Is there a way to delete the space between multiple clips on the timeline with one click?
I trim clips on the timeline, so I can have a couple hundred clips with space between on the timeline. Is there a way to delete all the spaces between the clips at once?
Right now I have to ripple delete the space between each clip, big hassle and a lot of key strokes. Is there a better faster way to trim clips in general? Or delete the spaces on the timeline?
The fast way to edit and avoid your issue is to edit the clips in the source monitor and insert or overlay them to the timeline from there.
(There are a number of ways to insert or overlayclips ).
Using the Razor in the timeline for trimming and editing is slow. Tidying up the mess adds more time.
The Razor Tool is for splitting clips.
If you are actually trimming clips by dragging the ends of them. Use Ctrl Drag to ripple the edit as you go.
I have not used the source monitor much. Can I use the sourse monitor to make a lot of cuts "clips" out of one big clip? Say I want to take the highlights out of a long wedding ceremony? Or do I need to do this one the timeline. Edit clips on the timeline is very intuitive to me and I can do it fast, except for all the spaces betweent the clips. ![]()
I agree. When she first posted that, I was amazed how simple it was to use, so bookmarked it for use by others.
Now, PrE has a built-in function for Deleting All Gaps, but it's limited to only Video, where there is no overlaying Video, or underlying full Audio. Those two situations will keep PrE's function from doing anything with the gaps.
To Silverfox, welcome to the forum, and hope that Ann's method cleans up those gaps for you.
Good luck,
Hunt
Yes, you want to use ripple delete and you will not have ths problem. Before I learned ths I had to trim like you are doing and then right click and select ripple delete. Take or setup a text sequence and play around with ripple delete and the other tools. Each one as it uses and can help speed up editing.
John Gerard
I think that this would make a good Feature Request, but it would need to be more robust, than the similar function in PrE. Since PrE does not have the same Track Targeting, that PrPro does, I think (not being a coder), that it could be implemented to function on a Targeted single Video Track, to work irrespective of other Tracks, both Video & Audio.
Good luck, and glad that worked for you. When I saw it first, I exclaimed a great big "NEAT !" and immediately bookmarked it.
Hunt
Absolutely ( and I wouldnt do it any other way because it is designed for ease and speed)
Try it:
1.Target a Video and Audio track in the timeline
2. Place the long source file in the Source monitor.
3. Locate the first highlight and Set In and Out Points ( KBD Shortcut "I' and "O")
4.Then Insert it to the timeline ( KBD "," )
Note: there are a number of ways of sending the selection to the timeline (eg.Insert / Overlay buttons, drag it to the Program Monitor, drag direct to the timeline). You can also take video only, audio only, both. Darg options have modifier keys for insert / overlay ripple-ing
Back to the source monitor (step 2) and mark next highlight selection....repeat steps...etc.....
Ensure your CTI (playhead) is always at the end of the last clip in the timeline. KBD short cut "End" and you will have no gaps to deal with.
shooternz, it is not possible when external audio is used
CS6 is out, but the feature is still not there
removing gaps still involves multiple steps. AnnBens created a great Tutorial for cases when clips are not spread on multiple tracks, but even in that case the technique is great.
Here's another solution for such cases, it is to use a bunch of short video/audio clips in a prepared sequence.
You can leave "Remove Gaps" sequence in the project if it is need to be used multiple times per session.
It's not faster to use, and it bloats project size.
And in fact it's much slower if you try to Copy/Paste a thousand of small clips
