 bytes
| Driver: kbdclass.sys, 7/14/2009 02:48:04, 50768 bytes
+ Terminalserver-Tastaturtreiber
| Matching Device ID: root\rdp_kbd
| Upper Filters: kbdclass
| Service: TermDD
+ Dell Touchpad
| Matching Device ID: *dll04b2
| Upper Filters: SynTP
| Service: i8042prt
+ HID-konforme Maus
| Vendor/Product ID: 0x046D, 0xC05A
| Matching Device ID: hid_device_system_mouse
| Service: mouhid
| Driver: mouhid.sys, 7/14/2009 01:00:20, 31232 bytes
| Driver: mouclass.sys, 7/14/2009 02:48:27, 49216 bytes
+ Wacom Mouse
| Matching Device ID: hid\wacomvirtualhid&col03
| Upper Filters: wacommousefilter
| Service: mouhid
| Driver: wacommousefilter.sys, 10/5/2010 12:26:02, 12848 bytes
+ Terminalserver-Maustreiber
| Matching Device ID: root\rdp_mou
| Upper Filters: mouclass
| Service: TermDD
| Driver: termdd.sys, 11/21/2010 04:23:47, 63360 bytes
| Driver: sermouse.sys, 7/14/2009 01:00:20, 26624 bytes
Disk & DVD/CD-ROM Drives
Drive: C:
Free Space: 305.9 GB
Total Space: 461.8 GB
File System: NTFS
Model: WDC WD5000BPKT-75PK4T0
Drive: D:
Model: TSSTcorp DVD+-RW TS-U633J
Driver: c:\windows\system32\drivers\cdrom.sys, 6.01.7601.17514 (German), 11/21/2010 04:23:47, 147456 bytes
Drive: E:
Model: DTSoftBusCd00
System Devices
Name: Intel(R) 6 Series/C200 Series Chipset Family USB Enhanced Host Controller - 1C2D
Device ID: PCI\VEN_8086&DEV_1C2D&SUBSYS_04B21028&REV_05\3&11583659&1&D0
Driver: C:\windows\system32\drivers\usbehci.sys, 6.01.7601.17586 (English), 3/25/2011 04:29:04, 52736 bytes
Driver: C:\windows\system32\drivers\usbport.sys, 6.01.7601.17586 (German), 3/25/2011 04:29:14, 325120 bytes
Driver: C:\windows\system32\drivers\usbhub.sys, 6.01.7601.21692 (German), 3/25/2011 04:24:56, 343040 bytes
Name: Intel(R) 6 Series/C200 Series Chipset Family PCI Express Root Port 1 - 1C10
Device ID: PCI\VEN_8086&DEV_1C10&SUBSYS_04B21028&REV_B5\3&11583659&1&E0
Driver: C:\windows\system32\DRIVERS\pci.sys, 6.01.7601.17514 (German), 11/21/2010 04:23:47, 184704 bytes
Name: AMD Radeon HD 6490M
Device ID: PCI\VEN_1002&DEV_6760&SUBSYS_04CC1028&REV_00\4&2D92FC7C&0&0008
Driver: C:\windows\system32\DRIVERS\atikmdag.sys, 8.01.0001.1142 (English), 5/12/2011 11:16:38, 9319424 bytes
Driver: C:\windows\system32\DRIVERS\ati2erec.dll, 1.00.0000.0019 (English), 5/12/2011 07:15:20, 53248 bytes
Driver: C:\windows\system32\DRIVERS\atikmpag.sys, 8.14.0001.6203 (English), 5/12/2011 07:16:54, 304128 bytes
Driver: C:\windows\system32\atiumd64.dll, 7.14.0010.0825 (English), 5/12/2011 07:24:04, 5395968 bytes
Driver: C:\windows\system32\atiumd6a.dll, 8.14.0010.0303 (English), 5/12/2011 08:11:20, 3420672 bytes
Driver: C:\windows\system32\atitmm64.dll, 6.14.0011.0023 (English), 5/12/2011 07:52:38, 120320 bytes
Driver: C:\windows\system32\atiicdxx.dat, 3/1/2011 02:30:06, 233012 bytes
Driver: C:\windows\system32\amdpcom64.dll, 8.14.0010.0023 (English), 5/12/2011 07:51:30, 53760 bytes
Driver: C:\windows\system32\atimpc64.dll, 8.14.0010.0023 (English), 5/12/2011 07:51:30, 53760 bytes
Driver: C:\windows\system32\atiadlxx.dll, 6.14.0010.1054 (English), 5/12/2011 07:17:28, 361984 bytes
Driver: C:\windows\system32\atiumd6a.cap, 5/12/2011 08:08:58, 916704 bytes
Driver: C:\windows\system32\atimuixx.dll, 6.14.0010.1002 (English), 5/12/2011 07:51:56, 16384 bytes
Driver: C:\windows\system32\atiapfxx.exe, 6.14.0010.1001 (English), 5/12/2011 07:58:04, 147456 bytes
Driver: C:\windows\system32\atiapfxx.blb, 5/12/2011 07:58:38, 150136 bytes
Driver: C:\windows\system32\atiumd6v.dll, 7.14.0010.0184 (English), 5/12/2011 08:11:54, 1208320 bytes
Driver: C:\windows\system32\atiesrxx.exe, 6.14.0011.1090 (English), 5/12/2011 07:53:46, 203264 bytes
Driver: C:\windows\system32\atieclxx.exe, 6.14.0011.1090 (English), 5/12/2011 07:54:20, 480256 bytes
Driver: C:\windows\system32\atipdl64.dll, 6.14.0010.2563 (English), 5/12/2011 07:52:18, 423424 bytes
Driver: C:\windows\system32\atiedu64.dll, 6.14.0010.2514 (English), 5/12/2011 07:51:50, 59392 bytes
Driver: C:\windows\system32\ATIDEMGX.dll, 2.00.4148.39432 (German), 5/12/2011 07:54:24, 462848 bytes
Driver: C:\windows\system32\atio6axx.dll, 6.14.0010.10664 (English), 5/12/2011 08:14:20, 22623232 bytes
Driver: C:\windows\system32\aticaldd64.dll, 6.14.0010.1353 (English), 5/12/2011 08:00:06, 7467520 bytes
Driver: C:\windows\system32\aticalrt64.dll, 6.14.0010.1353 (English), 5/12/2011 08:00:28, 51200 bytes
Driver: C:\windows\system32\aticalcl64.dll, 6.14.0010.1353 (English), 5/12/2011 08:00:18, 44544 bytes
Driver: C:\windows\system32\atipblag.dat, 3/18/2011 07:05:12, 3914 bytes
Driver: C:\windows\system32\atiu9p64.dll, 8.14.0001.6203 (English), 5/12/2011 07:16:00, 38912 bytes
Driver: C:\windows\system32\atiuxp64.dll, 8.14.0001.6203 (English), 5/12/2011 07:16:12, 40448 bytes
Driver: C:\windows\system32\atig6pxx.dll, 8.14.0001.6203 (English), 5/12/2011 07:17:14, 14848 bytes
Driver: C:\windows\system32\atig6txx.dll, 8.14.0001.6203 (English), 5/12/2011 07:17:08, 39936 bytes
Driver: C:\windows\system32\atibtmon.exe, 2.00.0000.0000 (English), 5/12/2009 02:35:30, 118784 bytes
Driver: C:\windows\system32\atidxx64.dll, 8.17.0010.0348 (English), 5/12/2011 07:39:46, 5080576 bytes
Driver: C:\windows\SysWOW64\atiumdag.dll, 7.14.0010.0825 (English), 5/12/2011 07:30:04, 4246016 bytes
Driver: C:\windows\SysWOW64\atiumdva.dll, 8.14.0010.0303 (English), 5/12/2011 08:04:02, 3631104 bytes
Driver: C:\windows\SysWOW64\amdpcom32.dll, 8.14.0010.0023 (English), 5/12/2011 07:51:22, 52736 bytes
Driver: C:\windows\SysWOW64\atimpc32.dll, 8.14.0010.0023 (English), 5/12/2011 07:51:22, 52736 bytes
Driver: C:\windows\SysWOW64\atiadlxy.dll, 6.14.0010.1054 (English), 5/12/2011 07:17:22, 258048 bytes
Driver: C:\windows\SysWOW64\atiumdva.cap, 5/12/2011 08:03:36, 916704 bytes
Driver: C:\windows\SysWOW64\atiumdmv.dll, 7.14.0010.0184 (English), 5/12/2011 08:11:30, 1912832 bytes
Driver: C:\windows\SysWOW64\atipdlxx.dll, 6.14.0010.2563 (English), 5/12/2011 07:52:12, 356352 bytes
Driver: C:\windows\SysWOW64\Oemdspif.dll, 6.15.0006.0006 (English), 5/12/2011 07:52:00, 278528 bytes
Driver: C:\windows\SysWOW64\ati2edxx.dll, 6.14.0010.2514 (English), 5/12/2011 07:51:46, 43520 bytes
Driver: C:\windows\SysWOW64\atioglxx.dll, 6.14.0010.10664 (English), 5/12/2011 07:53:08, 17469952 bytes
Driver: C:\windows\SysWOW64\atidxx32.dll, 8.17.0010.0348 (English), 5/12/2011 07:48:36, 4304896 bytes
Driver: C:\windows\SysWOW64\aticaldd.dll, 6.14.0010.1353 (English), 5/12/2011 07:57:04, 6098432 bytes
Driver: C:\windows\SysWOW64\aticalrt.dll, 6.14.0010.1353 (English), 5/12/2011 08:00:26, 46080 bytes
Driver: C:\windows\SysWOW64\aticalcl.dll, 6.14.0010.1353 (English), 5/12/2011 08:00:16, 44032 bytes
Driver: C:\windows\SysWOW64\atipblag.dat, 3/18/2011 07:05:12, 3914 bytes
Driver: C:\windows\SysWOW64\atiu9pag.dll, 8.14.0001.6203 (English), 5/12/2011 07:15:54, 29184 bytes
Driver: C:\windows\SysWOW64\atiuxpag.dll, 8.14.0001.6203 (English), 5/12/2011 07:16:06, 31232 bytes
Driver: C:\windows\SysWOW64\atigktxx.dll, 8.14.0001.6203 (English), 5/12/2011 07:17:00, 32768 bytes
Driver: C:\windows\SysWOW64\atiglpxx.dll, 8.14.0001.6203 (English), 5/12/2011 07:17:12, 12800 bytes
Driver: C:\windows\atiogl.xml, 1/14/2011 21:00:54, 30831 bytes
Driver: C:\windows\system32\aticfx64.dll, 8.17.0010.1072 (English), 5/12/2011 07:56:46, 788480 bytes
Driver: C:\windows\SysWOW64\aticfx32.dll, 8.17.0010.1072 (English), 5/12/2011 07:57:56, 672256 bytes
Driver: C:\windows\system32\coinst.dll, 1.00.0003.0005 (English), 5/12/2011 08:05:12, 58880 bytes
Name: Intel(R) 6 Series/C200 Series Chipset Family USB Enhanced Host Controller - 1C26
Device ID: PCI\VEN_8086&DEV_1C26&SUBSYS_04B21028&REV_05\3&11583659&1&E8
Name: Intel(R) Mobile Express Chipset SATA AHCI Controller
Device ID: PCI\VEN_8086&DEV_1C03&SUBSYS_04B21028&REV_05\3&11583659&1&FA
Driver: C:\windows\system32\DRIVERS\iaStor.sys, 10.01.0000.1008 (English), 11/7/2010 00:45:48, 438808 bytes
Name: Intel(R) 6 Series/C200 Series Chipset Family SMBus Controller - 1C22
Device ID: PCI\VEN_8086&DEV_1C22&SUBSYS_04B21028&REV_05\3&11583659&1&FB
Driver: n/a
Name: Intel(R) HD Graphics Family
Device ID: PCI\VEN_8086&DEV_0126&SUBSYS_04CC1028&REV_09\3&11583659&1&10
Driver: C:\windows\system32\DRIVERS\igdkmd64.sys, 8.15.0010.2361 (English), 4/10/2011 20:51:06, 12223936 bytes
Driver: C:\windows\system32\igdumd64.dll, 8.15.0010.2361 (English), 4/10/2011 20:51:02, 8238592 bytes
Driver: C:\windows\system32\igd10umd64.dll, 8.15.0010.2361 (English), 4/10/2011 20:37:38, 14511104 bytes
Driver: C:\windows\system32\igfxcmrt64.dll, 1.00.0000.1007 (English), 4/10/2011 19:40:40, 136704 bytes
Driver: C:\windows\system32\IccLibDll_x64.dll, 4/10/2011 19:40:40, 94208 bytes
Driver: C:\windows\system32\igkrng600.bin, 4/10/2011 20:49:08, 963116 bytes
Driver: C:\windows\system32\igcompkrng600.bin, 4/10/2011 20:49:08, 145804 bytes
Driver: C:\windows\system32\igfcg600m.bin, 4/10/2011 20:49:08, 218304 bytes
Driver: C:\windows\SysWow64\igkrng600.bin, 4/10/2011 20:49:08, 963116 bytes
Driver: C:\windows\SysWow64\igcompkrng600.bin, 4/10/2011 20:49:08, 145804 bytes
Driver: C:\windows\SysWow64\igfcg600m.bin, 4/10/2011 20:49:08, 218304 bytes
Driver: C:\windows\system32\igdde64.dll, 4/10/2011 20:48:54, 75776 bytes
Driver: C:\windows\SysWow64\igdde32.dll, 4/10/2011 20:42:48, 56832 bytes
Driver: C:\windows\system32\iglhxs64.vp, 4/10/2011 21:15:54, 17272 bytes
Driver: C:\windows\system32\iglhxo64.vp, 4/10/2011 19:40:32, 59243 bytes
Driver: C:\windows\system32\iglhxc64.vp, 4/10/2011 19:40:32, 59062 bytes
Driver: C:\windows\system32\iglhxg64.vp, 4/10/2011 19:40:34, 59174 bytes
Driver: C:\windows\system32\iglhxa64.vp, 4/10/2011 19:40:34, 1074 bytes
Driver: C:\windows\system32\iglhxa64.cpa, 4/10/2011 19:40:34, 1981696 bytes
Driver: C:\windows\system32\iglhcp64.dll, 2.00.0002.0001 (English), 4/10/2011 19:40:36, 98304 bytes
Driver: C:\windows\system32\iglhsip64.dll, 2.00.0002.0001 (English), 4/10/2011 19:40:36, 376832 bytes
Driver: C:\windows\SysWow64\igdumd32.dll, 8.15.0010.2361 (English), 4/10/2011 20:44:18, 6275072 bytes
Driver: C:\windows\SysWow64\igdumdx32.dll, 8.15.0010.2361 (English), 4/10/2011 20:41:02, 577024 bytes
Driver: C:\windows\SysWow64\igfxdv32.dll, 8.15.0010.2361 (English), 4/10/2011 20:06:44, 288768 bytes
Driver: C:\windows\SysWow64\igd10umd32.dll, 8.15.0010.2361 (English), 4/10/2011 20:31:18, 12289536 bytes
Driver: C:\windows\SysWow64\iglhcp32.dll, 2.00.0002.0001 (English), 4/10/2011 19:40:32, 98304 bytes
Driver: C:\windows\SysWow64\iglhsip32.dll, 2.00.0002.0001 (English), 4/10/2011 19:40:32, 376832 bytes
Driver: C:\windows\SysWow64\igfxcmrt32.dll, 1.00.0000.1007 (English), 4/10/2011 19:40:40, 158208 bytes
Driver: C:\windows\system32\difx64.exe, 4/10/2011 20:59:56, 179032 bytes
Driver: C:\windows\system32\hccutils.dll, 8.15.0010.2361 (English), 4/10/2011 20:12:16, 109056 bytes
Driver: C:\windows\system32\igfxsrvc.dll, 8.15.0010.2361 (English), 4/10/2011 20:12:46, 62464 bytes
Driver: C:\windows\system32\igfxsrvc.exe, 8.15.0010.2361 (English), 4/10/2011 21:00:04, 509272 bytes
Driver: C:\windows\system32\igfxpph.dll, 8.15.0010.2361 (English), 4/10/2011 20:13:08, 335872 bytes
Driver: C:\windows\system32\igfxcpl.cpl, 8.15.0010.2361 (English), 4/10/2011 20:13:36, 126976 bytes
Driver: C:\windows\system32\igfxdev.dll, 8.15.0010.2361 (English), 4/10/2011 20:12:06, 385024 bytes
Driver: C:\windows\system32\igfxdo.dll, 8.15.0010.2361 (English), 4/10/2011 20:11:24, 142336 bytes
Driver: C:\windows\system32\igfxtray.exe, 8.15.0010.2361 (English), 4/10/2011 21:00:06, 167256 bytes
Driver: C:\windows\system32\hkcmd.exe, 8.15.0010.2361 (English), 4/10/2011 20:59:58, 391512 bytes
Driver: C:\windows\system32\igfxress.dll, 8.15.0010.2361 (English), 4/10/2011 20:11:24, 9014784 bytes
Driver: C:\windows\system32\igfxpers.exe, 8.15.0010.2361 (English), 4/10/2011 21:00:02, 415064 bytes
Driver: C:\windows\system32\igfxTMM.dll, 8.15.0010.2361 (English), 4/10/2011 20:13:18, 378368 bytes
Driver: C:\windows\system32\gfxSrvc.dll, 8.15.0010.2361 (German), 4/10/2011 20:12:08, 146432 bytes
Driver: C:\windows\system32\GfxUI.exe, 8.15.0010.2361 (German), 4/10/2011 20:59:58, 4377432 bytes
Driver: C:\windows\system32\GfxUI.exe.config, 4/10/2011 20:04:00, 151 bytes
Driver: C:\windows\system32\IGFXDEVLib.dll, 1.00.0000.0000 (Invariant Language), 4/10/2011 20:12:08, 4096 bytes
Driver: C:\windows\system32\igfxext.exe, 8.15.0010.2361 (English), 4/10/2011 21:00:00, 238424 bytes
Driver: C:\windows\system32\igfxexps.dll, 8.15.0010.2361 (English), 4/10/2011 20:13:02, 28672 bytes
Driver: C:\windows\SysWow64\igfxexps32.dll, 8.15.0010.2361 (English), 4/10/2011 20:07:32, 24576 bytes
Driver: C:\windows\system32\igfxrara.lrc, 8.15.0010.2361 (English), 4/10/2011 20:13:38, 285184 bytes
Driver: C:\windows\system32\igfxrchs.lrc, 8.15.0010.2361 (English), 4/10/2011 20:13:40, 282624 bytes
Driver: C:\windows\system32\igfxrcht.lrc, 8.15.0010.2361 (English), 4/10/2011 20:13:40, 282624 bytes
Driver: C:\windows\system32\igfxrdan.lrc, 8.15.0010.2361 (English), 4/10/2011 20:13:42, 285696 bytes
Driver: C:\windows\system32\igfxrdeu.lrc, 8.15.0010.2361 (English), 4/10/2011 20:13:44, 286720 bytes
Driver: C:\windows\system32\igfxrenu.lrc, 8.15.0010.2361 (English), 4/10/2011 20:11:30, 285696 bytes
Driver: C:\windows\system32\igfxresn.lrc, 8.15.0010.2361 (English), 4/10/2011 20:13:52, 287232 bytes
Driver: C:\windows\system32\igfxrfin.lrc, 8.15.0010.2361 (English), 4/10/2011 20:13:42, 286208 bytes
Driver: C:\windows\system32\igfxrfra.lrc, 8.15.0010.2361 (English), 4/10/2011 20:13:44, 287232 bytes
Driver: C:\windows\system32\igfxrheb.lrc, 8.15.0010.2361 (English), 4/10/2011 20:13:46, 285184 bytes
Driver: C:\windows\system32\igfxrhrv.lrc, 8.15.0010.2361 (English), 4/10/2011 20:13:56, 286720 bytes
Driver: C:\windows\system32\igfxrita.lrc, 8.15.0010.2361 (English), 4/10/2011 20:13:46, 286720 bytes
Driver: C:\windows\system32\igfxrjpn.lrc, 8.15.0010.2361 (English), 4/10/2011 20:13:48, 283648 bytes
Driver: C:\windows\system32\igfxrkor.lrc, 8.15.0010.2361 (English), 4/10/2011 20:13:48, 283136 bytes
Driver: C:\windows\system32\igfxrnld.lrc, 8.15.0010.2361 (English), 4/10/2011 20:13:42, 286720 bytes
Driver: C:\windows\system32\igfxrnor.lrc, 8.15.0010.2361 (English), 4/10/2011 20:13:48, 286208 bytes
Driver: C:\windows\system32\igfxrplk.lrc, 8.15.0010.2361 (English), 4/10/2011 20:13:50, 286720 bytes
Driver: C:\windows\system32\igfxrptb.lrc, 8.15.0010.2361 (English), 4/10/2011 20:13:50, 286208 bytes
Driver: C:\windows\system32\igfxrptg.lrc, 8.15.0010.2361 (English), 4/10/2011 20:13:50, 286720 bytes
Driver: C:\windows\system32\igfxrrom.lrc, 8.15.0010.2361 (English), 4/10/2011 20:13:56, 286720 bytes
Driver: C:\windows\system32\igfxrrus.lrc, 8.15.0010.2361 (English), 4/10/2011 20:13:52, 286720 bytes
Driver: C:\windows\system32\igfxrsky.lrc, 8.15.0010.2361 (English), 4/10/2011 20:13:56, 286720 bytes
Driver: C:\windows\system32\igfxrslv.lrc, 8.15.0010.2361 (English), 4/10/2011 20:13:56, 286208 bytes
Driver: C:\windows\system32\igfxrsve.lrc, 8.15.0010.2361 (English), 4/10/2011 20:13:54, 286208 bytes
Driver: C:\windows\system32\igfxrtha.lrc, 8.15.0010.2361 (English), 4/10/2011 20:13:54, 285696 bytes
Driver: C:\windows\system32\igfxrcsy.lrc, 8.15.0010.2361 (English), 4/10/2011 20:13:40, 286720 bytes
Driver: C:\windows\system32\igfxrell.lrc, 8.15.0010.2361 (English), 4/10/2011 20:13:44, 287232 bytes
Driver: C:\windows\system32\igfxrhun.lrc, 8.15.0010.2361 (English), 4/10/2011 20:13:46, 286208 bytes
Driver: C:\windows\system32\igfxrtrk.lrc, 8.15.0010.2361 (English), 4/10/2011 20:13:54, 286208 bytes
Driver: C:\windows\system32\Gfxres.ar-SA.resources, 4/10/2011 20:13:58, 156057 bytes
Driver: C:\windows\system32\Gfxres.cs-CZ.resources, 4/10/2011 20:14:00, 133246 bytes
Driver: C:\windows\system32\Gfxres.da-DK.resources, 4/10/2011 20:14:00, 128407 bytes
Driver: C:\windows\system32\Gfxres.de-DE.resources, 4/10/2011 20:14:02, 137705 bytes
Driver: C:\windows\system32\Gfxres.el-GR.resources, 4/10/2011 20:14:04, 197902 bytes
Driver: C:\windows\system32\Gfxres.es-ES.resources, 4/10/2011 20:14:04, 137506 bytes
Driver: C:\windows\system32\Gfxres.en-US.resources, 4/10/2011 20:13:38, 123921 bytes
Driver: C:\windows\system32\Gfxres.fi-FI.resources, 4/10/2011 20:14:06, 132752 bytes
Driver: C:\windows\system32\Gfxres.fr-FR.resources, 4/10/2011 20:14:08, 135519 bytes
Driver: C:\windows\system32\Gfxres.he-IL.resources, 4/10/2011 20:14:10, 148846 bytes
Driver: C:\windows\system32\Gfxres.hr-HR.resources, 4/10/2011 20:14:34, 131705 bytes
Driver: C:\windows\system32\Gfxres.hu-HU.resources, 4/10/2011 20:14:10, 134238 bytes
Driver: C:\windows\system32\Gfxres.it-IT.resources, 4/10/2011 20:14:12, 140077 bytes
Driver: C:\windows\system32\Gfxres.ja-JP.resources, 4/10/2011 20:14:14, 152994 bytes
Driver: C:\windows\system32\Gfxres.ko-KR.resources, 4/10/2011 20:14:14, 138572 bytes
Driver: C:\windows\system32\Gfxres.nb-NO.resources, 4/10/2011 20:14:16, 128667 bytes
Driver: C:\windows\system32\Gfxres.nl-NL.resources, 4/10/2011 20:14:18, 134272 bytes
Driver: C:\windows\system32\Gfxres.pl-PL.resources, 4/10/2011 20:14:18, 133014 bytes
Driver: C:\windows\system32\Gfxres.pt-BR.resources, 4/10/2011 20:14:20, 134686 bytes
Driver: C:\windows\system32\Gfxres.pt-PT.resources, 4/10/2011 20:14:22, 133548 bytes
Driver: C:\windows\system32\Gfxres.ro-RO.resources, 4/10/2011 20:14:34, 136449 bytes
Driver: C:\windows\system32\Gfxres.ru-RU.resources, 4/10/2011 20:14:22, 182514 bytes
Driver: C:\windows\system32\Gfxres.sk-SK.resources, 4/10/2011 20:14:24, 132650 bytes
Driver: C:\windows\system32\Gfxres.sl-SI.resources, 4/10/2011 20:14:26, 128863 bytes
Driver: C:\windows\system32\Gfxres.sv-SE.resources, 4/10/2011 20:14:26, 133706 bytes
Driver: C:\windows\system32\Gfxres.th-TH.resources, 4/10/2011 20:14:28, 211082 bytes
Driver: C:\windows\system32\Gfxres.tr-TR.resources, 4/10/2011 20:14:30, 135222 bytes
Driver: C:\windows\system32\Gfxres.zh-CN.resources, 4/10/2011 20:14:30, 116233 bytes
Driver: C:\windows\system32\Gfxres.zh-TW.resources, 4/10/2011 20:14:32, 117522 bytes
Driver: C:\windows\system32\ig4icd64.dll, 8.15.0010.2361 (English), 4/10/2011 20:24:38, 17896960 bytes
Driver: C:\windows\SysWow64\ig4icd32.dll, 4/10/2011 20:18:22, 13356032 bytes
Driver: C:\windows\system32\DRIVERS\igdpmd64.sys, 8.15.0010.2361 (English), 4/10/2011 20:51:06, 12223936 bytes
Name: High Definition Audio-Controller
Device ID: PCI\VEN_8086&DEV_1C20&SUBSYS_04B21028&REV_05\3&11583659&1&D8
Driver: C:\windows\system32\DRIVERS\hdaudbus.sys, 6.01.7601.17514 (German), 11/21/2010 04:23:47, 122368 bytes
Name: 2nd generation Intel(R) Core(TM) processor family DRAM Controller - 0104
Device ID: PCI\VEN_8086&DEV_0104&SUBSYS_04B21028&REV_09\3&11583659&1&00
Driver: n/a
Name: Intel(R) 6 Series/C200 Series Chipset Family PCI Express Root Port 8 - 1C1E
Device ID: PCI\VEN_8086&DEV_1C1E&SUBSYS_04B21028&REV_B5\3&11583659&1&E7
Name: 2nd generation Intel(R) Core(TM) processor family PCI Express Controller - 0101
Device ID: PCI\VEN_8086&DEV_0101&SUBSYS_04B21028&REV_09\3&11583659&1&08
Name: Intel(R) 6 Series/C200 Series Chipset Family PCI Express Root Port 5 - 1C18
Device ID: PCI\VEN_8086&DEV_1C18&SUBSYS_04B21028&REV_B5\3&11583659&1&E4
Name: Intel(R) Centrino(R) Wireless-N 1030
Device ID: PCI\VEN_8086&DEV_008A&SUBSYS_53258086&REV_34\4&36386499&0&00E3
Driver: n/a
Name: Intel(R) HM67 Express Chipset Family LPC Interface Controller - 1C4B
Device ID: PCI\VEN_8086&DEV_1C4B&SUBSYS_04B21028&REV_05\3&11583659&1&F8
Driver: C:\windows\system32\DRIVERS\msisadrv.sys, 6.01.7600.16385 (English), 7/14/2009 02:48:27, 15424 bytes
Name: Intel(R) 6 Series/C200 Series Chipset Family PCI Express Root Port 4 - 1C16
Device ID: PCI\VEN_8086&DEV_1C16&SUBSYS_04B21028&REV_B5\3&11583659&1&E3
Name: Realtek PCIe GBE Family Controller
Device ID: PCI\VEN_10EC&DEV_8168&SUBSYS_04B21028&REV_06\4&33634699&0&00E1
Driver: n/a
Name: Intel(R) Management Engine Interface
Device ID: PCI\VEN_8086&DEV_1C3A&SUBSYS_04B21028&REV_04\3&11583659&1&B0
Driver: n/a
Name: Intel(R) 6 Series/C200 Series Chipset Family PCI Express Root Port 2 - 1C12
Device ID: PCI\VEN_8086&DEV_1C12&SUBSYS_04B21028&REV_B5\3&11583659&1&E1
Name: Renesas Electronics USB 3.0 Host Controller
Device ID: PCI\VEN_1033&DEV_0194&SUBSYS_04B21028&REV_04\4&14F9C5CE&0&00E4
Driver: C:\windows\system32\DRIVERS\nusb3xhc.sys, 2.00.0032.0000 (English), 12/10/2010 22:50:36, 181248 bytes
DirectShow Filters
DirectShow Filters:
WMAudio Decoder DMO,0x00800800,1,1,WMADMOD.DLL,6.01.7601.17514
WMAPro over S/PDIF DMO,0x00600800,1,1,WMADMOD.DLL,6.01.7601.17514
WMSpeech Decoder DMO,0x00600800,1,1,WMSPDMOD.DLL,6.01.7601.17514
MP3 Decoder DMO,0x00600800,1,1,mp3dmod.dll,6.01.7600.16385
Mpeg4s Decoder DMO,0x00800001,1,1,mp4sdecd.dll,6.01.7600.16385
WMV Screen decoder DMO,0x00600800,1,1,wmvsdecd.dll,6.01.7601.17514
WMVideo Decoder DMO,0x00800001,1,1,wmvdecod.dll,6.01.7601.17514
Mpeg43 Decoder DMO,0x00800001,1,1,mp43decd.dll,6.01.7600.16385
Mpeg4 Decoder DMO,0x00800001,1,1,mpg4decd.dll,6.01.7600.16385
DV Muxer,0x00400000,0,0,qdv.dll,6.06.7601.17514
Color Space Converter,0x00400001,1,1,quartz.dll,6.06.7601.17713
WM ASF Reader,0x00400000,0,0,qasf.dll,12.00.7601.17514
Screen Capture filter,0x00200000,0,1,wmpsrcwp.dll,12.00.7601.17514
AVI Splitter,0x00600000,1,1,quartz.dll,6.06.7601.17713
VGA 16 Color Ditherer,0x00400000,1,1,quartz.dll,6.06.7601.17713
SBE2MediaTypeProfile,0x00200000,0,0,sbe.dll,6.06.7601.17528
Microsoft DTV-DVD Video Decoder,0x005fffff,2,4,msmpeg2vdec.dll,6.01.7140.0000
AC3 Parser Filter,0x00600000,1,1,mpg2splt.ax,6.06.7601.17528
StreamBufferSink,0x00200000,0,0,sbe.dll,6.06.7601.17528
Microsoft TV Captions Decoder,0x00200001,1,0,MSTVCapn.dll,6.01.7601.17715
MJPEG Decompressor,0x00600000,1,1,quartz.dll,6.06.7601.17713
CBVA DMO wrapper filter,0x00200000,1,1,cbva.dll,6.01.7601.17514
MPEG-I Stream Splitter,0x00600000,1,2,quartz.dll,6.06.7601.17713
SAMI (CC) Parser,0x00400000,1,1,quartz.dll,6.06.7601.17713
VBI Codec,0x00600000,1,4,VBICodec.ax,6.06.7601.17514
ATI MPEG File Writer,0x00200000,1,0,atimpenc64.dll,11.06.0000.10511
ATI MPEG Video Decoder,0x005fffff,1,2,atimpenc64.dll,11.06.0000.10511
MPEG-2 Splitter,0x005fffff,1,0,mpg2splt.ax,6.06.7601.17528
Closed Captions Analysis Filter,0x00200000,2,5,cca.dll,6.06.7601.17514
SBE2FileScan,0x00200000,0,0,sbe.dll,6.06.7601.17528
Microsoft MPEG-2 Video Encoder,0x00200000,1,1,msmpeg2enc.dll,6.01.7601.17514
Internal Script Command Renderer,0x00800001,1,0,quartz.dll,6.06.7601.17713
MPEG Audio Decoder,0x03680001,1,1,quartz.dll,6.06.7601.17713
DV Splitter,0x00600000,1,2,qdv.dll,6.06.7601.17514
Video Mixing Renderer 9,0x00200000,1,0,quartz.dll,6.06.7601.17713
Microsoft MPEG-2 Encoder,0x00200000,2,1,msmpeg2enc.dll,6.01.7601.17514
ATI MPEG Audio Encoder,0x00200000,1,1,atimpenc64.dll,11.06.0000.10511
Xvid MPEG-4 Video Decoder,0x00800002,1,1,xvid.ax,
ACM Wrapper,0x00600000,1,1,quartz.dll,6.06.7601.17713
Video Renderer,0x00800001,1,0,quartz.dll,6.06.7601.17713
MPEG-2 Video Stream Analyzer,0x00200000,0,0,sbe.dll,6.06.7601.17528
Line 21 Decoder,0x00600000,1,1,,
Video Port Manager,0x00600000,2,1,quartz.dll,6.06.7601.17713
Video Renderer,0x00400000,1,0,quartz.dll,6.06.7601.17713
ATI MPEG Video Encoder,0x00200000,1,1,atimpenc64.dll,11.06.0000.10511
ATI MPEG Multiplexer,0x00200000,2,1,atimpenc64.dll,11.06.0000.10511
VPS Decoder,0x00200000,0,0,WSTPager.ax,6.06.7601.17514
WM ASF Writer,0x00400000,0,0,qasf.dll,12.00.7601.17514
VBI Surface Allocator,0x00600000,1,1,vbisurf.ax,6.01.7601.17514
File writer,0x00200000,1,0,qcap.dll,6.06.7601.17514
iTV Data Sink,0x00600000,1,0,itvdata.dll,6.06.7601.17514
iTV Data Capture filter,0x00600000,1,1,itvdata.dll,6.06.7601.17514
ATI Video Scaler Filter,0x00200000,1,1,atimpenc64.dll,11.06.0000.10511
DVD Navigator,0x00200000,0,3,qdvd.dll,6.06.7601.17713
Microsoft TV Subtitles Decoder,0x00200001,1,0,MSTVCapn.dll,6.01.7601.17715
Overlay Mixer2,0x00200000,1,1,,
RDP DShow Redirection Filter,0xffffffff,1,0,DShowRdpFilter.dll,
Microsoft MPEG-2 Audio Encoder,0x00200000,1,1,msmpeg2enc.dll,6.01.7601.17514
WST Pager,0x00200000,1,1,WSTPager.ax,6.06.7601.17514
MPEG-2 Demultiplexer,0x00600000,1,1,mpg2splt.ax,6.06.7601.17528
DV Video Decoder,0x00800000,1,1,qdv.dll,6.06.7601.17514
SampleGrabber,0x00200000,1,1,qedit.dll,6.06.7601.17514
Null Renderer,0x00200000,1,0,qedit.dll,6.06.7601.17514
MPEG-2 Sections and Tables,0x005fffff,1,0,Mpeg2Data.ax,6.06.7601.17514
Microsoft AC3 Encoder,0x00200000,1,1,msac3enc.dll,6.01.7601.17514
StreamBufferSource,0x00200000,0,0,sbe.dll,6.06.7601.17528
Smart Tee,0x00200000,1,2,qcap.dll,6.06.7601.17514
Overlay Mixer,0x00200000,0,0,,
AVI Decompressor,0x00600000,1,1,quartz.dll,6.06.7601.17713
NetBridge,0x00200000,2,0,netbridge.dll,6.01.7601.17514
AVI/WAV File Source,0x00400000,0,2,quartz.dll,6.06.7601.17713
Wave Parser,0x00400000,1,1,quartz.dll,6.06.7601.17713
MIDI Parser,0x00400000,1,1,quartz.dll,6.06.7601.17713
Multi-file Parser,0x00400000,1,1,quartz.dll,6.06.7601.17713
File stream renderer,0x00400000,1,1,quartz.dll,6.06.7601.17713
ATI Video Rotation Filter,0x00200000,1,1,atimpenc64.dll,11.06.0000.10511
Microsoft DTV-DVD Audio Decoder,0x005fffff,1,1,msmpeg2adec.dll,6.01.7140.0000
StreamBufferSink2,0x00200000,0,0,sbe.dll,6.06.7601.17528
AVI Mux,0x00200000,1,0,qcap.dll,6.06.7601.17514
Line 21 Decoder 2,0x00600002,1,1,quartz.dll,6.06.7601.17713
File Source (Async.),0x00400000,0,1,quartz.dll,6.06.7601.17713
File Source (URL),0x00400000,0,1,quartz.dll,6.06.7601.17713
Media Center Extender Encryption Filter,0x00200000,2,2,Mcx2Filter.dll,6.01.7601.17514
AudioRecorder WAV Dest,0x00200000,0,0,WavDest.dll,
AudioRecorder Wave Form,0x00200000,0,0,WavDest.dll,
SoundRecorder Null Renderer,0x00200000,0,0,WavDest.dll,
Infinite Pin Tee Filter,0x00200000,1,1,qcap.dll,6.06.7601.17514
Enhanced Video Renderer,0x00200000,1,0,evr.dll,6.01.7601.17514
BDA MPEG2 Transport Information Filter,0x00200000,2,0,psisrndr.ax,6.06.7601.17669
MPEG Video Decoder,0x40000001,1,1,quartz.dll,6.06.7601.17713
WDM Streaming Tee/Splitter Devices:
Tee/Sink-to-Sink-Konvertierung,0x00200000,1,1,ksproxy.ax,6.01.7601.17514
Video Compressors:
WMVideo8 Encoder DMO,0x00600800,1,1,wmvxencd.dll,6.01.7600.16385
WMVideo9 Encoder DMO,0x00600800,1,1,wmvencod.dll,6.01.7600.16385
MSScreen 9 encoder DMO,0x00600800,1,1,wmvsencd.dll,6.01.7600.16385
DV Video Encoder,0x00200000,0,0,qdv.dll,6.06.7601.17514
MJPEG Compressor,0x00200000,0,0,quartz.dll,6.06.7601.17713
Audio Compressors:
WM Speech Encoder DMO,0x00600800,1,1,WMSPDMOE.DLL,6.01.7600.16385
WMAudio Encoder DMO,0x00600800,1,1,WMADMOE.DLL,6.01.7600.16385
IMA ADPCM,0x00200000,1,1,quartz.dll,6.06.7601.17713
Microsoft ADPCM,0x00200000,1,1,quartz.dll,6.06.7601.17713
GSM 6.10,0x00200000,1,1,quartz.dll,6.06.7601.17713
CCITT A-Law,0x00200000,1,1,quartz.dll,6.06.7601.17713
CCITT u-Law,0x00200000,1,1,quartz.dll,6.06.7601.17713
MPEG Layer-3,0x00200000,1,1,quartz.dll,6.06.7601.17713
Audio Capture Sources:
Mikrofon (High Definition Audio,0x00200000,0,0,qcap.dll,6.06.7601.17514
PBDA CP Filters:
PBDA DTFilter,0x00600000,1,1,CPFilters.dll,6.06.7601.17528
PBDA ETFilter,0x00200000,0,0,CPFilters.dll,6.06.7601.17528
PBDA PTFilter,0x00200000,0,0,CPFilters.dll,6.06.7601.17528
Midi Renderers:
Default MidiOut Device,0x00800000,1,0,quartz.dll,6.06.7601.17713
Microsoft GS Wavetable Synth,0x00200000,1,0,quartz.dll,6.06.7601.17713
WDM Streaming Capture Devices:
HD Audio-Mikrofon 2,0x00200000,1,1,ksproxy.ax,6.01.7601.17514
Integrated Webcam,0x00200000,1,1,ksproxy.ax,6.01.7601.17514
WDM Streaming Rendering Devices:
HD Audio-Kopfhörer/Lautsprecher,0x00200000,1,1,ksproxy.ax,6.01.7601.17514
BDA Network Providers:
Microsoft ATSC Network Provider,0x00200000,0,1,MSDvbNP.ax,6.06.7601.17514
Microsoft DVBC Network Provider,0x00200000,0,1,MSDvbNP.ax,6.06.7601.17514
Microsoft DVBS Network Provider,0x00200000,0,1,MSDvbNP.ax,6.06.7601.17514
Microsoft DVBT Network Provider,0x00200000,0,1,MSDvbNP.ax,6.06.7601.17514
Microsoft Network Provider,0x00200000,0,1,MSNP.ax,6.06.7601.17514
Video Capture Sources:
Multi-Instance Capable VBI Codecs:
BDA Transport Information Renderers:
BDA MPEG2 Transport Information Filter,0x00600000,2,0,psisrndr.ax,6.06.7601.17669
MPEG-2 Sections and Tables,0x00600000,1,0,Mpeg2Data.ax,6.06.7601.17514
BDA CP/CA Filters:
Decrypt/Tag,0x00600000,1,1,EncDec.dll,6.06.7601.17708
Encrypt/Tag,0x00200000,0,0,EncDec.dll,6.06.7601.17708
PTFilter,0x00200000,0,0,EncDec.dll,6.06.7601.17708
XDS Codec,0x00200000,0,0,EncDec.dll,6.06.7601.17708
WDM Streaming Communication Transforms:
Audio Renderers:
Lautsprecher (High Definition A,0x00200000,1,0,quartz.dll,6.06.7601.17713
Default DirectSound Device,0x00800000,1,0,quartz.dll,6.06.7601.17713
Default WaveOut Device,0x00200000,1,0,quartz.dll,6.06.7601.17713
DirectSound: Lautsprecher (High Definition Audio-Gerät),0x00200000,1,0,quartz.dll,6.06.7601.17713
EVR Power Information
Current Setting: {5C67A112-A4C9-483F-B4A7-1D473BECAFDC} (Quality)
Quality Flags: 2576
Enabled:
Force throttling
Allow half deinterlace
Allow scaling
Decode Power Usage: 100
Balanced Flags: 1424
Enabled:
Force throttling
Allow batching
Force half deinterlace
Force scaling
Decode Power Usage: 50
PowerFlags: 1424
Enabled:
Force throttling
Allow batching
Force scaling
Decode Power Usage: 0
cheers!
