Can't not import mov files into AE.
Nov 18, 2011 1:39 AM
This problem has appeared for some of the time. It causes several things I can't do in my After Effect, but I really have no idea how I can fix it.
Problem 1: wait a long time to open the AE, it hangs on the initializing media core and takes about 10-15 mins to get through.
Problem 2: can't import the mov files, and if I import the mov to the AE project, this pop up comes
               "After Effects error: file 'file name.mov' cannot be imported - this 'MooV file is damaged or unsupported.'"
Problem 3: can't output the comp as mov. and this pop up warming comes
               "After Effects: One of the output modules could not be imported. It has been reset to use the default setting for the selected file format."
I read some threads and I knew this might cause by the blocked communication between AE and QT. But I have double check my QT, it is version 7.6.6 and I have no firewall software installed, hence the communication is okay (i guess, since I can play the mov file normally and not the warm message that “QuickTime is not installed on this system…”) .
Some other thread says may because of the three party component in the QT Library. This may make sense, cause I install some converters for converting the wmv and avi before…
Here are the components in the QT Library:
AviImporter.component
FFusion.component
iChatTheaterPreview.component
IMXCodec.component
XviD_Codec.component
↑↑The above 5 component I have move them out, but no luck still ↑↑
AppleAVCIntraCodec.component
AppleHDVCodec.component
AppleIntermediateCodec.component
AppleMPEG2Codec.component
AppleProResCodec.component
DesktopVideoOut.component
DVCPROHDCodec.component
DVCPROHDMuxer.component
DVCPROHDVideoDigitizer.component
DVCPROHDVideoOutput.component
DVCPROHDVideoOutputClock.component
DVCPROHDVideoOutputCodec.component
FCP Uncompressed 422.component
LiveType.component
Could anyone give me some advise regarding to those problems, and is there any of the above component I should move away.  DEL .\/.
Thanks so much in advance for any of your help and advise, really appreciate that! thanks!
Donna
Here are some background info about my mac:
Mac OSX 10.6.8
2x3 GHz Dual-Core Intel Xeon
8GB memory
AE CS5
QuickTime Player 7 version 7.6.6
Branched to a new discussion.
    Nov 18, 2011 7:54 AM   in reply to ilannod
    Remove all of those third-party components and try again.
    If After Effects works with QuickTime fine after that, then put the components back in one by one until you find the one (or more) that's causing the problem.
    Nov 20, 2011 2:20 PM   in reply to ilannod
    I was having the same problem and so far this solution has worked for me. (knock on wood)
    Try setting your default player for .mov files to QuickTime.  (Mine was set to Windows Media Player)
    • Right click on one of the mov files you are having a problem opening in AE.
    • Select the "Open with" and select "Choose default program..." at the bottom.
    • Select Quick Time. (Make sure the "Always use the selected program to open this kind of file" box is checked.)
    • Reboot your computer.
    • Open AE and see if it works.
