We tried to import a 25 minutes video file (format Quicktime, codec H.264) in premiere CS 5.5. The process stops after importing just a couple images (between 2 and 100). The same happend with other files formate.
Do anyone have an idea where the failure could come from ?
Thanks in advance,
Ray
Some reading... and a few questions to answer to give someone enough information to try and help
Read Bill Hunt on a file type as WRAPPER http://forums.adobe.com/thread/440037
What is a CODEC... a Primer http://forums.adobe.com/thread/546811
What CODEC is INSIDE that file? http://forums.adobe.com/thread/440037
Report back with the codec details of your file, use the programs below
For PC http://www.headbands.com/gspot/ or http://mediainfo.sourceforge.net/en
For Mac http://mediainfo.massanti.com/
http://blogs.adobe.com/premiereprotraining/2011/02/red-yellow-and-gree n-render-bars.html
Once you know exactly what it is you are editing, report back with that information... and your project setting, and if there is a red line above the video in the timeline, which indicates a mismatch between video and project
More information needed for someone to help http://forums.adobe.com/thread/416679
Some is general about your computer and OS, some is specific to video editing
Build a Configuration file http://www.piriform.com/speccy
Brand/Model Computer (or Brand/Model Motherboard if self-built)
How much system memory you have installed, such as 2Gig or ???
Operating System version, such as Win7 64bit Pro... or whatevevr
-including your security settings, such as are YOU the Administrator
-and have you tried to RIGHT click the program Icon and then select
-the Run as Administrator option (for Windows, not sure about Mac)
Your Firewall settings and brand of anti-virus are you running
Brand/Model graphics card, sush as ATI "xxxx" or nVidia "xxxx"
-or the brand/model graphics chip if on the motherboard
-and the exact driver version for the above graphics card/chip
-and how much video memory you have on your graphics card
Brand/Model sound card, or sound "chip" name on Motherboard
-and the exact driver version for the above sound card/chip
Size(s) and configuration of your hard drive(s)... example below
-and how much FREE space is available on each drive (in Windows
-you RIGHT click the drive letter while using Windows Explorer
-and then select the Properties option to see used/free space)
Windows Indexing is BAD http://forums.adobe.com/thread/676303
While in Properties, be sure you have drive indexing set OFF
-for the drive, and for all directories, to improve performance
Some/Much of the above are available by going to the Windows
Control Panel and then the Hardware option (Win7 option name)
OR Control Panel--System--Hardware Tab--Device Manager for WinXP
And the EXACT type and size of file that is causing you problems
-for pictures, that includes the camera used and the pixel dimensions
Plus Video-Specific Information http://forums.adobe.com/thread/459220
Read Bill Hunt on editing a VOB/MPG file http://forums.adobe.com/thread/464549
Edit Vob http://premierepro.wikia.com/wiki/FAQ:How_do_I_import_VOB_files_/_edit _a_DVD%3F
Read Hunt on Using MOD/TOD files http://forums.adobe.com/thread/699990
Work through all of the steps (ideas) listed at http://forums.adobe.com/thread/459220
If your problem isn't fixed after you follow all of the steps, report back with ALL OF THE DETAILS asked for in the FINALLY section at the troubleshooting link
Also read file troubleshooting http://kb2.adobe.com/cps/407/kb407928.html
