Locked
Cannot open Flash Builder 4.5 after updating
Sep 15, 2011 Sep 15, 2011
I have a corporate version of CS5.5 installed on 32bit machine.
Recently, Flash Builder notified me of an available update. It was for some Java but since Eclipse is Java Based I intalled it.
Now when I open it, it freezes on the splash screen. Without closing it, I open a new one. It asks for a new workspace since old used, I gave it new one. Still stuck on splash screen. Tried restarting computer. Now when I open Flash Builder, it is not stuck on splash page but and error popups and program exits. The popup tells me to look at a log file.
Here is the log file contents
!SESSION 2011-09-15 11:03:52.113 ----------------------------------------------- eclipse.buildId=M20110210-1200 java.version=1.6.0_16 java.vendor=Sun Microsystems Inc. BootLoader constants: OS=win32, ARCH=x86, WS=win32, NL=en_US Command-line arguments:  -os win32 -ws win32 -arch x86 !ENTRY org.eclipse.osgi 4 0 2011-09-15 11:03:53.844 !MESSAGE Application error !STACK 1 org.eclipse.swt.SWTError: No more handles      at org.eclipse.swt.SWT.error(SWT.java:4109)      at org.eclipse.swt.SWT.error(SWT.java:3998)      at org.eclipse.swt.SWT.error(SWT.java:3969)      at org.eclipse.swt.widgets.Widget.error(Widget.java:468)      at org.eclipse.swt.widgets.Control.createHandle(Control.java:633)      at org.eclipse.swt.widgets.Composite.createHandle(Composite.java:305)      at org.eclipse.swt.widgets.Control.createWidget(Control.java:649)      at org.eclipse.swt.widgets.Scrollable.createWidget(Scrollable.java:134)      at org.eclipse.swt.widgets.Control.<init>(Control.java:110)      at org.eclipse.swt.widgets.Scrollable.<init>(Scrollable.java:75)      at org.eclipse.swt.widgets.Composite.<init>(Composite.java:95)      at org.eclipse.ui.splash.BasicSplashHandler.getBundleProgressMonitor(BasicSplashHandler.java:159)      at org.eclipse.ui.splash.BasicSplashHandler.getContent(BasicSplashHandler.java:265)      at org.eclipse.ui.internal.splash.EclipseSplashHandler.init(EclipseSplashHandler.java:86)      at org.eclipse.ui.internal.Workbench$8.run(Workbench.java:782)      at org.eclipse.core.runtime.SafeRunner.run(SafeRunner.java:42)      at org.eclipse.ui.internal.Workbench.createSplashWrapper(Workbench.java:798)      at org.eclipse.ui.internal.Workbench.runUI(Workbench.java:2467)      at org.eclipse.ui.internal.Workbench.access$4(Workbench.java:2438)      at org.eclipse.ui.internal.Workbench$7.run(Workbench.java:671)      at org.eclipse.core.databinding.observable.Realm.runWithDefault(Realm.java:332)      at org.eclipse.ui.internal.Workbench.createAndRunWorkbench(Workbench.java:664)      at org.eclipse.ui.PlatformUI.createAndRunWorkbench(PlatformUI.java:149)      at com.adobe.flexbuilder.standalone.FlashBuilderApplication.start(FlashBuilderApplication.java:108)      at org.eclipse.equinox.internal.app.EclipseAppHandle.run(EclipseAppHandle.java:196)      at org.eclipse.core.runtime.internal.adaptor.EclipseAppLauncher.runApplication(EclipseAppLauncher.java:110)      at org.eclipse.core.runtime.internal.adaptor.EclipseAppLauncher.start(EclipseAppLauncher.java:79)      at org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseStarter.java:369)      at org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseStarter.java:179)      at sun.reflect.NativeMethodAccessorImpl.invoke0(Native Method)      at sun.reflect.NativeMethodAccessorImpl.invoke(Unknown Source)      at sun.reflect.DelegatingMethodAccessorImpl.invoke(Unknown Source)      at java.lang.reflect.Method.invoke(Unknown Source)      at org.eclipse.equinox.launcher.Main.invokeFramework(Main.java:619)      at org.eclipse.equinox.launcher.Main.basicRun(Main.java:574)      at org.eclipse.equinox.launcher.Main.run(Main.java:1407)
Edit - found another thread with similar issue but still no solution.
Installation and activation
3.3K
Oct 23, 2011 Oct 23, 2011
I'm getting the same problem, have you heard of or found a fix for this issue yet?
Dec 05, 2011 Dec 05, 2011
I am in the same boat now and OH SO HOSED.  Help, Adobe!
Jan 07, 2012 Jan 07, 2012
Hi
Just did a update in FB4.6 and now have above issue.
Any word on this.
Cheers
Jan 25, 2012 Jan 25, 2012
Yes, same here. I just upgraded to FB4.6 and now am having this problem. A solution would be great to see.
Guest
Apr 25, 2012 Apr 25, 2012
Hello, I'm having the same issue with Flash Builder 4.6.
I got it off freeriatools.adobe.com, after installing I tried to open it and it said "An unexpected runtime error occured : No more handles" with the following errors in the log file :
!SESSION 2012-04-25 20:40:19.812 -----------------------------------------------
eclipse.buildId=I20100608-0911
!ENTRY org.eclipse.ui 2 0 2012-04-25 20:40:36.702
!MESSAGE Warnings while parsing the commands from the 'org.eclipse.ui.commands' and 'org.eclipse.ui.actionDefinitions' extension points.
!SUBENTRY 1 org.eclipse.ui 2 0 2012-04-25 20:40:36.702
!MESSAGE Commands should really have a category: plug-in='com.qnx.flashbuilder.multiplatform.qnx.ui', id='com.qnx.flashbuilder.multiplatform.qnx.ui.commands.OpenInfoCenter', categoryId='com.qnx.flashbuilder.multiplatform.qnx.ui.commands.category.help'
!ENTRY org.eclipse.osgi 4 0 2012-04-25 20:40:37.412
!MESSAGE An unexpected runtime error has occurred.
!STACK 0
    at org.eclipse.swt.SWT.error(SWT.java:4308)
    at org.eclipse.swt.SWT.error(SWT.java:4197)
    at org.eclipse.swt.SWT.error(SWT.java:4168)
    at org.eclipse.swt.widgets.TaskBar.createHandle(TaskBar.java:103)
    at org.eclipse.swt.widgets.TaskBar.<init>(TaskBar.java:96)
    at org.eclipse.swt.widgets.Display.getSystemTaskBar(Display.java:2564)
    at org.eclipse.ui.internal.Workbench$TaskBarDelegatingProgressMontior.getTaskItem(Workbench.java:303)
    at org.eclipse.ui.internal.Workbench$TaskBarDelegatingProgressMontior.handleTaskBarProgressUpdated(Workbench.java:319)
    at org.eclipse.ui.internal.Workbench$TaskBarDelegatingProgressMontior.worked(Workbench.java:268)
    at org.eclipse.ui.internal.Workbench$StartupProgressBundleListener.bundleChanged(Workbench.java:420)
    at org.eclipse.osgi.framework.internal.core.BundleContextImpl.dispatchEvent(BundleContextImpl.java:847)
    at org.eclipse.osgi.framework.eventmgr.EventManager.dispatchEvent(EventManager.java:230)
    at org.eclipse.osgi.framework.eventmgr.ListenerQueue.dispatchEventSynchronous(ListenerQueue.java:148)
    at org.eclipse.osgi.framework.internal.core.Framework.publishBundleEventPrivileged(Framework.java:1522)
    at org.eclipse.osgi.framework.internal.core.Framework.publishBundleEvent(Framework.java:1458)
    at org.eclipse.osgi.framework.internal.core.Framework.publishBundleEvent(Framework.java:1453)
    at org.eclipse.osgi.framework.internal.core.BundleHost.startWorker(BundleHost.java:391)
    at org.eclipse.osgi.framework.internal.core.AbstractBundle.start(AbstractBundle.java:299)
    at org.eclipse.osgi.framework.util.SecureAction.start(SecureAction.java:440)
    at org.eclipse.osgi.internal.loader.BundleLoader.setLazyTrigger(BundleLoader.java:268)
    at org.eclipse.core.runtime.internal.adaptor.EclipseLazyStarter.postFindLocalClass(EclipseLazyStarter.java:107)
    at org.eclipse.osgi.baseadaptor.loader.ClasspathManager.findLocalClass(ClasspathManager.java:462)
    at org.eclipse.osgi.internal.baseadaptor.DefaultClassLoader.findLocalClass(DefaultClassLoader.java:216)
    at org.eclipse.osgi.internal.loader.BundleLoader.findLocalClass(BundleLoader.java:400)
    at org.eclipse.osgi.internal.loader.BundleLoader.findClassInternal(BundleLoader.java:476)
    at org.eclipse.osgi.internal.loader.BundleLoader.findClass(BundleLoader.java:429)
    at org.eclipse.osgi.internal.loader.BundleLoader.findClass(BundleLoader.java:417)
    at org.eclipse.osgi.internal.baseadaptor.DefaultClassLoader.loadClass(DefaultClassLoader.java:107)
    at java.lang.ClassLoader.loadClass(Unknown Source)
    at org.eclipse.osgi.internal.loader.BundleLoader.loadClass(BundleLoader.java:345)
    at org.eclipse.osgi.framework.internal.core.BundleHost.loadClass(BundleHost.java:229)
    at org.eclipse.osgi.framework.internal.core.AbstractBundle.loadClass(AbstractBundle.java:1207)
    at org.eclipse.equinox.internal.ds.model.ServiceComponent.createInstance(ServiceComponent.java:480)
    at org.eclipse.equinox.internal.ds.model.ServiceComponentProp.createInstance(ServiceComponentProp.java:271)
    at org.eclipse.equinox.internal.ds.model.ServiceComponentProp.build(ServiceComponentProp.java:332)
    at org.eclipse.equinox.internal.ds.InstanceProcess.buildComponent(InstanceProcess.java:588)
    at org.eclipse.equinox.internal.ds.ServiceReg.getService(ServiceReg.java:53)
    at org.eclipse.osgi.internal.serviceregistry.ServiceUse$1.run(ServiceUse.java:138)
    at java.security.AccessController.doPrivileged(Native Method)
    at org.eclipse.osgi.internal.serviceregistry.ServiceUse.getService(ServiceUse.java:136)
    at org.eclipse.osgi.internal.serviceregistry.ServiceRegistrationImpl.getService(ServiceRegistrationImpl.java:468)
    at org.eclipse.osgi.internal.serviceregistry.ServiceRegistry.getService(ServiceRegistry.java:467)
    at org.eclipse.osgi.framework.internal.core.BundleContextImpl.getService(BundleContextImpl.java:594)
    at org.osgi.util.tracker.ServiceTracker.addingService(ServiceTracker.java:450)
    at org.osgi.util.tracker.ServiceTracker$Tracked.customizerAdding(ServiceTracker.java:980)
    at org.osgi.util.tracker.ServiceTracker$Tracked.customizerAdding(ServiceTracker.java:1)
    at org.osgi.util.tracker.AbstractTracked.trackAdding(AbstractTracked.java:262)
    at org.osgi.util.tracker.AbstractTracked.trackInitial(AbstractTracked.java:185)
    at org.osgi.util.tracker.ServiceTracker.open(ServiceTracker.java:348)
    at org.osgi.util.tracker.ServiceTracker.open(ServiceTracker.java:283)
    at org.eclipse.core.internal.runtime.InternalPlatform.getBundleGroupProviders(InternalPlatform.java:225)
    at org.eclipse.core.runtime.Platform.getBundleGroupProviders(Platform.java:1261)
    at org.eclipse.ui.internal.ide.IDEWorkbenchPlugin.getFeatureInfos(IDEWorkbenchPlugin.java:291)
    at org.eclipse.ui.internal.ide.WorkbenchActionBuilder.makeFeatureDependentActions(WorkbenchActionBuilder.java:1217)
    at org.eclipse.ui.internal.ide.WorkbenchActionBuilder.makeActions(WorkbenchActionBuilder.java:1026)
    at org.eclipse.ui.application.ActionBarAdvisor.fillActionBars(ActionBarAdvisor.java:147)
    at org.eclipse.ui.internal.ide.WorkbenchActionBuilder.fillActionBars(WorkbenchActionBuilder.java:341)
    at org.eclipse.ui.internal.WorkbenchWindow.fillActionBars(WorkbenchWindow.java:3564)
    at org.eclipse.ui.internal.WorkbenchWindow.<init>(WorkbenchWindow.java:419)
    at org.eclipse.ui.internal.tweaklets.Workbench3xImplementation.createWorkbenchWindow(Workbench3xImplementation.java:31)
    at org.eclipse.ui.internal.Workbench.newWorkbenchWindow(Workbench.java:1920)
    at org.eclipse.ui.internal.Workbench.access$14(Workbench.java:1918)
    at org.eclipse.ui.internal.Workbench$21.runWithException(Workbench.java:1202)
    at org.eclipse.ui.internal.StartupThreading$StartupRunnable.run(StartupThreading.java:31)
    at org.eclipse.swt.widgets.RunnableLock.run(RunnableLock.java:35)
    at org.eclipse.swt.widgets.Synchronizer.runAsyncMessages(Synchronizer.java:135)
    at org.eclipse.swt.widgets.Display.runAsyncMessages(Display.java:4140)
    at org.eclipse.swt.widgets.Display.readAndDispatch(Display.java:3757)
    at org.eclipse.ui.application.WorkbenchAdvisor.openWindows(WorkbenchAdvisor.java:803)
    at org.eclipse.ui.internal.Workbench$33.runWithException(Workbench.java:1595)
    at org.eclipse.ui.internal.Workbench.runUI(Workbench.java:2604)
    at org.eclipse.ui.internal.Workbench.access$4(Workbench.java:2494)
    at org.eclipse.ui.internal.Workbench$7.run(Workbench.java:674)
    at org.eclipse.ui.internal.Workbench.createAndRunWorkbench(Workbench.java:667)
    at org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseStarter.java:344)
    at org.eclipse.equinox.launcher.Main.invokeFramework(Main.java:622)
    at org.eclipse.equinox.launcher.Main.basicRun(Main.java:577)
    at org.eclipse.equinox.launcher.Main.run(Main.java:1410)
!ENTRY org.eclipse.ui.workbench 4 0 2012-04-25 20:40:38.511
!MESSAGE FrameworkEvent ERROR
!STACK 0
!ENTRY org.eclipse.osgi 4 0 2012-04-25 20:40:38.974
!STACK 1
    at org.eclipse.ui.internal.WorkbenchWindow.createProgressIndicator(WorkbenchWindow.java:3362)
    at org.eclipse.ui.internal.WorkbenchWindow.createDefaultContents(WorkbenchWindow.java:1130)
    at org.eclipse.ui.internal.WorkbenchWindowConfigurer.createDefaultContents(WorkbenchWindowConfigurer.java:623)
    at org.eclipse.ui.application.WorkbenchWindowAdvisor.createWindowContents(WorkbenchWindowAdvisor.java:300)
    at org.eclipse.ui.internal.WorkbenchWindow.createContents(WorkbenchWindow.java:1036)
    at org.eclipse.jface.window.Window.create(Window.java:431)
    at org.eclipse.ui.internal.Workbench$22.runWithException(Workbench.java:1211)
I was wondering if anyone has found a solution to this problem yet? Because I need this software to work on my laptop in order to start working on my school projects.. Thanks in advance.
