URLLoader doesn't work(IOError #2032) in AIR SDK version 2.5
Dec 16, 2010 4:41 PM
  Latest reply: 72Pantera, Dec 26, 2013 8:26 PM
Replies 1 2 Previous Next
  • Chris Campbell
    May 4, 2010
    May 25, 2011 1:24 PM   in reply to canaca
    For those running into this error, could you please add a new bug to bugbase.adobe.com and post back with a link so that others can cast their votes?  In the bug, please include sample source code and a full description, including a link to this thread.
    Chris
    May 26, 2011 5:44 AM   in reply to Chris Campbell
    Bug created: https://bugbase.adobe.com/index.cfm?event=bug&id=2881807
    Please vote on this bug if you experience the same!
    May 27, 2011 8:00 AM   in reply to ShinyaArao
    I had a similar issue for iOS and determined that our web server certificate wasn't valid.  After updating the certificate, the 2032 no longer happens.
    May 30, 2011 6:26 AM   in reply to ShinyaArao
    Um....The point of My Question is 'Not working URLLoader in Local Network'...
    For Example, When url is http://ertr2.mireene.com, URLLoader is good working in AIR 2.5,
    but when url is http://192.168.0.10 , URLLoader is not working in this platform...
    important point, this problem is appeared in IOS and Android development.
    Finally I had solved this problem, not used local network(http://192.168......)  and using external network(exist server).
    URLLoader is not working in localhost or internal network!!
    Nov 3, 2011 10:32 AM   in reply to ShinyaArao
    Help!
    I have a traditional URLLoader/URLRequest setup that loads an external XML file.
    It works flawlessly in the AIR Launcher ... but when I try on my device it fails... giving me this message over the remote debug session:
    "...text=Error #2032: Stream Error. URL: app:/assets/xml/projects.xml"
    I've even tried changing my code to use the File.applicationDirectory approach. But once again,... it only works in the AIR Launcher... not on the device!
    What am I missing? Anyone have a clue?  Thanks in advance for anyone who can help or hint!
  • Chris Campbell
    May 4, 2010
    Dec 1, 2011 11:31 AM   in reply to chris_emerson
    Hi Chris,
    If you're still having an issue with this, could you post your code so I can take a look and try it out?
    Chris
    Dec 6, 2011 3:48 PM   in reply to ShinyaArao
    Hi
    Another Chris to add to the mix.
    I'm getting the same error. Im trying to convert a rather large web project to an Air for Mobile project in Flash Builder 4.5.
    I have Air SDK 3.0 and Flex 4.5.1 and whilst my URL request work fine running via the desk top, it encounters IOError 2032 when running on the device.
    Does anyone have a fix?
    All the best
    ChrisP.
  • Chris Campbell
    May 4, 2010
    Dec 7, 2011 12:54 PM   in reply to chrispeck303
    Chris,
    Is this happening on iOS or Android?
    Chris
    Dec 7, 2011 2:38 PM   in reply to Chris Campbell
    Hi Chris
    I'm using a Galaxy S2 running Android 2.3.3 for device debugging.
    As far as the code is concerned there isn't much to it when it finally sends the request.
    public function send (params:URLVariables, method:String="GET") : void
        var req:URLRequest = new URLRequest(url);
        req.method = method;
        req.data = params;
        addToQueue(req);
    then when dequeued
    urlLoader.load(req);
    My current theory is that it encounters an invalid SSL Certificate, though I would have thought android would spit out a warning. My system's guys are investigating that avenue. Otherwise, I'm a bit stuck.
    Any advice would be appreciated.
    All the best
    Chris.
    Dec 7, 2011 3:23 PM   in reply to chrispeck303
    Hi Chris
    Don't worry about this one. My bad. There was a firewall issue blocking requests to our dev servers from the phone.
    Thanks for your time all the same.
    ChrisP.
  • Chris Campbell
    May 4, 2010
    Dec 7, 2011 3:27 PM   in reply to chrispeck303
    Hi Chris,
    Np, and thanks for the update.  Glad you got it working.
    Chris
    Jan 5, 2012 4:54 PM   in reply to Chris Campbell
    Chris Campbell,
    from my post at http://forums.adobe.com/thread/943234, here is the code that reproduces this bug with Flash Builder 4.6/Air 3.1 (essentially if you load any valid https url in to UrlLoader in Flash Builder it works, however in the Android Emulator (I don't have a physical device) it gives an IOError 2032) - I see a certificate error in adb logcat but not sure if it is the cause:
    <?xml version="1.0" encoding="utf-8"?>
    <s:View xmlns:fx="http://ns.adobe.com/mxml/2009"
                        xmlns:s="library://ns.adobe.com/flex/spark"
                        xmlns:mx="library://ns.adobe.com/flex/mx"
                        xmlns:ns1="*"
                        xmlns:local="*"
                        creationComplete="windowedapplication1_creationCompleteHandler(event) "
                        actionBarVisible="true" tabBarVisible="true">
              <fx:Script>
                        <![CDATA[
                                  import mx.events.FlexEvent;
                                  protected var requestTokenUrl:String = "https://www.google.com";
                                  protected function windowedapplication1_creationCompleteHandler(event:FlexEvent):void
                                            var loader:URLLoader = new URLLoader();
                                            loader.addEventListener(ErrorEvent.ERROR, onError);
                                            loader.addEventListener(AsyncErrorEvent.ASYNC_ERROR, onAsyncError);
                                            loader.addEventListener(SecurityErrorEvent.SECURITY_ERROR, securityErrorHandler);
                                            loader.addEventListener(HTTPStatusEvent.HTTP_RESPONSE_STATUS, httpResponseStatusHandler);
                                            loader.addEventListener(IOErrorEvent.IO_ERROR, ioErrorHandler);
                                            var urlRequest:URLRequest = new URLRequest(requestTokenUrl);
                                            loader.load(urlRequest);
                                  protected function requestTokenHandler(event:Event):void
                                  protected function httpResponse(event:HTTPStatusEvent):void
                                            label.text += event.status;
                                            // TODO Auto-generated method stub
                                  private function completeHandler(event:Event):void {
                                            label.text += event.toString();
                                            trace("completeHandler data: " + event.currentTarget.data);
                                  private function openHandler(event:Event):void {
                                            trace("openHandler: " + event);
                                  private function onError(event:ErrorEvent):void {
                                            trace("onError: " + event.type);
                                  private function onAsyncError(event:AsyncErrorEvent):void {
                                            trace("onAsyncError: " + event);
                                  private function onNetStatus(event:NetStatusEvent):void {
                                            trace("onNetStatus: " + event);
                                  private function progressHandler(event:ProgressEvent):void {
                                            trace("progressHandler loaded:" + event.bytesLoaded + " total: " + event.bytesTotal);
                                  private function securityErrorHandler(event:SecurityErrorEvent):void {
                                            trace("securityErrorHandler: " + event);
                                  private function httpStatusHandler(event:HTTPStatusEvent):void {
                                            //label.text += event.responseHeaders.toString();
                                            trace("httpStatusHandler: " + event);
                                  private function httpResponseStatusHandler(event:HTTPStatusEvent):void {
                                  private function ioErrorHandler(event:IOErrorEvent):void {
                                            label.text += event.text;
                                            trace("ioErrorHandler: " + event);
              </fx:Script>
              <fx:Declarations>
                        <!-- Place non-visual elements (e.g., services, value objects) here -->
              </fx:Declarations>
              <s:Label id="label" y="185" width="100%" color="#0A0909" horizontalCenter="0" text=""/>
    </s:View>
    Jan 9, 2012 1:02 AM   in reply to tolga_erdogus
    Hi Chris Campbell,
    I am using Flash Builder 4.6/AIR 3.1.0. I am using RESTful web service to get XML results and to display on my mobile application. I am getting the same below error when accessing the webservice from mobile app (Android - Galaxy Tab 7 inch).
    Error: [IOErrorEvent type="ioError" bubbles=false cancelable=false eventPhase=2 text="Error # 2032"] URL: http://adfdevp.alshaya.com:7013/RESTEmployeeDetails-http://adfdevp.alshaya.com:7013/RESTEmployeeDetails-EmployeeDetails-co ntext-root/jersey/restlabEmployeeDetails-context-root/jersey/restlab
    The same code is working in Flash Builder 4.6 Android emulator. I have checked Network Monitor to "Disabled" before deploying to mobile. What am i doing wrong here? I am pasting my code below-
      xmlns:s="library://ns.adobe.com/flex/spark" title="HomeView" xmlns:dao="dao.*"
      xmlns:mx="library://ns.adobe.com/flex/mx">
    <fx:Script>
      <![CDATA[
       import mx.collections.ArrayCollection;
       import mx.collections.IList;
       import mx.collections.XMLListCollection;
       import mx.rpc.events.FaultEvent;
       import mx.rpc.events.ResultEvent;
       import mx.rpc.xml.SimpleXMLDecoder;
       import mx.utils.ArrayUtil;
       import valueObjects.EmployeeDetail;
       [Bindable]
       private var myXml:XML;
       [Bindable]
       public var resultCollection:IList;
       public function handleXml(event:ResultEvent):void
        var xmlListCollection:XMLListCollection = new XMLListCollection(event.result.children());
        var xmlListCollectionValues:XMLListCollection = new XMLListCollection(event.result.emp.children());
        var resultArray:Array = xmlListCollection.toArray();
        var resultArrayValues:Array = xmlListCollectionValues.toArray();
        var objEmployeeDetails:EmployeeDetail;
        var resultCollection:ArrayCollection = new ArrayCollection();
        var j:int = 0;
        for(var i:int=0;i<resultArray.length;i++){
         objEmployeeDetails = new EmployeeDetail();
         objEmployeeDetails.brand = resultArrayValues[j];
         objEmployeeDetails.division = resultArrayValues[j+1];
         objEmployeeDetails.email = resultArrayValues[j+2];
         objEmployeeDetails.employee_name = resultArrayValues[j+3];
         objEmployeeDetails.employee_number = resultArrayValues[j+4];
         objEmployeeDetails.grade = resultArrayValues[j+5];
         objEmployeeDetails.mobile = resultArrayValues[j+6];
         objEmployeeDetails.position = resultArrayValues[j+7];
         j = j + 8;
         resultCollection.addItem(objEmployeeDetails);
        list.dataProvider = resultCollection;
        //return resultCollection;
       public function handleFault(event:FaultEvent):void
        //Alert.show(event.fault.faultDetail, "Error");
       protected function sesrchEmployee():void
        xmlRpc.send();
    </fx:Script>
    <fx:Declarations>
      <dao:EmployeeDAO id="srv"/>
      <mx:HTTPService id="xmlRpc"
          url="http://adfdevp.alshaya.com:7013/RESTEmployeeDetails-EmployeeDetails-co ntext-root/jersey/restlab"
          result="handleXml(event)"
          fault="handleFault(event)"
          resultFormat="e4x" showBusyCursor="true">
       <mx:request xmlns="">
        <data>{key.text}</data>
        <data>{key1.text}</data>
       </mx:request>
      </mx:HTTPService>
    </fx:Declarations>
    <s:navigationContent/>
    <s:titleContent>
      <s:VGroup width="100%">
      <s:HGroup width="100%">
       <s:Label top="40" paddingTop="10" paddingRight="13" height="29" text="Employee Name:"/>
       <s:TextInput id="key" width="559"/>
      </s:HGroup>
       <s:Label height="30" paddingTop="10" text="Employee Number:"/>
       <s:TextInput id="key1" width="100%"/>
      </s:HGroup>
      </s:VGroup>
    </s:titleContent>
    <s:actionContent>
      <s:Button icon="@Embed('assets/search.png')" click="sesrchEmployee()"/>
    </s:actionContent>
    <s:List id="list" top="0" bottom="0" left="0" right="0"
       change="navigator.pushView(EmployeeDetails, list.selectedItem)">
      <s:itemRenderer>
       <fx:Component>
        <s:IconItemRenderer label="{data.employee_name}"
             messageField="position">
        </s:IconItemRenderer>
       </fx:Component>
      </s:itemRenderer>
    </s:List>
    </s:View>
    Appreciate your quick response in this regard.
    Murtaza Ghodawala
    Mobile: +965 97180549
    murtaza.ghodawala@alshaya.com
  • Chris Campbell
    May 4, 2010
    Jan 9, 2012 5:25 PM   in reply to Murtaza_Ghodawala
    Hi Murtaza and tolga,
    Could you both create new bugs (and please include the sample code you've added here) over at bugbase.adobe.com?  Please post back with the bug URL's once they've been created.  I encourage anyone else running into these problems to please visit the bug and vote/comment as appropriate.
    Chris
    Jan 9, 2012 11:27 PM   in reply to Chris Campbell
    Hi Chris,
    Please find the below bug URL -
    https://bugbase.adobe.com/index.cfm?event=bug&id=3083203
    Appreciate your quick response in fixing this issue as soon as possible. Thanks.
    Murtaza Ghodawala
    murtaza_ghoda82@hotmail.com
    Jan 10, 2012 6:52 AM   in reply to Chris Campbell
    Chris - I had already created one: https://bugbase.adobe.com/index.cfm?event=bug&id=3082218
    Though - i must say that this is a type of error that seems to be happening with a lot of people (on and off with some potential fixes and regressions since 2.X) and is in the URLLoader network stack.  It basically is in the critical path of any internet based Air app.
    Call me crazy, but I would say this bug is critical enough to just skip a democratized vote process and fix ASAP.  And in all honesty, there isn't enough Adobe activity in the forums for people to keep the faith and come back to vote for bugs.  From the outside, just by looking at the Adobe employee activity in forums, there seems to be a "pause" of Adobe Air right now.  It is sad because it is by far the coolest and most productive cross platform/device development environment. I am barely hanging on to the idea of building an Air app even though it is so poweful. I made a tremendous amount of progress in the first 3 days of starting to build my app and it has been on hold for 2 weeks after that.
    Apr 7, 2012 2:34 PM   in reply to ShinyaArao
    You may need to add an "anti cache" var like this:
    requestServer = new URLRequest("http://www.example.com/yourfile.xml?nocache=" + new Date().getTime());
    Hope this helps.
    May 23, 2012 3:42 PM   in reply to blogtom
    I'd been getting similar https and urlloader-related #2032 errors, but they seem fixed when I compile with AIR 3.3 from the Adobe Labs site (in conjunction with Flex 4.6).
    Nov 8, 2012 4:39 AM   in reply to banzai76_
    I too get this error on FB 4.6 + AIR 3.5. Trying to get this working on iPad 5.1. Also tested on iOS 6.0 device. No luck.
    My code is simple:
    loader.addEventListener(IOErrorEvent.IO_ERROR, IOErrorHandler, false, 0, true);
    var request:URLRequest = new URLRequest("https://somedomain/loginUser.jsp");
    request.manageCookies = true;
    var vars:URLVariables = new URLVariables("userName=" + usn + "&pword=" + pwd + "&LOGIN=LOGIN&operation=CPLOGIN");
    request.data = vars;
    loader.load(request);
    This code works on iPad emulator but not on iPad itself.
    Any help will be appreciated.
    My Best,
    Suat
    EDIT: I am also getting:
    IDS_CONSOLE_SANDBOX
    IDS_CONSOLE_NOT_PERMITTED
    Nov 8, 2012 6:50 AM   in reply to Suat Korkmaz
    Do you have a valid security certificate for the domain of the URL you are calling? If you don't, it will fail. This is a known AIR for iOS bug.
    If you can use the same code to successfully download a file from that domain using http (not https), then this would likely be the explanation.
    Nov 8, 2012 9:21 AM   in reply to banzai76_
    Thank you for your reply.
    I added an image file to the root of the domain and downloaded it. No problems.
    We debug'ed the backend side. The loginUser.jsp file clearly returns 302 status with a redirection url but I receive this as an ioError. This is totally strange.
    AFAIK the cert I use is valid. A few developers are using it with no problems but of course this dows not mean that it is valid. I'll check it.
    I don't know what to do next.
    Any further help will be appreciated too.
    My Best,
    Suat
    Nov 9, 2012 2:50 AM   in reply to Suat Korkmaz
    I would suggest as next steps:
    1. Download that image file again, this time using https. If that works then you know that there are no security problems.
    2. If possible, submit the login details directly to whatever URL you are trying to redirect to, and see if that works?
    Nov 9, 2012 3:35 AM   in reply to banzai76_
    1. I downloaded the file with https with success. No problems at all.
    2. I tried this. Result is the same. ioError.
    Thanks again.
    Nov 9, 2012 4:03 AM   in reply to Suat Korkmaz
    The last post says that https calls are not allowed in Adobe Air. Tell me that it is not true.
    http://stackoverflow.com/questions/10249793/problems-with-https-on-ipa d-from-air-app
    Nov 9, 2012 4:19 AM   in reply to Suat Korkmaz
    That isn't true.
    HTTPS is supported in AIR, including on iOS. I'm using it in development right now with exactly the same code as you. There are live apps in the itunes app store that use it, but there also a lot of posts around like this one where people are having trouble.
    In the test where you submitted data directly to the redirected url, can you see what the server log says it is returning? i.e. does it it receive the request and respond correctly?
    I'm out of ideas really. Maybe you could it on an android phone and try it from a swf hosted on the website? Just to see if the code works in those situations?
    Nov 9, 2012 6:01 AM   in reply to banzai76_
    I didin't like it but i soved the issue another way. I created a StageWebView and moved it outside the stage. Made the https call with it and thats all. Cookie created. All other services are now accessible.
    Thanks for your help banzai. I'm appreciated.
    Nov 13, 2012 1:13 AM   in reply to chris_emerson
    My previous problem was similar like what you've had, and finally today the problem is solved!
    I simply replace File.documentsDirectory.resolvePath("blablabla").nativePath into File.documentsDirectory.resolvePath("blablabla").url
    Nov 13, 2012 3:07 AM   in reply to Fathah Noor
    Can you please post the whole code?
    Nov 13, 2012 4:00 AM   in reply to Suat Korkmaz
    I think our problem is somewhat different? CMIIW
    I was responding to comments from chris_emerson particularly on this section:
    "I've even tried changing my code to use the File.applicationDirectory approach. But once again,... it only works in the AIR Launcher... not on the device!"
    Sep 18, 2013 3:03 AM   in reply to Murtaza_Ghodawala
    I know it's quite a late reply but I'll just add the following for future reference.
    I was having a very similar problem but with a desktop app, one specific request I'd used for a long time stopped working and I would always get the generic 2032 error.
    This was with a standalone Air app, using 3.1. After going through tons of posts and trying to figure out what was going on I finally solved it by simply cleaning all caches from my browsers (chrome, safari and firefox). It might seem silly since it's a standalone app but it did work.
    Hope it may help someone with this problem.
    Dec 26, 2013 8:26 PM   in reply to Chris Campbell
    Vote? for a bug fix? How about just fix it?  Still present in 3.9.
    Air is dead. The pace of bug fixes and features has slowed to a crawl.
1 2 Previous Next
Actions
