I'm trying to install Flash Builder 4.6, but I'm getting an error immediately when the installer starts. It says "Beta or prerelease versions of Adobe Flash Builder are installed on the machine, and must be uninstalled before this installation can proceed. Please uninstall these products, restart your computer, then run this installer again."
I do not have any beta version of Flash Builder installed on my machine. I do however have previous releases of FB 3.0, 4.0, and 4.5 installed. I use these to support various projects.
Here are my machine specifications:
2011 Macbook Pro w/ OSX Lion updated to 10.7.2
100GB of free space
8 GB of ram
I found the following error messages in the OSX Console app:
11/30/11 10:47:20.001 AM PDApp: CFURLCreateWithString was passed this invalid URL string: '/System/Library/Frameworks/' (a file system path instead of an URL string). The URL created will not work with most file URL functions. CFURLCreateWithFileSystemPath or CFURLCreateWithFileSystemPathRelativeToBase should be used instead.
11/30/11 10:47:20.001 AM [0x0-0x3f83f8].com.adobe.PDApp.setup: 2011-11-30 10:47:20.000 PDApp[6202:407] CFURLCreateWithString was passed this invalid URL string: '/System/Library/Frameworks/' (a file system path instead of an URL string). The URL created will not work with most file URL functions. CFURLCreateWithFileSystemPath or CFURLCreateWithFileSystemPathRelativeToBase should be used instead.
"If you already have Flash Builder 4.5 installed you will need to uninstall in order to install Flash Builder 4.6."
http://blogs.adobe.com/flex/2011/11/flex-4-6-and-flash-builder-4-6-upd ates-now-available.html
I had the same error until I uninstalled FB 4.5
I had the same issue, until I realized I had to uninstall the components from the Creative Suite and not directly from the Programs panel.
For those still having issues, unistall any previous versions of FB from Control Panel > Programs > Programs and Functionality and double click the Creative Suite you have currently installed. Untick all software except FB and AIR for iOS which needs to be removed before you install FB 4.6 - reboot and try now to install the latest Flash Builder. It should work.
Any solution for this yet? After having to uninstall FB4.5 (& iOS support) to upgrade then the installer not wanting to install iOS support because its 'already installed' ... FB4.6 wont compile iOS ... heres FB & the installer telling me both things at the same time!
Note: the store errors when i try to buy an upgrade so im also now on a trial again, plus FB4.6 wont import the default workspace FB4.5 created so im having to import the projects from that workspace manually!
Thanks Adobe, I guess i should just learn HTML5 as you seem to want ... as i remember i LOVED debugging stuff in every single version of each browser in the 90s!
