RLCadence
Can't see my files in Navigation panel of Library
Nov 23, 2011 4:12 PM
This is my third effort at posting thjis question - the last two came back "Error - can't post blank message" I just sent a test message all in text and it went, so I'll try sending without screen shots.
Usually when I Import I select what I want to Import from the left panel of the Library interface. I open Folders, then my C drive (whatever) and go from there. My entire file structure is displayed and I can navigate anywhere I want.
Tonight all that is displayed under Folders - C Drive is a listing of already imported folders. It's a list compiled from within Lightroom, not my computer's file directory.
I am not in Catalog and there is no slider to the left of the list - plus the list is not even a portion of my file list, it is something altogether else.
I was able to do a clumsy import by using File Import, which brought up an interface I have never seen before, much less used. I was able to "select a source" there and browse my files. But it was unfamiliar and I need to get my navigation window back to showing what's on my C drive when I click Folders - C Drive. Help?
Sorry about no screen shots, I'm afraid to lose another message. Fingers crossed.
    Nov 23, 2011 5:01 PM   in reply to RLCadence
    Please do pur up a screen shot of the problem area.
    Nov 23, 2011 5:14 PM   in reply to RLCadence
    Screen shots work. You need to use the camera icon:
    Adobe Forums Can't see my files in Navigation panel of Library - Mozilla Firefo_2011-11-23_21-12-18.jpg
    Hal
    Nov 23, 2011 7:51 PM   in reply to RLCadence
    The LIBRARY module isn't supposed to show you all of your drives & folders - it only shows those drives & folders which contain pictures from the current catalog.
    The IMPORT dialog, on the other hand, should show ALL of your devices, drives, and folders - every place you might want to import pictures from.  Did you actually click the IMPORT button before starting this process?
    Dec 7, 2011 12:30 PM   in reply to RLCadence
    Yes. Click on the button with the triangle in the lower left corner:
    Adobe Forums Can't see my files in Navigation panel of Library - Mozilla Firefo_2011-12-07_16-27-58.jpg
    Hal
