pressure sensitivity not working
Nov 20, 2011 11:54 AM
Tags: #failure #photoshop_touch #pressure_sensitivity
When I check the pressure sensitivity for either size or opacity, it does not work.  The brush size or opacity remains the same.
I am using an HTC Jetstream with an n-trig digitizer pen.
  • greule
    Oct 14, 2010
    Nov 21, 2011 8:50 AM   in reply to rebelpapa
    Thanks for reporting this. Unfortunately the HTC Jetstream behaves in some cases different as we expected when it comes to stylus support. We are inverstigating.
  • greule
    Oct 14, 2010
    Nov 22, 2011 12:27 AM   in reply to rebelpapa
    As soon as you enable the pressure sensitivity at the Stylus Pressure options (see enclosed screenshot) you are able to control Opacity (or size) without changing at the bush settings. If you have an eraser on you Stylus you should be able to erase without going to the Eraser tool.
  • greule
    Oct 14, 2010
    Nov 22, 2011 5:58 AM   in reply to rebelpapa
    You are correct with the Jetstream. Should work on a Lenovo Thinkpad and on  Samsung tablets with stylus support
    Nov 23, 2011 8:23 AM   in reply to rebelpapa
    @greule this meann only support for Lenovo and Samsung right?
    i test with Toshiba AT100 cannot support also, but for Samsung can work fine
  • greule
    Oct 14, 2010
    Nov 23, 2011 8:43 AM   in reply to Kajorn Bhirakit
    Correct
    Nov 29, 2011 10:52 AM   in reply to rebelpapa
    Hi rebelpapa,
    This is a very good suggestion. Would you be willing to add it to our Ideas section? If you don't get back here to add it, I will do it for you in a few days.
    Luanne
    Mar 1, 2012 11:08 PM   in reply to greule
    does that mean the samsung galaxy tab 10.1 will work with pressure sensitivity?
