eneego_2011
Robohelp 9.0.1.232 crashes when moving folders
Dec 3, 2011 1:17 PM
Tags: #html #robohelp #crashing #moving #robohelp_9 #rh9
The problem:
  • RH9 has started to crash after i move about the 2nd folder of topics. it can be 1 or more topics in the folder and it still crashes.
  • Upon restart the old location contains the original topics but with broken links; the new location contains just the moved and empty folder.
  • In Windows (on disk) the new location contains the correct files, but requires me to "import" the files or use "tools-->resolve broken links" to fix
  • random folders have been removed from RH9 - but exist on disk
Steps taken:
  1. uninstalled RH7, RH8 & RH9 completely (as RH9 has no "repair" feature which is disheartenting)
  2. Re-installed RH9
  3. Updated to latest version available on Adobe's site
  4. Running correct Service Pack
Questions:
  • Is there a Preferences file I could trash and replace?
  • Has anyone else had this problem?
  • Any ideas?
Thanks in advance.
--bill
    Dec 3, 2011 1:28 PM   in reply to eneego_2011
    Welcome to our community
    Can you please click File > Rename Project and take a screen capture of the dialog you see? Please post the screen capture into this thread using the forum interface.
    Don't actually follow through with the renaming. Just get the dialog open so you can grab it. Then cancel.
    Cheers... Rick
    Helpful and Handy Links
    RoboHelp Wish Form/Bug Reporting Form
    Begin learning RoboHelp HTML 7, 8 or 9 within the day!
    Adobe Certified RoboHelp HTML Training
    SorcerStone Blog
    RoboHelp eBooks
    Dec 3, 2011 1:48 PM   in reply to eneego_2011
    Hello again
    Well frapdoodle!
    I say that because I was fully expecting to see a drive letter other than C in that dialog. (RoboHelp projects are notorious for causing bad things to happen when you store them on the network)
    The only other thing that comes to mind is that perhaps you might try creating a folder closer to the root of the C drive. Perhaps C:\Projects. Then copy your folder to this folder and see how it goes.
    Do any of the files involved use characters other than a-z, A-Z, 0-9 or an underscore? If so, that could cause problems too.
    Cheers... Rick
    SorcerStone Blog
    RoboHelp eBooks
    Dec 4, 2011 12:49 AM   in reply to eneego_2011
    How are you moving the topics?
    Are you doing so via Project Manager (correct) or in Windows Explorer (will cause exactly this problem)?
    @petergrainge
    Dec 4, 2011 7:39 PM   in reply to eneego_2011
    Hi there
    A thought popped into my mind about this. I'm wondering if you could avoid the issue by working as follows:
    Instead of wholesale moving folders, try creating new folders in the desired locations. Then move topics from folder to folder. Once the old folder is empty, delete it.
    Might be worth trying.
    Cheers... Rick
    SorcerStone Blog
    RoboHelp eBooks
    Dec 5, 2011 1:59 AM   in reply to Captiv8r
    Hi ,
            Please try moving the folders with the filters (Show/Hide files) of the Project manager view unchecked.
    The Show/Hide files can be found in the Project manager pod (a funnel shape icon), just leave the "Show topics" checked.
    after every complete move of folder please Save the project, and do not start another move folder until the first move is shown completed.
    But by the symptoms of your problem it seems the .cpd file of your project is not correctly updated.
    Please confirm few things
    1. .fpj file (inside folder) which can be opened in notepad is correctly updated in such inconsistent project.
    2. After fresh upgrade from RH 7 project to RH 9 project delete the .cpd file and reopen project and check that all the folders show up proper content. (there is a possibility that the folder level information (.fpj) are not in sync with project level information (.cpd)) -- oucome of a corrupt project.
    3. Lastly please check the same action on RH 7 itself (assuming the project was upgraded from version RH 7), if the same is crashing in RH 7 itself then the problem is in the project.
    Regards
    Ashish
    Dec 5, 2011 6:45 AM   in reply to RoboAsh
    Hi Ashish
    Question here. Would the same be achieved by toggling the view from Global to Classic and working only within the HTML Files (Topics) pseudo folder?
    Thanks... Rick
    SorcerStone Blog
    RoboHelp eBooks
    Dec 5, 2011 2:21 PM   in reply to eneego_2011
    Hello again
    Keep in mind that I've been using RoboHelp for about 20 years. So with that in mind, it's self evident that I'm very fond of working a different way. When RoboHelp 7 was introduced, it shipped with a new "view" of things that was unfamiliar. This was called "Global view". Fortunately, the development team provided a "Classic" view. That's the view I prefer.
    Call me a stodgy old c00t if you want, but I find this view vastly simpler to use than the "new and improved" globall view.
    Additionally, I believe the default setting for the dialog you see when clicking the funnel icon is to have all options enabled.
    Cheers... Rick
    SorcerStone Blog
    RoboHelp eBooks
    Dec 5, 2011 9:50 PM   in reply to RoboWizard
    Hi Rick,
         My guess was that the update of Project manager was causing the problem and even in the Classic the refresh will be done for all the files if the filter is not on.
    but it seems there is some other problem.
    Will require the project to diagnose the issue
    Regards
    Ashish
    Dec 5, 2011 9:56 PM   in reply to eneego_2011
    Hi Bill,
         can you please share your project so that I can understand the issue and even find a workaround for you.
    Please share the project via senditnow.com or acrobat.com if it large or send a zipped project directly to ashishchandra.gupta@gmail.com.
    If you are able to recreate the issue with a smaller version of the same project with even dummy content then do share it if you cant share the whole project.
    regards
    Ashish
