need help with display table in cfoutput query
Nov 20, 2011 9:58 AM
i need to do this form of outputting cfoutput query.
<cfquery name="myquery" datasource="mydsn">
select email,phone from mytable
</cfquery>
<table>
<tr>
<cfoutput query="myquery">
<td>
#myquery.email#<br/>
#myquery.phone#<br/>
</td
</cfoutput>
</tr>
</table>
but i need output like this like for every 2 records i need new row.
Example.
Now getting my outpout like this
1   2   3   4  5   6  7
i want my output like this
1   2
3   4
5   6
7
Please help me
Thanks.
    Nov 20, 2011 5:23 PM   in reply to cfnew
    <cfif currentrow mod 2 is 0 and currentrow lt recordcount></tr><tr></cfif>
    Your job is figure out where to put it.
    Nov 21, 2011 12:49 AM   in reply to cfnew
    Do you really want to display the email and phone of 2 different users on the same row? That doesn't make sense to me. Then again, do you mean, by 2 records per row, that you wish to display the email and phone per user per row? If so, then you require something like this
    <table>
    <tr>
    <td>
    #myquery.email#
    </td>
    <td>
    #myquery.phone#
    </td>
    </tr>
    </cfoutput>
    </table>
    Nov 24, 2011 7:59 AM   in reply to cfnew
    </cfquery>
    <table>
    <tr>
    <td>
    </td>
    <cfif currentrow mod 2 eq 0 or currentrow eq recordcount>
         </tr>
    </cfif>
    </cfoutput>
    </table>
    Nov 24, 2011 9:09 AM   in reply to cp_anil@rediff
    </cfquery>
    <table>
    <tr>
    <td>
    </td>
         </tr>
    </cfif>
    </cfoutput>
    </table>
    Not quite. Check Dan's suggestion once again.
    Nov 24, 2011 9:18 AM   in reply to BKBK
    Better yet, don't check my suggestion unless this is an academic exercise.  BKBK gave a better answer.
    Nov 30, 2011 7:33 AM   in reply to cfnew
    Sometimes its tricky to get the kind of output you want when you are populating a table with the results of a query, during web application development.
    After every two records you want to close the row with </TR> tag, and create a new row in the table using the <TR> tag, which stands for TABLE ROW. Using the MOD function is probably the best way to do this. If the currentrow is divided by 2 with no remainder, then you have to create a new row of data. the equivalent in ColdFusion is <cfif (CurrentRow MOD 2) eq 0>
    Here is an example of the code you would need:
    <table>
    <tr>
    <td>
    </td>
    <!--- if we have outputed two cells of data, close the row and start a new row unless we are at the end of the data --->
    <cfif ((currentrow mod 2) eq 0) or (CurrentRow eq RecordCount)>
         </tr>
         <cfif CurrentRow lt RecordCount> <!--- if we are not at the end of the data, start a new row in the table for data --->
            <tr>
         </cfif>
    </cfif>
    </cfoutput>
    </table>
    You have to visualize how the data will be outputed. Hope this helps.
    Michael G. Workman
    mworkman@usbid.com
    http://www.usbid.com
    http://ic.locate-ic.com
    Dec 8, 2011 4:13 AM   in reply to cfnew
    Please try this one
    <cfscript>
        row=1;
    </cfscript>
    <table>
        <cfoutput query="myquery" >
                <cfif row mod 2 eq 1>
                    <tr>
                    <td>#row#</td><td>#myquery.email#</td><td>#myquery.phone#</td>
                </cfif>
                <cfif row mod 2 eq 0>
                    </tr>
                </cfif>
                <cfset row=row+1>
        </cfoutput>
    </table>
