Hello Geeks,
Need your help on solving the below issue.
Am using Adobe Livecycle Workbench ES2 for creating a Process.
The requirement is to Add a Child Node to the XML.
<helpUrls>
<HelpUrl>
<Name>BugReport</Name>
<url>C:\BugRep.exe</url>
</HelpUrl>
</helpUrls>
Need to add Child Node
<helpUrls>
<HelpUrl>
</HelpUrl>
<HelpUrl>
<Name>IssueReport</Name>
<url>C:\IssueRep.exe</url>
</HelpUrl>
</helpUrls>
The Schema Looks as below
<xs:element name="helpUrls">
<xs:complexType>
<xs:sequence maxOccurs="unbounded">
<xs:element name="HelpUrl">
<xs:complexType>
<xs:element name="Name" type="xs:string" />
<xs:element name="url" type="xs:string" />
</xs:sequence>
</xs:complexType>
</xs:element>
</xs:sequence>
</xs:complexType>
</xs:element>
Thanks in advance
Regards
Darsh
Total Likes
This you cannot do in a direct way.
You can add the node <HelpUrl with a different name for example <TempUrl> and then rename the tag name into HelpUrl using XSLT activity. Otherwise the latest node will overwrite the existing HelpUrl node.
Nith
Total Likes
Hello Nith,
Loads of thanks for you suggestions.. Am not that good in XLST, can you let me know how can i go about renaming the Tags Process Design.
Darsh
Total Likes
A Sample XM File after adding a <temp> tag would look like:
<root><HelpUrl>some URL1</HelpUrl><HelpUrl>some URL2</HelpUrl><temp>New URL</temp></root>
The XSL used to rename the above XML is as follows:
<?xml version="1.0"?>
<xsl:stylesheet version="1.0"
xmlns:xsl="http://www.w3.org/1999/XSL/Transform">
<xsl:template match="/">
<root>
<xsl:for-each select="root/HelpUrl">
<HelpUrl>
<xsl:value-of select="."/>
</HelpUrl>
</xsl:for-each>
<xsl:for-each select="root/temp">
<HelpUrl>
</HelpUrl>
</xsl:for-each>
</root>
</xsl:template>
</xsl:stylesheet>
I hope you can understand from the above example on how to rename a tag using XLST.
Send me your email address so that I can send you the sample process I tried for you.
Nith
Total Likes
