Adobe Drive 3 not starting on Mac OS X 10.7.2
Nov 17, 2011 9:03 AM
I have a computer with Mac OS X 10.7.2 installed. On this computer there is the Creative Suite CS 5.5 (with the latest updates applied to every single piece), a component of the Creative Suite CS5 (InDesign CS5, updated as well). It is impossible to have Adobe Drive 3 running on this computer.
Every time the Adobe Drive 3 application is launched, the CS5ServiceManager crashes.
Not only, when Adobe Drive 3 is installed on that computer, Photoshop CS 5.1 and Illustrator CS 5.1 take 2 minutes to open a file that normally takes 2/3 seconds to be opened.
Is this a known bug?
Best,
Luca
    Nov 18, 2011 1:02 AM   in reply to emerasoft-srl
    Hi Luca,
    Thank you very much for your postting this issue.
    As your desription, we did following test to reproduce:
    1. On Mac 10.7, update to Mac 10.7.2.
    2. Install Design standard CS5 and Design standard CS5.5 on Mac 10.7.2. then update product to latest build.
    3. Install AD 3.0 and Launch Connect UI. everything works well.
    So i am not sure if there are somthing missing in my test.
    It will be helpful if provide us the CS5 ServiceManager log at:/users/@username/Library/Application Support/Adobe/CS5 ServiceManager/logs. and your System Information files.
    Jianfeng
    Nov 22, 2011 11:45 PM   in reply to emerasoft-srl
    Hi Luca,
    Sorry for late reply.
    I have got the log and system info from your mail. Thanks for your effort.
    We're invesgating about this issue.
    Can you help to try following steps :
    Lauch InDesign CS5 and click 'Windows'/'Extensions'/'Kuler'. check if CS5 ServiceManager is launched.
    If CS5 ServiceManager still is crashed. try to uninstall AD, and do the above step again.
    Thanks for your effort again!
    Jianfeng
    Nov 23, 2011 1:42 AM   in reply to emerasoft-srl
    Hi Luca,
    Thanks for your effort!
    In your system info, we found one difference between your machine and our test machine.
    The Java VisualVM  version is 14.0.3 in your machine. Current our test enviroment is 14.1.0.  So can you update your Java to 14.1.0 ?
    Jianfeng
    Nov 23, 2011 3:14 AM   in reply to emerasoft-srl
    Hi Luca,
    We comparing the Service Manager load lib, find there are some difference:
    Following are piece of Service Manager load library when Service Manager launched successfully:
    /Users/labuser/Library/Application Support/Adobe/CS5ServiceManager
    /Library/Application Support/Adobe/CS5ServiceManager/CS5ServiceManager.app/Contents/MacOS/ CS5ServiceManager
    /System/Library/Frameworks/JavaVM.framework/Versions/A/JavaVM
    /System/Library/PrivateFrameworks/JavaLaunching.framework/Versions/A/J avaLaunching
    /System/Library/Java/JavaVirtualMachines/1.6.0.jdk/Contents/Libraries/ libjvmlinkage.dylib
    /System/Library/Java/JavaVirtualMachines/1.6.0.jdk/Contents/Home/lib/j ce.jar
    /System/Library/Java/Extensions/AppleScriptEngine.jar
    /System/Library/Java/JavaVirtualMachines/1.6.0.jdk/Contents/Libraries/ libverify.dylib
    /System/Library/Frameworks/JavaVM.framework/Versions/A/Frameworks/Java NativeFoundation.framework/Versions/A/JavaNativeFoundation
    /System/Library/Java/JavaVirtualMachines/1.6.0.jdk/Contents/Libraries/ libjava.jnilib
    Follwoing are from your logs:
        0x1000 -    0x3bfe7 +com.adobe.csi.CS5ServiceManager (??? - 5.0.0.743) <72D5CE97-C76C-E56A-4F97-FA1C27EF3179> /Library/Application Support/Adobe/*/CS5ServiceManager.app/Contents/MacOS/CS5ServiceManage r
       0x76000 - 0x7affd  com.apple.JavaVM (14.1.0 - 14.1.0) <1163556C-5C1D-3C5A-8767-682DAE7D3174> /System/Library/Frameworks/JavaVM.framework/Versions/A/JavaVM
    0x82000 -    0x86fff  JavaLaunching (??? - ???) <54FA100F-1C60-33D1-97C0-3B0704FE97BC> /System/Library/PrivateFrameworks/JavaLaunching.framework/Versions/A/ JavaLaunching
    0x70f000 -   0x716fff  libverify.dylib (1.0 - 1.0) <C4F30112-1D8E-31D8-8E38-F6A10194E21F> /System/Library/Frameworks/JavaVM.framework/Versions/1.5.0/Libraries/l ibverify.dylib
      0x71b000 -   0x723fff  JavaNativeFoundation (??? - ???) <066553E2-055F-3D16-AD97-8F715D63CC61> /System/Library/Frameworks/JavaVM.framework/Versions/A/Frameworks/Jav aNativeFoundation.framework/Versions/A/JavaNativeFoundation
    0x72c000 -   0x733ffb  libjvmlinkage.dylib (??? - ???) <6A77EDD1-D1B2-39A9-A637-67BC1D7349F9> /System/Library/Java/JavaVirtualMachines/1.6.0.jdk/Contents/Libraries /libjvmlinkage.dylib
    0x73a000 -   0x757fff  libjava.jnilib (??? - ???) <A84706D2-237E-37E9-A7B5-F1079935107D> /System/Library/Frameworks/JavaVM.framework/Versions/1.5.0/Libraries/l ibjava.jnilib
    0x5000000 - 0x536dfe3  libjvm.dylib (??? - ???) <E873F28F-C5E1-DAA6-2B07-7C1A50044B06> /System/Library/Java/JavaVirtualMachines/1.5.0/Contents/Home/bundle/Li braries/libjvm.dylib
    0x8fe06000 - 0x8fe389c7  dyld (195.5 - ???) <134323A7-49DC-3A9D-ACFD-32FAD0FD6BA2> /usr/lib/dyld
    Highlighted are difference.
    My concern is :there are two JavaVM framework 1.5.0 and 1.6.0 involved. it should be only 1.6.0.jdk in the /System/Library/Java/JavaVirtualMachines if all the java updated from Mac website.
    So can you just keep 1.6.0 jdk and try it again? Thanks for your patience.
    Jianfeng
    Nov 23, 2011 4:45 AM   in reply to emerasoft-srl
    I think it doesn't matter whether you use JDK 1.5 or JDK 1.6. The most important thing is that you must use 32-bit version. Becasue some dll/framework in Adobe Drive have only 32-bit version.
