Tiffany Tsai 6 posts
Nov 25, 2011
"Save as" Problem
Nov 25, 2011 5:50 PM
Tags: #acrobat #10 #acrobat_x_pro
When I open up an existing scanned file, and make changes to it in Adobe Acrobat X (by highlighting and underlining) I am unable to save the file under its original name.
Instead, when I try to save the file, it forces me to save as. I am wondering if it is just software compatibility with the file, but other computers with Adobe X worked just fine. So I am wondering what might have caused the problem.
Thanks for your time and assistance!
    Nov 26, 2011 1:36 AM   in reply to Tiffany Tsai
    Save will save 'as is'  with same name,file format,location, Where save as gives you the option to change name and save in a different format,location. So there no big difference.
    Nov 26, 2011 6:03 AM   in reply to Tiffany Tsai
    The problem with Save is that it saves everything, old and new. That causes your file to become larger. The Save As gets rid of stuff no longer in use. Don't know if that is happening in your case, but could be the issue.
    Nov 26, 2011 12:42 PM   in reply to Tiffany Tsai
    Is the location from which you open the file - the folder or directory - on a server or somewhere where you haven't got full access? That could make it behave like a read-only file.
    Or are you able to do a 'save as' back to the same folder?
    bob
    Nov 26, 2011 2:33 PM   in reply to Tiffany Tsai
    Syncing the file wouldn't cause this, as far as I know.
    If you open the file, go to File->Properties->Security, are there any restrictions?
    bob
    Nov 26, 2011 4:03 PM   in reply to Tiffany Tsai
    On the general tab of the properties window, is the readonly checked? That can easily happen if you copy the file from a CD or it may be the way the file was sent to you (I think).
    Nov 28, 2011 6:38 AM   in reply to Tiffany Tsai
    Boy, you must have time on your hands. A reinstallation of my system and software usually takes me several days.
    Dec 16, 2011 11:42 PM   in reply to Tiffany Tsai
    Is there no solution to this? I cannot save any of my PDFs that I annotate!!!
    Dec 17, 2011 12:18 AM   in reply to rgc67
    Use File > Save As...
    Dec 17, 2011 10:15 AM   in reply to Bernd Alheit
    That obviously is NOT a solution.
    Dec 17, 2011 11:13 AM   in reply to rgc67
    You can't save with File > Save As... ?
    Dec 22, 2011 10:14 PM   in reply to Bernd Alheit
    I solved my issue here:
    http://acrobatusers.com/forum/general-acrobat-topics/cant-save-file-af ter-making-edits#comment-86760
    It's the stupid preview window in Windows 7 interfering.
