Hello,
I am having some trouble setting up the SharePoint connect for LiveCycle. When entering the user credentials in the configuration page, I get a 401 Unauthorized error from Share Point server. However, using the same credentials, I am able to log into the Share Point site successfully.
Both systems are sync'd to the same LDAP and I've followed the instructions quite closely from Configuring LiveCycle ES2 Connector for Microsoft SharePoint.
My settings are similarly as follows:
Server: sp.lkp.com:80
User: spuser
Password: *******
Domain: LKP
Does anyone have any idea what might be wrong?
The instructions for the server say:
SharePoint Server Host Name: The host name port number of the web application on the SharePoint server, in the format [hostname]:[port]. , should my link point to something more specific than just the server url?
Thanks in advance.
Solved! Go to Solution.
Total Likes
Yes, Basic authentication should be enabled for SharePoint 2010. For MOSS 2007 NTLM should also work as it uses NTLM v1 but sharepoint 2010 uses NTLM v2 which is not supported by the connector yet.
Total Likes
Please check whether Basic Authentication is enabled on sp.lkp.com:80 or not?
Total Likes
Should Basic Authentication be enabled as well even if I opt to use NTLM or Kerberos authentication?
I will check if it is enabled when I have a chance to check tomorrow.
Total Likes
Total Likes
