vcplain
Dynamic Link isn't linking
Jan 19, 2011 7:28 AM
Hello!
I have CS4 suite (student version, meaning it doesn't have all those lovely extra plugins like keylight and mochaAE).
I created a video in Premiere Pro, but some of my footage was shaky so I opened up AE and imported the footage (not the PPro project) and stabilised the footage. Then I tried to import the footage into PPro to replace my old footage, using the drag and drop method. I got an error message saying the dynamic link server is busy.
Looking in the forums for a solution I believe my problem is that I am using footage already in my PPro project. It seems I can only import footage that is not already in PPro. So I deleted the clip from my PPro project, closed and reopened PPro and then tried to drag and drop it, but I get the same error message. I've tried closing and opening the 2 programs in different orders as directed by some of the posts I read in the Adobe forums but still no joy.
Before deleting the footage I tried the method of right clicking the footage in PPro and selecting replace with AE composition, but I got the error message 'Could not connect to AE'.
I don't know what to do next.
Is there anyone who can give me step by step instructions? I am a bit of a novice - frustrated but keen.
Thank you for your time.
Vanessa
    Jan 19, 2011 10:36 AM   in reply to vcplain
    Export the file out of AE instead of using Dynamic Link.
    Jan 19, 2011 8:40 PM   in reply to vcplain
    Reexport with the correct settings.
    Jan 20, 2011 8:00 PM   in reply to vcplain
    Well done.
    A lot of people would have needed hand holding.  Nice to see someone who can take the broad idea and work out the specifics on their own.
    Dec 7, 2011 6:42 AM   in reply to Jim Simon
    Jim, I looked for your answer and all I see is "Reexport with the correct settings"?
    I am having a similar issue between Premium Pro CS5 and Encore CS5
    I created a project and tried to access Encore via dynamic link, but it is grayed our
    so I launched Encore and loaded the project, but the load never finished even after several hours, it just "hangs"
    The only export that is not grayed out is "AAF & Final Cut"
    Can you please help me with the correct settings?
    Dec 7, 2011 10:08 AM   in reply to BlazfromTexas
    Describe specifically what you're trying to do here.
    Dec 7, 2011 12:10 PM   in reply to BlazfromTexas
    Post a screen shot of what you see when you try to export - Forum Tutorials http://forums.adobe.com/docs/DOC-1021
    What happens with Encore if you import video files and not a PPro project?
    A "simple project" step-by-step Tutorial for Encore (Not Dynamic Link)
    - once you've done a simple project, the user guide has lots more
    - http://www.pacifier.com/~jtsmith/Encore.txt
    Read Bill Hunt on a file type as WRAPPER http://forums.adobe.com/thread/440037
    What is a CODEC... a Primer http://forums.adobe.com/thread/546811
    What CODEC is INSIDE that file? http://forums.adobe.com/thread/440037
    Report back with the codec details of your file, use the programs below
    For PC http://www.headbands.com/gspot/ or http://mediainfo.sourceforge.net/en
    For Mac http://mediainfo.massanti.com/
    http://blogs.adobe.com/premiereprotraining/2011/02/red-yellow-and-gree n-render-bars.html
    Once you know exactly what it is you are editing, report back with that information... and your project setting, and if there is a red line above the video in the timeline, which indicates a mismatch between video and project
    More information needed for someone to help http://forums.adobe.com/thread/416679
    Some is general about your computer and OS, some is specific to video editing
    Build a Configuration file http://www.piriform.com/speccy
    Brand/Model Computer (or Brand/Model Motherboard if self-built)
    How much system memory you have installed, such as 2Gig or ???
    Operating System version, such as Win7 64bit Pro... or whatevevr
    -including your security settings, such as are YOU the Administrator
    -and have you tried to RIGHT click the program Icon and then select
    -the Run as Administrator option (for Windows, not sure about Mac)
    Your Firewall settings and brand of anti-virus are you running
    Brand/Model graphics card, sush as ATI "xxxx" or nVidia "xxxx"
    -or the brand/model graphics chip if on the motherboard
    -and the exact driver version for the above graphics card/chip
    -and how much video memory you have on your graphics card
    Brand/Model sound card, or sound "chip" name on Motherboard
    -and the exact driver version for the above sound card/chip
    Size(s) and configuration of your hard drive(s)... example below
    -and how much FREE space is available on each drive (in Windows
    -you RIGHT click the drive letter while using Windows Explorer
    -and then select the Properties option to see used/free space)
    Windows Indexing is BAD http://forums.adobe.com/thread/676303
    While in Properties, be sure you have drive indexing set OFF
    -for the drive, and for all directories, to improve performance
    Some/Much of the above are available by going to the Windows
    Control Panel and then the Hardware option (Win7 option name)
    OR Control Panel--System--Hardware Tab--Device Manager for WinXP
    And the EXACT type and size of file that is causing you problems
    -for pictures, that includes the camera used and the pixel dimensions
    Plus Video-Specific Information http://forums.adobe.com/thread/459220
    Read Bill Hunt on editing a VOB/MPG file http://forums.adobe.com/thread/464549
    Edit Vob http://premierepro.wikia.com/wiki/FAQ:How_do_I_import_VOB_files_/_edit _a_DVD%3F
    Read Hunt on Using MOD/TOD files http://forums.adobe.com/thread/699990
    Work through all of the steps (ideas) listed at http://forums.adobe.com/thread/459220
    If your problem isn't fixed after you follow all of the steps, report back with ALL OF THE DETAILS asked for in the FINALLY section at the troubleshooting link
    Also read file troubleshooting http://kb2.adobe.com/cps/407/kb407928.html
