m4v file needs transcoding in Blu-ray project
Nov 30, 2011 7:57 PM
m4v is produced by Media Encoder
However, when imported into Encore, it's shown as untranscoded.  When I try to build, it will start transcoding process.
What's causing this?
    Nov 30, 2011 8:35 PM   in reply to Howard Hoffman
    What is your max datarate in the project setting?
    A perhaps related thread:
    http://forums.adobe.com/message/4043414#4043414
    Dec 1, 2011 2:13 AM   in reply to Howard Hoffman
    There seems to be a bug in Encore ( i have not encountered it yet) with the vbr 2pass.
    Set VBR to 1 pass, see how that works out.
    Dec 1, 2011 5:40 AM   in reply to Ann Bens
    I agree with Ann, since nothing else is working. Jeff has posted elsewhere (I linked part of it) suggesting that the VBR 2 pass is only an issue in High profile? And Ann, you are using VBR 2 pass without problem?
    Dec 1, 2011 6:40 AM   in reply to Stan Jones
    Yes with high profile, tried different settings also in ntsc (as i am on pal), I have never seen this issue.
    Nor in CS5 or CS4.
    Dec 1, 2011 10:45 AM   in reply to Howard Hoffman
    Well set it to high and try again.
    Dec 3, 2011 1:13 PM   in reply to Howard Hoffman
    Did you use the same name to save the file or did rename.
    On a side note: if something is not working right in Encore I start over in a fresh Encore project. Usually it turns out fine.
    Dec 3, 2011 1:29 PM   in reply to Howard Hoffman
    I've tried the 30 second and it works just fine.
    Do you mean you have tried a short, 30 second segment using those settings and it works?
    Dec 3, 2011 1:58 PM   in reply to Howard Hoffman
    I would go for 5 minutes.
    What preset are you starting with; how are you changing it?
    Dec 3, 2011 3:33 PM   in reply to Howard Hoffman
    I always go through AME never seen this.
    Check for gaps, they can cause 'weird' behaviour.
    Dec 4, 2011 7:26 PM   in reply to Howard Hoffman
    Let's assume there is corruption in the clip. That would be good troubleshooting. The b1 - b4 having no error in any of them is odd.
    Unusual, but I have had to go back and recapture.
    I don't see that we asked: what is the source?
    Dec 5, 2011 1:27 AM   in reply to Howard Hoffman
    You do not need a 'joiner' you can put all the pieces in one Encore timeline.
    Jan 4, 2012 7:19 AM   in reply to Howard Hoffman
    This has to be a bug in AME CS5.5, having the same exact problem:
    http://forums.adobe.com/message/4117565
    Anyway, I have CS5 installed on my Windows partition and tried adding the .m4v file to Encore CS5 and Encore still wanted to transcode it which leads me to believe that it's a problem with the encode using AME.
    I was able to open my Premiere CS5.5 project in CS5 without an issue so I'm going to just have to encode using AME CS5 under my Windows partition until Adobe issues a patch for this extremely inconvienient problem.
    There are few things more frustrating than sitting through an eight hour encode only to learn Encore wants to do that again when you know it shouldn't have to.
    Jan 4, 2012 4:10 PM   in reply to Howard Hoffman
    So basically encode VBR 1-Pass or wait for the fix.
    That seems crazy to me but whatcha gonna do?
