Hello Geeks,
Need your help on solving the below issue.
Am using Adobe Livecycle Workbench ES2 for creating a Process.
The requirement is to Add a Child Node to the XML.
<helpUrls>
<HelpUrl>
<Name>BugReport</Name>
<url>C:\BugRep.exe</url>
</HelpUrl>
</helpUrls>
Need to add Child Node
<helpUrls>
<HelpUrl>
</HelpUrl>
<HelpUrl>
<Name>IssueReport</Name>
<url>C:\IssueRep.exe</url>
</HelpUrl>
</helpUrls>
The Schema Looks as below
<xs:element name="helpUrls">
<xs:complexType>
<xs:sequence maxOccurs="unbounded">
<xs:element name="HelpUrl">
<xs:complexType>
<xs:element name="Name" type="xs:string" />
<xs:element name="url" type="xs:string" />
</xs:sequence>
</xs:complexType>
</xs:element>
</xs:sequence>
</xs:complexType>
</xs:element>
Thanks in advance
Regards
Darsh
A Sample XM File after adding a <temp> tag would look like:
<root><HelpUrl>some URL1</HelpUrl><HelpUrl>some URL2</HelpUrl><temp>New URL</temp></root>
The XSL used to rename the above XML is as follows:
<?xml version="1.0"?>
<xsl:stylesheet version="1.0"
xmlns:xsl="http://www.w3.org/1999/XSL/Transform">
<xsl:template match="/">
<root>
<xsl:for-each select="root/HelpUrl">
<HelpUrl>
<xsl:value-of select="."/>
</HelpUrl>
</xsl:for-each>
<xsl:for-each select="root/temp">
<HelpUrl>
</HelpUrl>
</xsl:for-each>
</root>
</xsl:template>
</xsl:stylesheet>
I hope you can understand from the above example on how to rename a tag using XLST.
Send me your email address so that I can send you the sample process I tried for you.
Nith
