SethDepp
Storing a position value from the previous frame
Nov 26, 2011 3:20 PM
Hey guys,
So, I'm trying to assign the X value a null object had at the previous frame so I can continue to subtract a number from it cumulatively. I'm trying to assign it to a variable (prevframe). I'm not sure where I'm going wrong, but the line I'm trying to do it on is written as follows:
prevframe = transform.xPosition.valueAtTime(time-(1/24))
So in my mind, this should be taking a look at the value of X on the null, then looking back in time to figure out what it's value was on the previous frame (my frame rate is 24, so I'm dividing 1 second in to 24 pieces and telling it to subtract that much from the current time), and assigning whatever that returns to the variable. But it's just returning a static value, even though I'm subtracting from it. I feel like it's not the correct syntax, but I really have no idea.
I want to continue to subtract a value which is based on the velocity of another object from this, which I have worked out, I just can't figure out how to reference what this nulls X position was in the previous frame so it always returns the same value until all motion has stopped. The formula the variable is being run through looks like:
finalposition = prevframe - camvelocity
Which is then assigned to the final X position of the null object.
So, I'm not sure where I'm going wrong. I hope I've provided enough information to help someone wrap their head around this and hopefully help me solve it.
Thanks in advance,
-Seth
    Nov 26, 2011 4:37 PM   in reply to SethDepp
    I'm fairly confused by your question, but I have a few comments.
    First instead of using 1/24 in your prefFrame calculation I would use thisComp.frameDuration.
    an expression that would display the x position of a null in the previous frame would look like this.
    nl = thisComp.layer("Null 1"); // your null
    prevframe = nl.position.valueAtTime(time - thisComp.frameDuration);
    x = prevframe[0]; // extract x value
    [x, value[1]]
    I have no idea what you're trying to do with the camvelocity or how you came up with that number. The expression listed above will allow you to animate the layers Y position and track the x position of the null one frame behind the current frame. If the null moves 10 pixels per frame the position of the layer will be 10 pixels behind the null until the motion stops.
    Nov 26, 2011 6:47 PM   in reply to SethDepp
    I'm not sure I know what you mean by camera's velocity.
    If the camera is moving 20 pixels per frame then you want to subtract 20 pixels from the the x position of he camera, then in the next frame you want to subtract 40 pixels, then then next 60 pixels.
    If you define your camera as cam = thisComp.layer(Camera 1); then you take the initial position of the camera as ocp = cam.position.valueAtTime(0) you'll get the position value at the first frame of the composition. ocp = Original Camera Position. Then you subtract the current camera position as ccp = cam.position to get the total pixels the camera has moved in x. It sounds like that's what you want. All you have to do is extract the x value ([0]).
    Now you can take that value and apply it to the position value of your null like this:
    cam = thisComp.layer("Camera 1");
    ocp = cam.position.valueAtTime(0);
    ccp = cam.position;
    nx = ocp - ccp;
    [value[0] + nx[0], value[1], value[2]];
    I'm assuming that the null is 3D. If not eliminate the last item in the array. By using value[0] + nx in the array you'll be able to adjust the starting position of the null in any axis. You can even add keyframes if you'd like.
    I'm not sure you're going to get the results you are looking for. It seems like you're trying to simulate some kind of lens flair. Changing the + to a - in the final line will reverse the tracking of the null.
    Nov 27, 2011 4:02 PM   in reply to SethDepp
    I think you've been bitten by the fact that expressions have no memory of what they've calculated on previous frames. If the camera has a constant velocity you can probably get away with something as simple as this:
    v = thisComp.layer("Camera 1").transform.position.velocityAtTime(0);
    value - (time - inPoint)*v[0];
    If the camera has variable velocity, you need to loop through each previous frame and add up offsets created by the velocity at each frame, more like this:
    f = timeToFrames(inPoint);
    accum = 0;
    c = thisComp.layer("Camera 1").transform.position;
    for (f = timeToFrames(inPoint); f <= timeToFrames(); f++){
      accum += c.velocityAtTime(framesToTime(f))[0]*thisComp.frameDuration;
    value - accum
    It gets more complicated it you need it to be anything other than horizontal motion.
    Hope this helps.
    Dan
    Nov 27, 2011 5:06 PM   in reply to Dan Ebberts
    Dan,
    I tried your second expression in a test comp with the camera moving between 2 keyframes at a constant velocity. The results were nearly identical to my expression. Your first expression, the simple one also produced identical results but the layer kept moving after the camera stopped. I thought the first expression should have v where time is. That doesn't work.
    value - (v - inPoint)*v[0]; // doesn't work
    I can't see how to make the horizontal movement stop when the camera stops. I also discovered that under some conditions with only two keyframes the simple expression produces completely different movement.
    Thanks for giving me some more to think about.
    Nov 27, 2011 5:14 PM   in reply to Rick Gerard
    >The results were identical to my expression.
    That sounds right.  I may have over-thought this. I was thinking that to account for variable velocity, you'd have to integrate it over time, but if you integrate speed you get distance traveled. Duh.  So your way is simpler and should work even if the velocity is variable.
    Dan
    Nov 27, 2011 6:03 PM   in reply to Dan Ebberts
    I actually kind of like what's happening with the simple expression. I'm not sure how to describe the motion, but it does some really interesting things when there's a bunch of camera movement.
