I'm trying to use hibernateannotations with lcds 3.1 and flexbuilder 4.5.1 and I'm having problem getting the fill operation to work, I'm not sure what I'm doing wrong
I'm getting this error back from lcds:
[LCDS]Exception executing assembler operation. incomingMessage: Flex Message (flex.data.messages.DataMessageExt)
operation = fill
id = null
clientId = C1DFF41D-2A96-1A63-E293-F4CB0FEEE405
correlationId =
destination = WrUesdDataManagerService
messageId = 9861843C-94CA-9656-D044-F4CB1029A6AC
timestamp = 1322661908887
timeToLive = 0
body =
[[], getAllSorted, [Ljava.lang.Object;@7d6b4be5]
hdr(DSId) = D8A3C599-C32F-EA78-D64B-978BE213BFC3
hdr(DSEndpoint) = my-rtmp
exception: java.lang.ClassCastException: flex.messaging.io.ArrayCollection cannot be cast to java.lang.String
at flex.data.assemblers.HibernateAssembler.fill(HibernateAssembler.java: 1034)
at flex.data.assemblers.HibernateAssembler.fill(HibernateAssembler.java: 957)
at flex.data.adapters.JavaAdapter.invokeFillOperation(JavaAdapter.java:9 96)
at flex.data.adapters.JavaAdapter.invoke(JavaAdapter.java:622)
my actionscript looks like this:
var param:ArrayCollection = new ArrayCollection();
param.addItem(jobs);
param.addItem("getAllSorted");
param.addItem([]);
getAllResult.token = WrUesdDataService.fill(param);
and I've went through commenting out the various params like jobs and [] but I still get the same error
the using lcds 3.1 doc says fills should like this
myService.fill(myCollection, "flex:hql", "from Person p where p.firstName = ? ", ["Paul"]);
but the compiler doesn't that syntax.
I created the service by importing it into the data model and generating the code.
here is my data-managementconfig.xml
<?xml version="1.0" encoding="UTF-8"?>
<service id="data-service"
class="flex.data.DataService">
<adapters>
<adapter-definition id="actionscript" class="flex.data.adapters.ASObjectAdapter" default="true"/>
<adapter-definition id="java-dao" class="flex.data.adapters.JavaAdapter"/>
</adapters>
<default-channels>
<channel ref="my-rtmp"/>
</default-channels>
<destination id="WrUesdDataManagerService">
<adapter ref="java-dao" />
<properties>
<source>flex.data.assemblers.HibernateAnnotationsAssembler</source>
<item-class>gov.llnl.castlewr.model.WrUesdData</item-class>
<scope>application</scope>
<metadata>
<identity property="uesdId"/>
</metadata>
<server>
<fill-configuration>
<use-query-cache>false</use-query-cache>
<allow-hql-queries>true</allow-hql-queries>
</fill-configuration>
</server>
</properties>
</destination>
</service>
any suggestions?
A few questions:
Rohit
From flexbuilder:
ADEP Data Services - Content Repository Enablement 4.5.501000.v315043-20110711 com.adobe.model.feature.ria.feature.group
ADEP Data Services - Flash Builder 4.5 Enablement 4.5.501000.v315043-20110711 com.adobe.model.feature.fb.feature.group
ADEP Data Services - Model Editor 4.5.501000.v315043-20110711 com.adobe.model.feature.editor.feature.group
ADEP Data Services - Modeler Core 4.5.501000.v315043-20110711 com.adobe.model.feature.core.feature.group
ADEP Data Services - SAP Connector 4.5.501000.v315043-20110711 com.adobe.model.feature.sap.feature.group
The compiler wants WrDataService.fill(arg0:ArrayCollection) which I assumed are the 3 args listed for the fill, (collection, query, queryparams)
From: "Rohit . Kumar" <forums@adobe.com<mailto:forums@adobe.com>>
Reply-To: "jive-655742809-9tro-2-2ewwm@mail.forums.adobe.com<mailto:jive-655742809-9tro-2-2ewwm@mail.forums.adobe.com>" <jive-655742809-9tro-2-2ewwm@mail.forums.adobe.com<mailto:jive-655742809-9tro-2-2ewwm@mail.forums.adobe.com>>
Date: Wed, 30 Nov 2011 09:43:51 -0800
To: Chuckles McGregor <mcgregor1@llnl.gov<mailto:mcgregor1@llnl.gov>>
Subject: Re: lcds 3.1 hibernateannotations problem lcds 3.1 hibernateannotations problem
created by Rohit . Kumar<http://forums.adobe.com/people/Rohit.Kumar> in LiveCycle Data Services ES - View the full discussion<http://forums.adobe.com/message/4055062#4055062
