Aball2
Browser "Can't find file"
Dec 2, 2011 12:11 PM
I am using CF8 on 2003 Windows Server.
I have a file, let's call it "ABC.cfm".  Everything is working fine with this file.
I have updated the code in the file and renamed "ABC.cfm" to "ABCold.cfm".   I think saved a new file called "ABC.cfm" and moved it the location where the original "ABC.cfm" file was and I get an error in the browsers (Firefox and IE) that basically says it can't find the file.  If I rename "ABCold.cfm" back to "ABC.cfm" it finds the file.
Any idea why the browsers can not find the renamed file but can find the same file by the original name?
    Dec 2, 2011 12:15 PM   in reply to Aball2
    Are you sure of the case of that file is exactly the same?  Are you sure
    you are uploading it to the right folder?
    Dec 2, 2011 12:24 PM   in reply to Aball2
    And the error you get is a 404 error or some other error?  Like a cfinclude
    cannot find template error?
    Dec 2, 2011 1:11 PM   in reply to Aball2
    Sounds to me like IIS doesn't have sufficient permissions to see the files.  This is a bit odd because I have a feeling that generally file perms are inherited from their directory, not set on the files themselves.  However you should check whether the a/c that IIS is running as has permissions to see the files that aren't being served.
    Adam
    Dec 3, 2011 11:34 AM   in reply to Aball2
    ColdFusion is known to sometimes masquerade its inability to process an error by responding with a page-not-found. To rule this out, perform the following test.
    Comment out all the code on the page, excepting
    Test result: <cfoutput>#now()#</cfoutput>
