I have been asked to build a small website based on a PDF template (with an additional .indd file) created by a designer who knows nothing about HTML, but they have advised me is that it should be possible to somehow extract the required components (layout & images) using Adobe Illustrator CS5 and then use those to create the webpages.
Is this correct or is there a better way to get the layout & images out of the PDF or .indd files?
I can just about figure my way through Adobe Illustrator, but guidance would be helpful as this is the 1st time i have attempted something like this.
Also the layout that has been provided is about the 1/2 the size it should be, I have tried scaling this up within Adobe Illustrator, but the resulting image won't export to a webpage properly, all that exports is what is within the little box in the middle of the screen. I know I am doing this wrong. What's the correct way to make everything larger?
I suggest you should post your query at this link:
<http://forums.adobe.com/community/illustrator/illustrator_general>
Good luck.
I've been faced with this before. Depending on complexity of artwork, it is possible to do screenshots of PDFs. I opened mine in Photoshop and created PSD files. Then saved individual layers for the web as images only -- either jpg or png.
Nancy O.
Alt-Web Design & Publishing
Web | Graphics | Print | Media Specialists
