m4v is produced by Media Encoder
However, when imported into Encore, it's shown as untranscoded. When I try to build, it will start transcoding process.
What's causing this?
From Media Info
Video
Format : AVC
Format/Info : Advanced Video Codec
Format profile : Main@L4.1
Format settings, CABAC : Yes
Format settings, ReFrames : 3 frames
Bit rate mode : Variable
Maximum bit rate : 35.0 Mbps
Width : 1 920 pixels
Height : 1 080 pixels
Display aspect ratio : 16:9
Frame rate : 29.970 fps
Standard : NTSC
Color space : YUV
Chroma subsampling : 4:2:0
Bit depth : 8 bits
Scan type : Interlaced
Scan order : Top Field First
Project transcoding setting:
H.264
1920x1080
29.97
Upper
I played some trick with it: choose Locate transcode file -> Blu-ray and pick the same file. Then try to build it. During importing, it errors our:
Blu-ray Object: "<Timeline>video", Error: "invalid format", Code: "14",
Note: "ERROR: This stream doesn't include Picture timing SEI, Unit Offset = 508122323"
Searched and found
http://adobe.hosted.jivesoftware.com/message/3460426
I am not sure if this is the same problem. My encoding setting is automatic. The result m4v shows
| Scan order | : Top Field First |
Still, I will give it try and report back
Different name and folder. Fresh project tried. None is working.
Are we sure this is an Encore bug, not an AME bug? The above error shows a positon info. Is it possible to translate into the timeline point? I've tried the 30 second and it works just fine. So I suspect there is some part of the timeline is causing this problem.
I've tried to 1 min and 20 min with the gap right in the middle. The result imported just fine.
Do you know how to translate the position number in the above error message to position on timeline?
I have 2 projects with this problem. I've checked the 2nd project and it has no gap.
I've split the entire video into 4 segments in AME, a-d. Piece b is the only one with this problem. Then I split it into 4 piece b1 to b4. Now none of them has this problem.
segment b is 40 min long. It has no filter other than a few still on top of video.
This has to be the most frustrating thing I have ever had.
I've used tsMuxeR 1.10.6 to do the joining. Output is set to Demux. The result file plays out just fine.
When b1-b4 are joined, the result requires transcoding, even though none of them require transcoding.
If I put segment a, b1-4, c, d into the timeline, Encore seems to handle everything properly and produces the Blu-ray folder output that's played fine.
I'd think at this point it's more likely to be a bug in Encore than AME.
Again, this is really frustrating.
Investigation #2: more likely a bug in AME
I took the second project and used tsMuxeR to mux and split the m4v+ac3 files repetitively. It narrowed down a 3 second segment which has this transcoding requirement. -- If you know a program that can do this w/o muxing, please let me know. I had no luck so far.
I then removed 1 second from the beginning of the clip and added an Encore marker (which to my knowledge force I frame)
The result m4v file worked out fine in Encore. This might mean a bug in AME, which is more serious.
I went back to project 1 and did the same. This time 6 30-second segments have this problems. This is too much for me I gave up on that investigation.
I've uploaded the file and let the Adobe developer to take a look at the 3-second m2ts (I can't find any other tool so I have to mux it). Let's see what they find out.
This has to be a bug in AME CS5.5, having the same exact problem:
http://forums.adobe.com/message/4117565
Anyway, I have CS5 installed on my Windows partition and tried adding the .m4v file to Encore CS5 and Encore still wanted to transcode it which leads me to believe that it's a problem with the encode using AME.
I was able to open my Premiere CS5.5 project in CS5 without an issue so I'm going to just have to encode using AME CS5 under my Windows partition until Adobe issues a patch for this extremely inconvienient problem.
There are few things more frustrating than sitting through an eight hour encode only to learn Encore wants to do that again when you know it shouldn't have to.
