I am getting the following error when trying to convert an MS Word 2010 document into a PDF using Adobe Acrobat Pro 9.0
%%[ ProductName: Distiller ]%%
Cambria not found, using Courier.
%%[ Error: invalidfont; OffendingCommand: xshow ]%%
Stack:
-dict-
-file-
%%[ Flushing: rest of job (to end-of-file) will be ignored ]%%
%%[ Warning: PostScript error. No PDF file produced. ] %%
Can somone suggest what I can do?
Thanks a lot!
Well acrobat 9 pdf maker is not compatible with ms2010. If you wish to convert office app to pdf you need to use the File > Print to Adobe Pdf Printer as your workflow.
Hope this helps.
This is a postscript error pointing to a font issue in the Word document that you are trying to convert. See if the information here can be of help in troubleshooting your issue:
http://www.prepressure.com/postscript/troubleshooting/errors/invalidfont
Best of luck.
