My server is running the following:
I'm running some command line software to generate audio for a custom captcha form. I can't get this bat file to run with cfexecute. I can run the bat fine if I run it manually and it generates the .wav file but it will NOT run with cfexecute. I had tried running the exe with cfexecute while passing the arguments and all that outputed to the page was "[empty string]". I have read pretty much every forum post I can find searching through google and can't find the solution to my problem. Please someone help me out I'm wracking my brain over this.
Variables passed:
<cfparam name="FileName" default="">
<cfparam name="Cap" default="">
<cfset newString = "">
<cfloop index="intChar" from="1" to="#Len( Cap )#" step="1">
<cfset strChar = Mid( Cap, intChar, 1 ) />
<cfset newString = newString & "#strChar#.....">
</cfloop>
<cfoutput>
<cfsavecontent variable="cmd_content">C:\TSC.exe /s "#newString#" C:\Inetpub\wwwroot\captcha\#FileName# Mary (for Telephone)</cfsavecontent>
</cfoutput>
<cfset cmd_filename = "#ListFirst(FileName, ".")#.cmd">
<cffile action="write" file="C:\Inetpub\wwwroot\captcha\#cmd_filename#" output="#cmd_content#">
<cfexecute name="C:\Inetpub\wwwroot\captcha\#cmd_filename#" outputFile="C:\testoutput.txt" timeout = "90"></cfexecute>
This is the content of testoutput.txt when the script is ran:
C:\ColdFusion9\runtime\bin>C:\TSC.exe /s "N.....F.....A.....C.....Z.....M.....U.....2....." C:\Inetpub\wwwroot\captcha\NFACZMU2-050031.wav Mary (for Telephone)
What am I doing wrong?
I still can't get it to work that way. I changed my cfexecute to:
<cfexecute name="C:\windows\system32\cmd.exe" arguments="/c C:\Inetpub\wwwroot\captcha\#cmd_filename#" outputFile="C:\testoutput.txt" timeout = "90"></cfexecute>
And I changed my bat file to have:
cd\
</cfsavecontent>
The output file is showing:
C:\ColdFusion9\runtime\bin>cd\
C:\>TSC.exe /s "3.....P.....4.....Z.....8.....U.....7.....X....." C:\Inetpub\wwwroot\captcha\3P4Z8U7X-105724.wav Mary (for Telephone)
I still can't get it to run the exe. I have watched the process list while running this and the exe doesn't show up. I tried cfexecute on the exe directly before trying the bat method, with hard coded arguments, and it still didn't work. I am so lost right now this makes no sense to me.
Try this to get more info. Put acfabort in front of the cfexecute code. Run your script - let it create the bat file and then stop before trying to execute it. Then go into a DOS box on the same machine and execute the bat file manually, see what happens. What does it give yoy for any errors, etc.
Good luck
reed
