peacebreakerr
Sorenson Squeeze H264 settings for blu-ray?
Nov 22, 2011 3:36 PM
Tags: #problem #cs5 #video #import #h.264 #blu-ray #encore #transcoding
I'm trying to create a blu-ray in encore, and when importing an H264 using squeeze's blu-ray preset, encore wants to reencode.  However, a blu-ray mpeg2 created from squeeze's presets works fine with encore.  I'm not able to have Adobe Media Encoder installed on the computer that I am encoding from.  Any advice?  Here are the settings:
Mainconcept H.264
2pass vbr
1080i 29.97
25,000 Kbps
constrain at 30,000 Kbps
level 4.1
high AVC profile
interlaced
top field first
CABAC encoding entropy mode
key frames every 300 frames
auto key frame on scene change (50)
use b-pictures 3
use b-slices as reference (unchecked)
multiple slices (0)
reference frames (2)
    Nov 22, 2011 5:40 PM   in reply to peacebreakerr
    I don't know if Jeff will drop by to comment on this, particularly re squeeze and whether the following applies the same or differently.
    There is a bug regarding how Encore is handling 2 pass vbr h.264.
    See this thread:
    http://forums.adobe.com/message/3917097#3917097
    Nov 23, 2011 10:37 AM   in reply to peacebreakerr
    Try your original settings, only turn CABAC off.  If that doesn't work, then I recommend X264 via MeGui (Windows only).  Save as raw .264 files and En will import them without wanting to transcode.
    -Jeff
    Nov 26, 2011 8:56 AM   in reply to peacebreakerr
    Why not?  AME is installed with PP, which you need to install Encore.  So you should have all three.
