I'm relatively new to FlashBuilder development and I'm having some issues with a bar chart. I'm try to create a chart to show the timeline of projects, each with a start and end date.
(1) The actual bars appear only on the left side of the y-axis.
(2) If I hover the mouse over the blank chart area, it shows a tip for the bar that is not visible (see screenshot).
(3) The dates on the x-axis are in descending order and should be in ascending order.
I would appreciate any help with any of these issues. Thanks!
Code to display the chart:
<s:NavigatorContent id="navProjectChart" label="Project Chart">
<mx:BarChart id="bcProjectChart" dataProvider="{chartData}" left="2" top="40" width="710" includeIn="List" paddingRight="5" paddingLeft="5" showDataTips="true" type="clustered" height="505">
<mx:horizontalAxis>
<mx:DateTimeAxis dataUnits="days" title="Timeline" parseFunction="parseDateStringToDate" />
</mx:horizontalAxis>
<mx:verticalAxis>
<mx:CategoryAxis categoryField="Name" />
</mx:verticalAxis>
<mx:series>
<mx:BarSeries xField="EndDate" minField="StartDate" fill="{sc1}" stroke="{s1}" />
</mx:series>
</mx:BarChart>
</s:NavigatorContent>
protected function parseDateStringToDate(s:String):Date
var newDate:Date = DateFormatter.parseDateString(s);
trace("Input string: "+s+", Parsed Date: "+newDate);
return newDate;
Can you please send me a sample application at deeptika(at)adobe(dot)com?
I used the following app and it seems to be working fine
<?xml version="1.0"?>
<!-- Simple example to demonstrate the BubbleChart control. -->
<s:Application xmlns:fx="http://ns.adobe.com/mxml/2009"
xmlns:s="library://ns.adobe.com/flex/spark"
xmlns:mx="library://ns.adobe.com/flex/mx">
<fx:Script>
<![CDATA[
import mx.collections.ArrayCollection;
import mx.formatters.DateFormatter;
[Bindable]
private var chartData:ArrayCollection = new ArrayCollection([
{Name: "A1", StartDate: new Date(2011,10,10), EndDate: new Date(2011, 11, 10)},
{Name: "A2", StartDate: new Date(2011,7,9), EndDate: new Date(2011, 10, 10)}
return newDate;
</fx:Script>
<mx:horizontalAxis>
<mx:DateTimeAxis dataUnits="days" title="Timeline" />
<mx:verticalAxis>
</mx:verticalAxis>
<mx:series>
<mx:BarSeries xField="EndDate" minField="StartDate" />
</mx:series>
</mx:BarChart>
</s:Application>
Deeptika
