Popup Windows. (Buttons & MSO Question.)
Dec 1, 2011 4:41 PM
My question is in regards to "Buttons" and "MSO's".
     I have Multi-State Object (Popup) windows mastered using the technique giving by Bob Bringhust, http://blogs.adobe.com/indesigndocs/2010/12/hot-spot-button-workaround -for-indesign-dig-pubs.html using buttons and MSO's but my question is this.  Can you make it so the buttons behind a MSO (Popup) are not active?  Even in Bob's example above you can click on the each button while they are hidden behind the popup window.  You can not see the buttons behind the popup but they are still active and this is my problem.
     I have a nice 3 by 4 row of images, all buttons, they are linked to a MSO and when the MSO (Popup) is open you can still accidentally hit any of the hidden buttons behind the MSO.  I have tried several things to solve this problem without any luck.  It doesn't matter where the MSO and buttons are in a layer structure, top or bottom makes no difference.  I have tried to make each layer in the MSO a button so as to supersede the 3 by 4 row of buttons behind but as far as I can tell buttons do not work inside of a MSO so that did not work.  I tried making the "close" button as large as the MSO (Popup) but this just made all the images of the 3 by 4 not work.  I guess you can not have a button over a button.
At this point I have run out of ideas so I have come here seeking knowledge.  Any thoughts or solutions would be greatly appreciated.
Sincerely,
Ryan.
  • Bob Bringhurst
    May 29, 2007
    Dec 1, 2011 6:06 PM   in reply to Ryan A. SGS
    If I understand what you're trying to do, you can't do that with the current set of tools. Buttons appear on top of the slideshow regardless of their stack order, and you can't make a button inactive when you change states.
    What you need is the ability to add buttons to slideshow states. If all goes according to plan -- and it's looking good so far -- the next release of tools in January will let you add buttons and perhaps other interactive overlays to slideshow states.
    Dec 1, 2011 6:18 PM   in reply to Bob Bringhurst
    That would be a major upgrade.
    Bob
    Dec 2, 2011 2:30 AM   in reply to Bob Levine
    Totally agree, modes in modes will absolutely be a good addition.
    Are there any info on what's to be expected in the next releases? A roadmap?
    best regards,
    Bjørn Helge
    Dec 2, 2011 6:12 AM   in reply to Ryan A. SGS
    You can do this with HTML5 (try the free Adobe Edge beta).  You first frame could have the thumbnails.  Tap one and you're brought to a frame with just the image you need.
    Dec 2, 2011 6:18 AM   in reply to landrvr1
    Thanks, I will try that. Since I got your attention, do you know if all HTML5 created in Edge will work, or are there any known limitations?
    Dec 2, 2011 11:47 AM   in reply to Ryan A. SGS
    Maybe Quark has more features but I doubt is easier. Nothing is easy with Quark, my friend :-)
    Dec 3, 2011 7:10 AM   in reply to Bjorn Helge Lervag
    Bjorn, I don't know of any limitations....  I believe this really has to do with iOS being HTML5 compatible across the board.  If there's some new HTML5 process that iOS doesn't support, it won't work in the folio.  I'd check with the Edge forum on that as well just to be sure.
    Dec 3, 2011 7:14 AM   in reply to Ryan A. SGS
    Ryan Ackley SGS wrote:
    Hate Quark if you must but in all seriousness Quarks 9's digital publishing features are about 100x easier.  The difference could be compared to building in Flash to Edge, or coding straight HTML to using Dreamweaver as far as ease is concerned.  Comparing the two feels more like Quark really took the time to build something from scratch where as Adobe's feels more like an after thought that they are still refining, which they are.  Don't get me wrong thought I still love Adobe but they should learn from what Quark has done as well.
    Ryan Ackley
    Simon Golub and Sons Inc.
    Graphic Designer / Marketing
    Local: 206-762-4800 ext. 312
    Toll Free: 800-426-7125
    www.simongolub.com<http://www.simongolub.com/>
    P Save Trees. Print only when necessary.
    Heh.  I'm not saying I don't believe you, but those comparisons are pretty severe....HTML coding vs Dreamweaver?  Surely Quark's workflow and technique cannot be that far in advance of InDesign/DPS?  (I find the entire workflow methodology in DPS to be pretty simple and straightforward....a bit hamfisted perhaps, but still easy to use.)
    Dec 3, 2011 9:18 AM   in reply to landrvr1
    I can tell from expierence that Quarks tools are indeed simpler and well thought out more. Its Aquafadus in fact with a Quark shell. Its simple, elegant and has more options then DPS. Sadly..
    Dec 3, 2011 1:31 PM   in reply to Ryan A. SGS
    Just a quick comment; publishing to tablets is a revolution. Not only
    traditional print to digital magazine, but all of interactive sales
    presentations can now be delivered to tablets, a format that clients really
    wants and that we know is a preferred solution.
    Adobe has a solid position with all their amazing tools for media creation,
    however better solutions with better widgets and easier production flow
    towards tablets will attract new adapting users.
    I believe that with partners like Woodwing and promises of new
    functionality early next year, Adobe will strengthen DPS as preferred
    solution. However Adobe needs to exceed competitors to keep their position.
    We're working with projects and clients that wants their solutions today.
    Best regards,
    Bjørn Helge
    Sendt fra min iPhone
    Den 3. des. 2011 kl. 22:07 skrev Ryan Ackley SGS <forums@adobe.com>:
       Re: Popup Windows. (Buttons & MSO Question.)  created by Ryan
    Ackley SGS<http://forums.adobe.com/people/RyanAckleySGS>in
    Digital Publishing Suite - View the full
    discussion<http://forums.adobe.com/message/4061815#4061815
